Question about LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher
Installation upon installing 24"stainless electronic dishwasher, I don't see how & or any top tabs to attach to under counter top for stadiltion. most diswashers have tabs for wood screws to attach the top of dishwasher to. please advise. theres just thick plastic w/ grooves in it..
  • 3 Answers
Some people put timber off cuts on the top panel to stop the dishwasher tilting forward
Posted on Apr 21, 2008
Dishwasher was not installed but only slid under counter so now it topples over. I have no installation clips
Your dishwasher may have a "side mount" and you may be able to screw it into the sides of the cabinet, if not, you will need to find out how to attach the brackets to your dishwasher (they usually slip into a groove in the top of the dishwasher, bending the tab over once slipped in will prevent it from coming out again.) If the brackets are for another dishwasher, you will need to order the correct brackets for yours.
Oct 07, 2012 | Magic Chef Built-In Dishwasher -...
What are the dimensions?
You are missing a digit in the model number. KitchenAid Dishwashers have a number (0-6) after the SS.
The KUDI01FLSS0 installation guide gives the dimensions of the dishwasher opening and the unit itself on various pages. See http://www.kitchenaid.ca/assets/pdfs/literature/Installation%20Instructions%20-%208524480.pdf . The top vent and the front vent KUDI01FLSS model washers are slightly different. The front vent dishwasher dimensions are 33 7/8" H (with the wheels removed) x 23 7/8" W x 24 7/8" D (including the handle). The top vent model is only 24 1/2" deep. With the wheels in their lowest position, the opening for the dishwasher must be 34 1/2" high (from floor to the bottom of the counter top).
I hope this helps. Other KitchenAid appliance manuals are available here: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD . Use the search box to enter the model number and use the drop down menu to select Consumer.
Aug 14, 2012 | KitchenAid 24 in. KUDI01FLSS Stainless...
What holds the dishwasher under the counter top
There are 2 screws that hold the dishwasher in place. To see the screws open the door all the way. Then bendover and look at the underside of your counter top. You will see the screws on both sides about 3 inches in from the sides.
May 11, 2010 | Bosch 24 in. SHE43C05UC Stainless Steel...
I'm having my kitchen counter tops replaced with granite. I have a GE Model GSD700 dishwasher that is now attached to the existing counter top. The granite counter tops will not accept having a dishwasher...
• Purchase and install the GPF65 side-mount
bracket kit if the underside of counter is granite
or a similar material that will not accept wood
screws. The GPF65 kit is available from authorized
GE appliance dealers.
Also note that any stainless steel tub models would be able to accomadate granite tops without a kit, and I beleive all Profile GE models come with the kit included.
Sep 27, 2009 | Dishwashers
Error code
The unit did not reach it's full fill level after 10 minutes.
Check that water is not siphoning out as quickly as it fills. The drain hose must go up and attach under the counter top or go through a hole in the cabinet at, or near the counter top prior to connecting to the drain under the sink.
Also check that water is coming in at a sufficient level. Check the water shut off under the sink to be in the full open position. The screen in the water valve could be blocked, or the valve itself could be bad. If no water is coming in at all, make sure there is nothing (silverware) under the float. If not, suspect a bad valve.
**Remove power from the appliance prior to attempting any repairs.
May 10, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Maytag model no: dwu8530aax installation
under counter dishwasher installation look under sink is plumbing set up for dishwasher? drain and water supply? if no you need to do some plumbing. if yes you need to supply power- water- drian it just slides under counter and is screwed in with 2 screws in 2 brackets on front top of dishwasher. thank you for useing fixya please rate me if you need more info contact me thank you again
Feb 20, 2009 | Dishwashers
Securing Bosch SHU 4300 under "hard" countertops
If this is a new Bosch Dishwasher then there should be two metal tabs that protrude from the top of the tub above the door. These tabs are for top mounting the dishwasher to a wood countertop, however these tabs also can be relocated to side mount the dishwasher to the cabinetry. The way to do this is to pull the dishwasher out of the hole it is in, in the counter (be careful not to pull too hard or to move the machine out too far due to the length of the water and electric lines). just pull it out easy till you can see the tabs, Now using a pair of pliers, bend the tabs on the backside of the mounts straight so you can remove them from the framing of the dishwasher. Next look at the tabs there should be a perforation where you can use 2 pairs of pliers to snap the tabs off at the perforation, after snapping off these tabs, look at the sides of the dishwasher and you will see a slot where you can reattach the tabs into, and bend the tabs in the back to hold them in place. If you look at the rubber gasket material on both sides of the machine - you can see where the round holes are located for side mounting. Attach the tabs and gently push the machine back into the cabinetry. Now using a small drill bit, drill a pilot hole into both sides of the cabinets to mount the dishwasher. You want to drill these pilot holes so as not to split the counter facing when you drill in the screws. Using the Bosch screws that came with the dishwasher (or small flat phillips screws) slowly screw in the screws into the sides of the cabinetry. When you attempt to remove the machine from the cabinetry you may find that it is adjusted tight to the countertop. If this is the case you will need to remove the 2 screws that hold the kickplate in at the bottom of the dishwasher in the front and remove the kickplate. Then you will need to bring up the front legs on both the left and the right and also the rear leg which is adjusted up and down by using a flat blade screwdriver. Look at the front of the dishwasher, behind the kickplate and there will be a adjusting screw with arrows which point left to right. the direction you turn this screw will determine which way the dishwasher will adjust,- right adjusts the machine higher and left lower. Good luck!!!!!! Hope this helps.
Feb 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Need installation instructions for a Bosch dishwasher with hidden controls, possibly SHX36L 12UC 24-in under counter dishwasher. It comes to me used with no instructions and the usual install makes it...
go to thermador.com to view manuals. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
E 1 error
90% of the time you get an E1 error code is because the drain hose is not properly installed between the LG dishwasher and the drain. The hose should connect to an Air Gap valve (almost free at any hardware store) but in a pinch, raise the drain hose near the drain and attach the hose to the bottom of the counter top under the sink. Is should rise almost 30 inches between the dishwasher and the drain or the water WILL siphon out of the dishwasher as soon as the wash or rinse cycle begins (and take 5 minutes before the water gets low enough the cause the E1 error.
Good Luck!
Nov 21, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Kenmore Dishwasher installation
taking astab at this but your kit floor has been replaced and to close to counter now????, your either shimming up counter or removine the floor from under d/w
Mar 11, 2008 | Whirlpool 24 in. GU1500XT - Multiple Color...
LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher Logo
186 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
