Question about Poulan Garden
Poulan/weedeater te475 how to re string - Poulan Garden
  • 8,197 Answers
To know how to restring go to link below and on page 8 tells you how.
http://www.mymowerparts.com/pdf/Poulan_AYP_1/163886e.pdf
Good Luck
Posted on May 29, 2010
What is gas to oil mix ratio on weedeater string trimmer
The ratio is 40:1 Just add 3.2 ounces of 2 cycle oil to one gallon of fuel. Be sure to cap off the tank and shake to distribute the oil throughout the fuel before adding to weed eater.
Sep 19, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
The spline for my Poulan TE475 WeedEater comes out during start up and wraps around the shaft. I use .080 round spline. It started recently to do this.
The string head on these units is very poorly designed. There is hardly anything in the head to retain the line. I suggest removing the stock string head and going to Home Depot and getting a replacement Universal type head or one for the Ryobi or Homelite They are basically interchangeable. Check the length available on the shaft end (threaded part) after removing the head.Use a large wrench or pliars to hold the dust cap when you unscrew the head. If you feel the driveshaft turning, don't continue turning head or you will break the flex driveshaft.
Jun 30, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Replace pull string (how to put string on after taking cover off)
Basically, pull the string through the winding hole and knot it off insuring no more than .25" tail on the knot and pull tight. :)
Jul 22, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
How do you put string in
turn trimmer upside down grab the spool head firmly and pull out replace string but wind in the way arrow shows you and replace fishing the loose end back through the hole on the side as you slip back together ,once together grab string and pull to remove any slack and away you go
Aug 22, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
WEED EATER STRING
you have the string in backwards, or the gear is not ingauged.
Aug 13, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Garden Logo
650 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
