Question about RIM BlackBerry Curve 8310 Smartphone
My phone dials one particular number by itself.
  • 76 Answers
Reload OS
Posted on Jun 06, 2010
I need instruction manual to program speed dial
I was unable to locate a user manual for that particular device, however the basic instructions for programming speed dial functions are normally very similar between most phones.
Generally there are ONE TOUCH Speed Dial buttons labelled something like M1, M2, and M3 on the dial pad somewhere.
There should also be another button labelled PROG or STORE on the keypad as well.
Normally to program a number into a ONE TOUCH speed dial memory location you carry out the following procedure:
Lift the handset.
Then press the PROG (or STORE) button.
Now just use the number keypad to dial the full telephone number that you want to store in a Speed Dial location.
Once the full telephone number is dialed, then push the M1 button to store that phone number in the M1 One Touch Speed Dial location.
The phone may or may not show some kind of confirmation that the M1 location was just programmed, then just hang up the handset.
Now when you lift the handset and press the M1 button, the phone should automatically dial the phone number you programmed into it.
Now just repeat the same process for the M2 and M3 One Touch Speed Dial buttons with other phone numbers if necessary.
To change one of the Speed Dial numbers, just carry out the normal programming procedure for that location using the new phone number and the old number will simply be overwritten.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Dec 02, 2011 | Southwestern Bell FM-480 Corded Phone
Hi i want to block messages & calls from particular number. i have nokia 5130 c2
Greetings,
In order to block calls from a particular number you need to contact your service provider. You can dial 611 usually. They can put a block on that number for you, just let them know if you are getting harrassing calls, etc.
Thank you.
Apr 13, 2011 | Nokia 5130 Cellular Phone
How do i bar a particular caller from ringing my phone
such services are usually provided by the network operator. u need to contact ur operator if u need to ban certain number.
may networks also issue a dial code which u can dial and ask the op to black that number.
Mar 02, 2011 | Sony W595a Cell Phone
Could you please tell me how to programme numbers into my speed dial as i have lost my manual
hi friend, go inside call setting. there is an option speed dial.then, select a particular number. select option to select contact . which you want to assign in.
then, come back to dial up keypad. and press that number for few sec. then, automatically call is dial to that person.
Regards: Rakesh
Feb 16, 2011 | Cell Phones
Howbto assgn speed dial number
press and hole the key which u want to assign a particular phon num ........then goto setttings->phon settings->contacts->speed dial->on/off
or
goto contacts->settings->speed dial->on/off
Mar 29, 2010 | Nokia 1661 Cell Phone
Panasonic phone
This system will have to be programmed to allow line 1 to ring on that particular set. When you pick up line 1 now and it dials out it is dialing the last number you called from the phone.
May 28, 2009 | Panasonic KX-T7730 Corded Phone
STEPS NEEDED TO PROGRAM SPEED DIAL
For speed dial go to Main Menu >> settings >> initial setup >> Speed dial >> Phone Memory.
Than transfer numbers which you want to assign as speed dial in Phone memory.
Goto particular contact and edit the number and assign it as Speed dial.
May 20, 2009 | Motorola Mobility RAZR V3
Dial Tone but won't call out.
The problem was the main phone line not the phone itself
Jan 07, 2009 | Uniden Cordless Phone
The phone dials numbers by itself i think it needs reprogramming
Blackberry pearl dials phone numbers on it's own.
I've taken out the battery for an extended time and when replaced, starts dialing numbers again.
How do I restart the phone to reset factory specs or what else can I do?
May 08, 2008 | RIM Blackberry 8110 Cellular Phone
RIM BlackBerry Curve 8310 Smartphone Logo
290 people viewed this question
Top RIM Computers & Internet Experts
ismael castillo
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
