No power when plugged to mains not charging battery
Getting no power to the laptop from adapter have tried other adapter of same make and model apears to be a fault of the internal pick up can this be replaced and how thanks
    Genius:
  • 1,226 Answers
In that case it was proven that the power input to the laptop got an error, however try remove the battery and power it by the laptop adapter and switch on. if the system boot, the battery need to be replaced, but if does not power on, you have to check the power input of the laptop, maybe the fuse in it blown out. You can let the vendor do it for you, or bring it to the service center if you can hardly do the job in fixing it.
that problem require a series of testing. so if you need more information notify me for further solution. melnavz
Posted on Apr 08, 2008
HP dv6000 laptop not charging problem, adapter, battery and power jack looks like it works fine
If your battery, charger, and DC Jack are ok, then the most common problem is the surface mount transistors on your HP's main board called MOSFET's. They are small 30V N channel 8 pin components soldered to the main board. The boards also have transistor circuits which switch back and forth between a charging and discharging state. However these rarely ever fail. The MOSFETS fail because of the thermal loads which they must endure. Although some notebooks (like the Gateway I'm currently on) have a DC jack which serves dual purpose of supplying DC 19V AND connecting/disconnecting charging circuit. However your HP dv6K does not.
However it's worth mentioning that these models have had all sorts of problems...most notably poor thermal design to begin with that usually creates solder connection problems with the main chipset especially on AMD models. Good luck.. :)
Mar 27, 2013 | HP Pavilion DV6500T Notebook
Nc6000 multibay battery does not recharge
Perhaps remove the multi-bay battery, and let main battery charge all the way. Then reattach multi-bay battery, and see if it's recognized.
(Will charge)
That is AC adapter (Charger) removed, then remove multi-bay battery.
Plug AC adapter back into laptop, THEN plug AC adapter into power.
[You do Not want to unplug an AC adapter from a laptop, with the AC adapter plugged into power. Could be a power surge/voltage spike. Unplug AC adapter from power, when plugging into laptop, or unplugging from laptop ]
Main battery charged, unplug power to AC adapter, unplug AC adapter from laptop. Plug multi-bay battery in, then AC adapter.
(Then plug AC adapter into power)
Post back in a Comment.
Regards,
joecoolvette
Feb 28, 2013 | HP Computers & Internet
Dell Vostro Battery charging problems
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Jul 12, 2012 | Dell Vostro V13 Laptop Computer (Intel...
Advent t1600 wont start, it used to start with the mains plugged in was told it was the battery but wont even power up in mains mode now
First try using a different ac adapter/power cord.If after trying that it won't power up it only leaves the power board where the power button is located may be bad or the power jack where the ac adapter/power cord plugs into the laptop may be bad.Alot of the time when the ac adapter/power cord gets weak or stops working at all will cause it to not charge or not turn on even plugged in.
Oct 27, 2011 | Advent Netbook
No turn on notbook compaq 1711t
Hello The mandatory requirements before you try anything else are the main battery must be installed, it must work correctly, and there must be nothing wrong with the AC adapter or it's connection to the laptop. -Your model is recent enough the main battery must be installed - it won't start up on the AC adapter alone. - The main battery must be capable of being charged up to at least a minimal capacity. - The main battery does not last forever. Typically it works as it should for a year or so then begins to deteriorate - by the second year it can't be charged to anywhere near it's rated capacity. It gets worse as time goes by. Older batteries often develop internal shorts that makes it impossible for them to produce the voltage they're supposed to produce (you can test for that with a volt meter), and they may get HOT when you attempt to charge them for a while, rather than a little warm, or they may never get warm at all. - If you haven't replaced it since the computer was new, this model is old enough the main battery should be replaced! There must be nothing wrong with the AC adapter or it's connection to the laptop - if there is, the main battery cannot be charged properly. A common thing people do when they unplug the AC adapter is to pull on the cord rather than the plug on the end of the cord as they are supposed to do. Doing that eventually damages the plug and/or the wiring near the plug, and over a longer period of time, doing that damages the jack in the laptop the plug plugs into. The jack in the laptop should move when you wiggle the plug in the jack. Most laptops have an led that lights up only when the AC adapter is plugged in, there's nothing wrong with the AC adapter or it's connection to the laptop, and the AC adapter is charging the battery. That led should come on at least briefly when you unplug the plug from the AC adapter, then plug it back into the laptop jack, even if the main battery is fully charged. The led should not blink on and off randomlyIwhen you wiggle the plug in the jack. If that led never comes on, there is something wrong with the AC adapter or it's connection to the laptop, or the main battery is shorted (check it's voltage). If that led never goes out even after a long time, the main battery is probably no good - replace the main battery. The plug on the AC adapter cord can be replaced, but if you damaged it by pulling on the cord you will probably continue to do that at least part of the time, so since a plug molded onto the cord stands up to abuse a lot longer than a replacement plug, it's often a better idea to replace the cord from the AC adapter to the laptop if it can be unplugged at the AC adapter (a laptop repair place may stock that), or if that can't be done or you can't find that part, replace the AC adapter. The jack on the laptop can usually be replaced but that requires taking apart the laptop and careful removal and replacement of the jack. A laptop repair place does that sort of thing frequently, and often have the more common jacks in stock, though they may have to order one. Hope this helps, if so do appreciate my effort by rating the solution Good Luck, Cmptrlink
Dec 31, 2010 | Compaq Presario 1711T Notebook
My Advent 7203 wont take charge, the green light on the charger is constant when plugged into mains but when i plug it in to laptopp it goes faint and flashes fast. Also as you plug it in it sparks!
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Sep 07, 2010 | Computers & Internet
Laptop will only work when plugged into the mains, battery will not charge
your battery may be died or discharged comptletely and your power adapter are not charging.
get test the power adapter first, if it is ok, you should buy a new battery then
otherwise you should buy a new power adapter.
Aug 18, 2010 | Dell Inspiron 1525 Notebook
I have a IBM 600x recently installed windows xp sucessfully and today it wont boot up at all it wont acept a charge using the ac adapter apears to have power/the adapter light lights up when not plugged...
Try taking the battery out and just use the AC adaptor.
Does the PC "come on" when you press the power button?
Does it show the animation bar at the bottom of the screen when XP first starts?
Apr 25, 2009 | IBM ThinkPad® 600X (2645-9ZU) PC Notebook
Power plug socket on notebook has failed.
You will have to have a new d/c jack installed on the motherboard. Not a big job, but you might want to have a techie friend do it for you, as it will require some soldering.
Mar 18, 2009 | Computers & Internet
Shuts down
Is this laptop brand new? Because normally, when you plug in the power adapter, the battery charges up to 100% and stays there UNTIL the power adapter is unplugged. Then it will start to run down its power. It's not supposed to run down with the power adapter plugged in. Also, if you take out the battery and only plug in the power adapter, it should work fine. If it doesn't, then there's a problem with the adapter.
Apr 02, 2007 | Toshiba Satellite P30 Notebook
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
