Question about Ricoh GX3050sfn InkJet Printer
Warning close scanner unit scaner unit open and it's actually closed
2 Suggested Answers
SOURCE: display screen says: door/covers open close covers of relay unit??
I believe the "relay Unit" on that machine is the section that transports copies to either the finisher (if installed) or the exit tray on the LEFT side of that machine. Sometimes neither of these units are present, but the relay unit may still be installed.
There are 2 flip up covers on that section (left and right), and you will probably see that one of them (usually the left one) has come unclipped, or perhaps the plastic clip that holds it closed is broken. If you flip up this unit. You will see a black button at the back end that is engaged when ther unit is closed. If you simply pree this button with your finger, hopefully the message will go away - this may at least help you troubleshoot what is causing the "cover open" message). Even if the clip is broken, it is often just a matter of seating the unit correctly so that the switch is engaged when the unit is closed. There is also the same switch on the right cover that could be causing the problem, but this cover doesn't sem to get damged as often.
I hope this helps. Please let me know.
Posted on May 26, 2009
Close the scanner unit warning
Found the problem!
1. Open unit as if replacing ink.
2. Remove panel displaying
SERIAL No. XXXXXXXXXX INK INFO STICKER
3. Find "button sensor" in top left corner. When pressed down the unit registers the scanner unit as closed.
There must have been a piece that broke off. That piece used to press the "button sensor" down when lid was closed.
Hope this helped some other our there!
P
May 28, 2012 | Epson Workforce 610 All-In-One InkJet...
Mon imprimente pixma mp810 donne un code erreur 5020 et demande de deverouiller le scaner
This correction is listed on the Canon website. Lock Switch Make sure to unlock the scanning unit before turning the machine on.
  1. Lift the document cover open.
  2. Slide the scanner lock switch to the release mark.
    Caution : Make sure to unlock the Scanning Unit (Printer Cover) before turning the machine on.Before transporting the machine, always lock the Scanning Unit (Printer Cover) by moving the Scanner Lock Switch towards the lock mark.
  3. Close the document cover.
  4. Press to turn off the machine.
  5. Wait approximately 5 seconds then press to power back on the printer.
Mar 27, 2011 | Canon PIXMA MP810 All-In-One InkJet...
How to unlock the scaner
I am posting this solution for Dell printers but i guess it will work well on samsung too...
  • Lift the scanner unit on the front of the printer until you hear the scanner's support click and lock. Use both hands to lift the scanner unit.
  • Locate the scanner's lock switch on the left side of the raised scanner beside the scanner support and pull the lock toward you.
  • Lift the scanner unit. Push and hold the scanner support back to release the scanner unit from its raised position.
  • Lower the scanner unit slowly until it is completely closed.
  • Turn on the printer.
Feb 26, 2011 | Samsung SCX-4216F All-In-One Laser Printer
My printer is not printing I need to know how to intall the ink
Hi Good day. Here are the ways to install the ink in your printer.
1 Ensure the All-In-One printer is powered on.
2 Lift the scanner unit or access door (
The cartridge holder will move to the center of the Inkjet or All-In-One.
3 Press down on the cartridge carrier latch to raise the carrier lid.
4 Remove the used cartridge. NOTE: If you are removing both cartridges, repeat the preceding two steps for the second cartridge.
5 Remove the protective tape from the back and bottom of the new cartridge(s).
WARNING! Do not touch the gold contact area on the back or the metal nozzles on the bottom of the cartridges.
6 Insert the new cartridges into their respective carriers. The image at right illustrates inserting the color cartridge.
7 Close the carrier lids so that they remain closed.
8 Close the access door or scanner unit, taking care to keep your hands out from underneath the scanner unit as it is being closed.
9 On some All-In-One units, the control panel display will prompt you to load paper and print an alignment page. NOTE: The scanner unit must be closed before you can start a new scan, print, copy, or fax job.
Oct 07, 2010 | Lexmark X5470 All-In-One InkJet Printer
Hanging problem
scan the exit code it will close your scanner and then scan the recall default code (4 times) then scan the ENTER code your problem will be solve
Eshwer
Dec 18, 2009 | Eclipse Metrologic MS5145 Barcode Scanner
Sharp AL 1631 is flashing 1 L. What does that
Hi:
This might refer to your scanner assy being locked. The scanner assy is the unit under the glass that scans your document prior to copying it. Look inside the cavity where you pick up your completed copies. Look at the upper left corner and see if there is a knob there. If there is, make sure it is in the completely unlocked position.
Andrew
Aug 09, 2009 | Sharp AL 1631 Copier
Ink
The cartridge holder will move to the center of the All-In-One
Close the scanner unit, taking care to keep your hands out from underneath the scanner unit as it is being closed.The control panel display will prompt you to load paper and print an alignment page. NOTE: The scanner unit must be closed before you can start a new scan, print, copy, or fax job.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 07, 2009 | Lexmark X5150 All-In-One InkJet Printer
My Umax 3400 astra driver is not working in Windows Xp.
dowload vistascan vs375u (11,674KB) and open it you will receive 6 disks+1 disk german and 1 disk english. open the disk 1 and double click VSSETUP you will see a lot of DOS commands and at the end you will have VISTASCAN in the Programs Files ( Start--All Programs--VistaScan--enter) .
If Scanner test works O.K.
if not
- go to MyComputer right click,
- click hardware,
-click device manager,
-right click the UMAX Astra
-click update driver
-click "install from a specific location" Next "Don't search I will chose the driver to install"-- Next -- choose USB scanner (Not UMAX Astra 3400) --Next--
- you will receive a warning " continue anyway" finish
- Reboot.
open VISTASCAN Test it will pass now
good luck
jacques
Nov 29, 2008 | Umax Astra 3400 Flatbed Scanner
Flash pops up, but flash closed warning stays
My E5700 did this a couple of times. The fix for my flash was that the unit wasn't actually popping all the way open. I closed it, then manually poppped open the flash and gave it a gentle upward tug. The flash seemed to lock into position -- and has worked fine since. I hope your fix is as simple as with my E5700.
I hope this helps!
Regards,
CharlieJ
[Please rate this solution, if it helps you.]
Nov 01, 2008 | Nikon Coolpix 5700 Digital Camera
Transparency adaptor won't close
Remove the transparency adaptor from the scanner bed (unscrew the two smaller screws, then slide back and off) and then remove the glass (and plastic frame) of the transparency adapter (there are six screws).
By the hinge there is a small white plastic switch. Usually the transparency adaptor hits this when it's closed, letting your computer know that it is ready to scan. What I did, as bcvideo did, was take duct tape and firmly taped the switch to the side of the transparency adaptor, using several small strips of tape.
The scanner works well now. You may need/want to put something on top of the scanner if it does not fully close.
Apr 08, 2008 | Epson Expression 1680 Professional Flatbed...
Ricoh GX3050sfn InkJet Printer Logo
89 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
