I have a Technics Integrated Amplifier SU-G70. It plays great, but keeps switching from CD to Tuner. It will play for about five minutes in each mode and switch back and forth. What do you that the problem is.
    Guru:
  • 722 Answers
If you feel comfortable doing so, (and it is no longer under warranty) pull off the case and make sure there are no loose wires, or no wires touching.
If this unit was recently purchased, I highlyl advise taking it bakc ot the placeof purchase for replacement or repair. Also, if there are any internal or external fuses, make sure none of them are blown, and make sure this is being plugged into a surge protector, and not just a wall outlet.
carsandcomps,
Guru, Premium Expert @ Fixya.com
Posted on May 29, 2010
Does a technics stereo amp su-g90 have a stereo to play music
This device does not have an internal tuner. It is simply an amplifier. The buttons on the front labeled TUNER - TAPE - PHONO - DAT/VCR 1 - VCR 2/TV are selector buttons for additional components that hook up to the respective connectors at the rear of the unit. If you want to play a radio with this device, you must buy a tuner and attach it to the tuner inputs in the rear of the unit.
Oct 03, 2016 | Technics Audio Players & Recorders
Technics SU-X302 Problems
Greetings
Is there any indicator on or its all off?
anyway i will assume that there is none
1.check power fuse if blown.
2.check power transformer if there is any output voltage
3.check internal fuses
more information will give a better idea.
try these steps and hope this helps.
Dec 25, 2013 | Technics Audio Players & Recorders
I have a technics hifi su-ch900 everytime I play a cd or cassette or have the tuner the sound cuts out when its slightly loud, on low volume its fine. I have checked the cables and they are correctly...
I found a link to a CH900 that switched off completely.
If you are not a technician, please don't open the amplifier.
But I think it will be a simple repair. It is not the same problem, but it looks a little simelar.
http://www.electronicspoint.com/technics-su-ch900-switching-off-t53309.html
Also found a service manual, but not complete. Still here is the link
http://elektrotanya.com/technics_su-ch900.pdf/download.html
Oct 30, 2013 | Audio Players & Recorders
Su-c800u pre-amp switching not steady, keep darting from one mode to another and disrupting smooth flow of music
I had the same issue.the contacts on selector switch is dirty.All u need to get a good contact cleaner and spray the selector rod( remove knob first with preamp facing up), the liguid will find leak into selector and clean contacts.
after doing mine, the slector knob feels more solid when turned and does not change input anymore.
Junior
Jan 14, 2012 | Technics Audio Players & Recorders
My su-g95 technics Stereo integrated amplifier wont play any noise. and when i adjust the volume it makes a popping/crackling noise. i am 100% sure all the speakers were hooked up correctly.
Well it sounds like your amplifier IC's are working correctly since you are hearing that pop. I have the same amplifier and every 10db increment it pops. Have you tried every input? Possibly try starting at a low volume, plug an RCA plug into CD or any other input, and touch the center prong of the other end of the cable. You should get a 60hz hum if your in the USA, otherwise it will be 50-55hz. Regardless it should make noise.
Sep 29, 2011 | Technics SUV500 2-Channel Amplifier
How do I connect my CD Player, Tape Deck and Tuner to the SU 300 Technics Amplifier
hi,
For connecting these to your amplifier you need 4 Stereo RCA Cable.
1.Connection for cd:
Take one of the RCA cable connect the one end (red/white) jack to the line out of your cd and connect the other end (red/white) to the CD input of Your amplifier.
2. Connecting the tunner:
Take one of the RCA cable and connect the one end (red/white) jack to the line output of you Tuner and connect the other end (red/white) to the TUNER input of your amplifier.
3. Connectiong the tape deck:
Now you have two RCA cable. Take one of the RCA cable and connect the one end (red/white) jacks to the PLAY out of the Tape deck and connect the other end (red/white) to the TAPE 1 play input of your amplifier.
Now connect the last RCA cable. Connect the one end (red/white) jack to the record input of the TAPE deck And connect the other end (red/white) to the TAPE 1 Record input of your amplifier.(this connection will help you to record to tape from cd or tuner. if you are not interested in recording then you can avoid this connection.)
Now you can select these three items from the frond plannel control switch of the amplifier.
ok
Jul 28, 2011 | NAD 218THX 2-Channel Amplifier
I have a technics SU-V98-KM8 Amplifier that turns on and lights up but does not have any soundd coming out of it. I have checked alll the cables and cords and everything is hooked up the way its supposed...
Your amplifier is turned on and all the indicator lights work and you made it sure that all the cables, and cords are attached to where they are supposed to be connected and yet you don't get any sound coming out when you play a music. Amplifiers have selector knobs for you to set where your source is coming from. Selector knobs can be set to TUNER, DVD, CD, and AUX. The scenario might be like this: your source is coming from a movie being played on your DVD player connected to your amplifier but your knob selector is set to AUX. Try playing a music selection from your CD player attached to your amplifier and set the selector knob to CD. If still there is no sound coming out you need to have it checked by a qualified technician.
Jul 23, 2011 | Technics Audio Players & Recorders
SUV500 2-Channel Amplifier: Hi! can I connect another technics cd-player,sl...
yes you can connect another cd player to the DAT input of your amp.
input connections like DAT, TUNER, CD, AUX etc (except phono) is just to differentiate between what sources are connected, the amp cannot tell what source is connected and will output the sound no problem.
as for the remote operation, if the 2 technics cd players are switched on at the same time they're going to do what you command from the remote together but you'll obviously be listening to 1 at a time.
May 17, 2010 | Technics SUV500 2-Channel Amplifier
Technics SU-G91 OVERLOAD PROBLEM
THe amp has detected a problem and shutdown to prevent further damage. This unit has 2 amp pacs inside and one or both have failed. If you can solder, you can fix this yourself. The main amp pac is an SVI3206 and can be purchased online for about $60.
Keep me posted.
Dan
Oct 17, 2008 | Audio Players & Recorders
Technics su-a808 amp & sh-ge70 graphic equaliser.
connect your media source(dvd-cd player)to equalizer in-connect equalizer out to amplifier line in-or aux in-connect amplifier out to your loudspeaker.
Jun 24, 2008 | Audio Players & Recorders
64 people viewed this question
 Grubhead
Grubhead
