Question about Car Audio & Video
Have a woodstock DAB Car Radio to go into a BMW but the unit does not have the outer metal case that it would need to slide into, where do you think I would be able to purchase one?
  • 185 Answers
Any car audio shop should have one like bust buy or hh greg
Posted on Apr 09, 2008
SOURCE:
I have a blaupunkt woodstock dab 54 and its stuck saying wait 1h HELP!
by default you have 3 chances to enter your code, after then time is get much longer for you to wait. what you can do is still keep your radio power on and leave it for 1 hour, Do not power Off. the cycle of wait will reset. then you can try enter you code again. hope its help.
Aug 02, 2014 | Blaupunkt Woodstock DAB 52 CD Player
My woodstock dab 54 reads kcard not ok after i changed the battery and wont let me keycode number
Hey I could do with help on this as I have lost the kcard (Ihave the code)
Feb 18, 2012 | Audio Players & Recorders
Need radio code for 91 bmw 5251
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Remove the radio from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes or stamped in the metal casing.
These older BMW radios usually require specialist advice for the code so it might be quicker to ask here
[email protected]
Aug 10, 2010 | BMW Car Audio & Video
Radio unlock code
Dear Madam or Sir,
the unlock code can only be recovered by the BMW Dealer, it´s saved in the BMW databases. The dealer only needs to know the vehicle identification number of your car.
Jun 26, 2010 | 1994 BMW 5 Series
What is the scanner frequencie for Woodstock City Police. Woodstock Ontario Canada
Here is the info from Radioreference.com.
http://www.radioreference.com/apps/db/?ctid=4312
139.77000 Woodstock City Police (Ch7)
142.42500 Woodstock City Police (?)
142.47000 Woodstock City Police (?)
142.68000 Woodstock City Police (Ch 1)
142.68000 Woodstock City Police (Ch 2)
142.86000 Woodstock City Police (ch 5)
142.92000 Woodstock City Police (Ch 6)
413.23750 Woodstock City Police (UHF)
158.38500 Woodstock City Fire
Hope this helps - J
For all of you scanner needs try ScannerMaster
Nov 18, 2009 | Radio Shack Pro-95 Handheld Scanner
I just bought a dab from Morphy Richards and, it appears that you need aa remote to change channels. Could this be so? Display says press select yet there aint no select on the unit... model is Morphy...
ok i just found out what it is digital radio !!!!!!!! ok i dont think we have a radio department but i think we still have a car audio department . those guys should be up on all this new stuff .... good luck
Mar 30, 2009 | Morphy Richards 44051 4-Slice Toaster
I don't know which JVC unit I have.
no i dont think so. but it is fairly easy to remove if u visit your nearest store that sell car stereos ask them for the removal too for a jvc radio. they should give u to flat L shaped pieces of metal all u have to do is remove the thin plastic trim piece around the radio then on both sides of the radio between the radio and the metal cage that holds the radio they will slide in u may have to play around with them a little till they unlock the radio but when they do all u have to do is just slide the radio to u enough to read a white label on the top of the radio that will give u the model number. should take no longer than 15 min. after that pull the tools out then just slide it back in till u here or feel it lock and your done oh dont forget to put the radio trim back on.
Nov 13, 2008 | JVC KD-S680 CD Player
Blaupunkt woodstock 54 has a mind of its own...
Hi
Ive got the same unit & they can be a bit unpredictable.Theres a way around it as the unit facilitates a 'NORMSET' feature which allows the user to reset the unit to basic settings as when it was first taken out of the box.
Also the sd card you use can only be 1gb or less & has to be formatted in 16kb through windows XP or Vista.
If you want to know more get back to me & I will talk you through it,it sounds like the units been corrupted by a sd card that wasn't formatted correctly as this happened to mine but now is sorted.
The WOODSTOCK Range aren't made anymore,the latest version is the NASHVILLE,and I was advised that my unit may have had to go back to Germany for reprogramming as no-one really knows about them in the UK.
However I sought advice and problem was rectified.
Mar 21, 2008 | Audio Players & Recorders
Car Audio & Video Logo
82 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
