Question about Ovens
Why does my brand new ceramic hob appear to have small bubbles under the glass?is this normal?
2 Suggested Answers
SOURCE: Samsung PKG001 Stainless steel Single Oven and ceramic hob
Had exactly the same problem and just had the samsung engineer out (as it was only 3 months old ) who replaced the thermostat. all is now working ok
Posted on Sep 04, 2009
How can you remove burnt plastic from electric hob oven
from the ceramic or glass cook top
will be a slow process cant scratch the top
hope its not tuppa ware
it will smoke
plastic scraper or solid plastic spatula
with hob off .. boiling water little at a time
may have to low heat the hob again
Apr 16, 2017 | Ovens
What products can I use to clean my aeg hg795540xb gas glass top hob? The instructions say neutral products and no hob scrapers
Please, follow this link:
http://www.amazon.co.uk/AEG-Electrolux-50296742005-Ceramic-Cleaning/dp/B002LJDJ7Y
25358477-ou0pu244fjwiiyewsm5u145c-2-0.jpg 6. CARE AND CLEANING WARNING!
Refer to Safety chapters.
6.1 General information
• Clean the hob after each use.
• Always use cookware with clean bottom.
• Scratches or dark stains on the surface have no effect on how the hob operates.
• Use a special cleaner applicable for the surface of the hob.
Dado
Jan 06, 2015 | AEG Ovens
What is the worst that could happen if an electric double oven ceramic hob had the neutral and earth mains power wired the wrong way round ?
Electronic controller would most likely be damaged and need to be replaced. These things usually cost between $350-$400
Nov 28, 2014 | Ovens Ovens
Gas hob Luce(hotpoint) gas on glass 5ring burners keeps going out on low flame when pull pan drawer beneath out
Same problem with my hob. I adjusted the small jets to their lowest setting in order to be able to simmer -impossible on the bigger jets. The problem is the vents underneath the hob. These can't be closed off so the problem appears to be in the design. The solution I have to use while I save up to by a decent German model is to open and close the cupboard doors underneath the hob very, very slowly.
Nov 19, 2013 | Ovens
I have only used my large oven three times and already the inside glass is brown. I have removed it but failed to clean it using all the regular cleaning materials. Can you suggest any way of cleaning...
Use a Stanley (or similar brand) window scraper. Hold it firmly and always flat against the glass and scrape that browm muck away. Be careful not to let the points on either side of the blade to dig in as this will scratch the glass.
This type of cleaning is carried out on ceramic/halogen hobs so is ok to use on interior slass oven doors.
Hope this helps
Jun 15, 2011 | AEG D2100-4 Electric Double Oven
With a new Ceramic Glass Induction Hob EHD68210P which coloured wire is the neutral? Brown, Black, Blue or Green.
Standard wiring colour:
Active - Red or Brown
Neutral - Blue or Black
Earth - Green/Yellow.
Best thing is to call an electrician as you do not want to damage your appliance.
Nov 04, 2010 | Electrolux Ovens
My glass cermamic cooktop is burned, i mean literally. Its milk stains or sauce stains all over it. And i cant remove it. There are dark brown stains on it. Please help me
try using a ceramic hob specific scraper to removed the burnt on bits then use a ceramic hob cleaner.
Can you let me know what country you are in and I can send you alternative links.
The following link are for the uk.
https://www.bosch-eshop.com/eshop/bosch/gb/ceramic-hob-cleaning-1.htm
311299 is the most cost effective as it contains cleaner and scraper.
Aug 21, 2010 | Ovens
I have dropped a cup onto my ceramic Zanussi hob, is the slither of glass that came off able to be repaired ??
Just to clarify something, is your hob above a double oven D2100-4 because that is only telling me about your oven the hob will have its own Mod. no. But any crack to the glass on any Hob can weaken the glass and really should not be used due to the weight of Pots on glass if the glass did break it could be quite dangerous with all the electrics below.
Hope this gives you some help in the matter.
Good Luck.
May 06, 2010 | AEG D2100-4 Electric Double Oven
I have replaced a Kelvinator hob with a ceramic hob. It works but the owen is not working. What is the problem?
There are possibly a number of options. It could be that in wiring the hob in you have disturbed the wiring for the oven. Normally the oven works off the main oven control switch on the panel and the hob could be wired into something else.
Is the oven totally dead no power at all for everything, or is the clock running but the oven will not switch on?
Dec 29, 2009 | Stoves 720EF Electric Double Oven
Samsung PKG001 Stainless steel Single Oven and Ceramic Hob : Hob working ok oven light comes on and fans work ok no display on oven and no heat any suggestions
Jul 15, 2009 | Ovens
Ovens Logo
231 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
