Question about Whirlpool MH2155XPS Microwave Oven
HOW DO YOU REPLACE HANDLE ON A WHIRLPOOL MICROWAVE. DO I NEED TO PRY BACK THE CLIPS ON INSIDE FRAME.
  • Whirlpool Master
  • 9,098 Answers
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In some cases, you then have to gently rotate the handle to unlock it.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on May 30, 2010
How to replace the door handle on a whirlpool MH2155XPQ micro wave
The screws that hold on the handle are inside the door assembly. Here is the way its done but its not for the average person. On the inside of the door is a plastic frame all the way around the door. It is held in place by plastic tabs. You have to gently pry off that frame with something like a putty knife or small screw driver. If you are not careful you end up breaking off some of the tabs. Once that frame is off you should have access to the 2 screws holding on the handle. Remove screws---replace handle---and push plastic frame back on.
Jun 26, 2015 | Whirlpool MH1150XM Convection/Microwave...
Trying to replace handle on door,removed three screws on side of door unable to remove inside panel
Most microwave doors are just clipped together with plastic tabs.To remove the inner door panel you need to carefully pry the plastic frame off the inside with something like a small screwdriver or putty knife. Even being careful you may end up breaking the tabs or frame. Once the inner frame is removed you should be able to get to the handle screws. I'll try to attach a picture of the door breakdown.
May 09, 2015 | Whirlpool MH7140XF Microwave Oven
How to disassemble the door of gmh5205xvs-0
On the inside of the door there is a plastic frame that goes around the edge with 2 slots in it that the door latches go through. You have to very carefully pry the frame outward to remove it. First check with a parts supplier to see if your handle is available because some microwave doors are not repairable----you need to purchase a complete door. If the handle is available then attempt to remove the frame as I described before. Once the frame is off you should be able to see the handle screws. If they are still hidden the outer door frame and inner metal door will need to be separated also. They too just pry apart with plastic tabs holding everything together. Replace handle and reassemble. Not hard just time consuming and must be done carefully so as not to break the plastic parts.
Feb 26, 2015 | Whirlpool Microwave Ovens
Need to replace door handle
1. Unplug microwave oven or disconnect power. 2. Open the microwave oven door. 3. Pry the choke cover away from the top door pin, and remove the top pin from the pivot bracket. Lift the door off the bottom bracket, and remove it. 4. Place the oven door front side down on a padded surface. 5. Remove the choke screws from the door frame. 6. Starting at the top right corner, pry the choke cover out with a putty knife, and unsnap it from the choke. Only remove the top, bottom and right sides of the choke cover at this time. You will remove the handle end of the choke cover later. 7. Starting at the top edge of the door near the center and working clockwise, use a putty knife, and pry the latching tabs of the choke out of the door frame slots. Lift the choke as you release the tabs so they do not snap back into the slots. NOTE: When you reach the handle side of door, pull both the choke and the choke cover away from the door frame, and then separate the two components. 8. To remove the door switch actuators from the choke, remove the screw from each actuator. REASSEMBLY NOTE: When you reinstall the door on the oven, insert the top pin into the pivot bracket and press down on the pin until it snaps into place
Read more: http://www.appliancepartspros.com/whirlpool-microwave-door-handle-w10246505-ap4418092.html#qa1#ixzz2qpA2P5CA
Jan 17, 2014 | Whirlpool MH3184XP Microwave Oven
Mmi have a ge advantiun x20 model SCA1001FSS01 THE HNDLE IS BROKEN OFF HOW DO i REPLACE THIS pafife@yahoo.com
HELLO.
THE SOLUTION ON HOW TO REPLACE THE BROKEN HANDLE
THINGS NEEDED.
Phillips screwdriver.
Thin, flat-head screwdriver.
Putty knife.
Replacement microwave door handle.
1 Examine the inside of the door. The handles of some early GE Spacemaker microwave models were attached after the two inner door panels were assembled to the outer door. If you see two recessed screws opposite the handle attaching points, undo them with a Phillips screwdriver and remove the handle. If not, go to the next step.
2 Insert the blade of a thin, flat-head screwdriver into the top, outer corner of the door, between the plastic inner frame and the outer door. Gently pry the inner frame out and slip a putty knife into the exposed opening on top of the door. Slide the putty knife toward the hinges to free the top of the inner frame; repeat on the front and bottom edges of the door and lift the inner frame out to expose a second metal inner frame.
3 Insert a thin, flat-head screwdriver into each of the small square openings on the top and bottom of the inner metal frame, starting at the handle end of the door. Undo the attaching clips by gently levering the inner door away, using the rim of the outer door as a fulcrum. Move the inner door away from the outer door on its hinges.
4 Remove the glass from the outer door. Undo the two screws holding the handle to the outer door with a Phillips screwdriver. Screw the replacement handle onto the door and tighten securely.
5 Replace the glass panel and reassemble the door by snapping the two inner frames back in place.
Thanks.
Aug 30, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
There is a whirlpool Microwave (model:MH1150XMB4) in our apartment. Unfortunately, there is a crack in the door. Although the crack is only in the plastic frame of the door, the landlord asked us to...
Got the same problem. Still inquiring but I might have found a solution here : http://midwestapplianceparts.com/microwave-parts-537/whirlpool-microwave-parts-648/microwave-door-panel-663/whirlpool-microwave-door-panel-w-glass-4212.html
$79 for the panel only
Jul 01, 2010 | Whirlpool MH1150XMQ Microwave Oven
Need help replacing handle on whirlpool microwave model MH1150XM
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2009 | Whirlpool MH1150XM Convection/Microwave...
Replacing door handle of Whirlpool GH6178XP
I kept prying on the frame case until it disengaged, came loose and exposed the bottom screw.
Feb 17, 2009 | Whirlpool GH6178XPS Microwave Oven
I would like to replace the microwave oven handle.
The inside of the door has a Black Plastic frame about 1 inch wide. This frame can be removed by placing a thin screwdriver between it and the outer door frame and gently (very gently) prying it away from the door. It takes a little wiggling of the frame but it will unlock. On each end of the handle is a philips head screw that holds the handle to the door.
Jan 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave door handle replacement
Solution for GE Spacemaker Ovens (my model is JVM1650BH05)
1- Remove door by lifting it out of hinges. You will need to remove grille first (2 set screws).
2- Carefully pry off the plastic inside door trim. Use a fine knife or putty knife. There are 10 tabs holding the trim from behind. It's OK if you break a tab! Try to pull out as straight as possible.
3- Once the trim is off, remove the 2 visible screws that hold the door handle. NOTE: There are 2 invisible screws so you are not done yet!
4- You now need to remove the metal ring that holds the latches. To do that, grab the metal ring and using your other hand, release each plastic tab one by one (same tabs as above).
5- Once the metal ring is loose, you will see 2 screws. Remove them if they are still there.
6- Position your new handle and attach using the first 2 screws.
7- Reposition the metal ring by re-snapping it in place. Install the other 2 screws.
8- Replace the plastic trim by snapping it back in place
9- Reinstall door and grille. Tell wife or hubby that you are a genius!
Bonus: use metal washers when screwing down the 2 first screws.
Mar 10, 2008 | Microwave Ovens
Whirlpool MH2155XPS Microwave Oven Logo
110 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
