Question about Yamaha RXV765BL Receiver
Turned on my Yamaha RX-V765 Main. Then turned on my blueray DVD player. Yamaha receiver turned off. Will not turn back on at all. Tried another power outlet no luck. What can I do?
    President:
  • Yamaha Master
  • 1,114 Answers
The most common problem found on FixYa for Audio VideoTurned on my Yamaha RX-V765 Main. Then turned on - 2_bing.gif Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Posted on Jun 03, 2010
RX V765 switches off
power supply or something is shorted triggering it in self protection to turn off.
have a shop look at it.
Dec 07, 2012 | Yamaha RX-V870 Receiver
When i play dvds through my rx-v1000 the pro logic light is always on. shouldnt it be decoding a digital signal when im playing a dvd?
Hello,there is a chance that dolby digital isnt turned on on the dvd players audio settings, make sure in the dvd menu its not set to pcm.
Feb 08, 2011 | Yamaha RX-V1000 Receiver
My brother gave me this Yamaha RX-V663 receiver because he'd bought a new one. He said it was starting to have sound issues. So, I have seven speakers (minus the subwoofer) all hooked up correctly...
hi,
its not with any setting problem. its because ur receiver have some hardware problem. if there is any supply voltage missing, this problem can occur. especially the +15vand -15v. or if there is any loose contact or dry soldering in power supply or in the DAC ( Digital to analog converter) card. first of all check for any dry soldering in the main board. also check the soldering of DAC board socket and input selector board socket.
ok
Dec 31, 2010 | Yamaha RX-V663 Receiver
Just purchased the Yamaha RX-V765 receiver. Have
I too have purchased the same receiver and have the same speakers. Did you get a good solution to this problem and how does it sound?
Jul 26, 2010 | Yamaha Audio Players & Recorders
My Yamaha RX-V765 receiver has the Yamaha bluetooth but no work
Macs aren't compatible with everything.
So the reason it didnt find it was cause its not compatible. I mean thats my conclusions and it might be right.
Good luck
**dont forget to rate**
Jul 10, 2009 | Yamaha YBA-10WH Bluetooth Wireless Audio...
Problems connecting Yamaha & BluRay player on Portable Computer.
hi i had similar problem, you need to change the settings in the bluray player output to hdmi or auto in other to get sound after the settings turn everything off even from the socket and then turn it back on for that setting to take effect. try this
Jan 12, 2009 | Yamaha RX-V661 Receiver
Yamaha RX V861 - Phillips DVD - No sound via digital coax
Does your TV support "Line In" or "Aux" or "External"? if so plug your "Low end" DVD directly into the back of the tv and verify that you Can get audio. Quite a few DVD players do have a mute feature. Be sure this is turned "off"...accordianman
May 14, 2008 | Yamaha RX-V861 Receiver
Yamaha RXV765BL Receiver Logo
324 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
