Question about Canon Pixma MP500 All-In-One InkJet Printer
Ink Problems. is only printing with yellow ink
Put in new ink cartdriges and than went to print but now it is only printing with the yellow ink. none of the other colors are printing even when we do a nozzel check or a deep cleaning only yellow shows.
how can you fix this.
    Sergeant:
  • 284 Answers
You may need to replace the Print Head or Purge Unit.
Posted on May 30, 2010
How can I fix my ink problem?
It is possible the ink carriage and print head are very dirty and needs servicing.
Aug 25, 2014 | Brother LC51BK Print cartridge, Inkjet...
Will not print, gives error oxco5do281, ink problem
Paper jam would not be related to ink problem. printers sense ink via photo cells or magnetic sensers. paper path is mechanical. It sounds that your cartridge is not fully in position, for whatever reason. Hp Printers are better at accepting refill cartdriges than some. But has to be done correctly. But feed problems, are mechanical.
Dec 02, 2013 | HP Photosmart 3210 Printer
Have put new cartridges in and only prints yellow lines
Remove all cartridges, make sure any tape has been removed from over the nozzle. Ensure that everything has been installed properly, then use your printer (prompts on device, or in printer>control panel) to print some test pages, realign heads, etc.
May 05, 2011 | Canon Computers & Internet
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
My mfc-240c won't print red, even with a new cartdrige.
Try running a few cleanings on the color.
Press the ink button and select cleaning,, do about five cleanings. Print the ink quality test page (from the ink button as well) and see the quality if it improved.
If it still doesnt print its possible the ink is clogged and may need servicing to replace the printer head
Apr 06, 2010 | Brother MFC 240C All-In-One InkJet Printer
My black ink ran out so I replaced the ink
Hi:
I have used the printer series that you have for years, and once in awhile, I get a new cartridge that won't immediately print. Often, there is just a bit of dried ink residue on the print head, and that won't allow the cartridge to work correctly.
Some simple things to try are :
1) Remove the black cartridge. and take a damp paper towel and gently swab the print head area. Next, apply some pressure to the sides of the black cartridge, until you see black ink oozing out of the print head. Repeat if needed. Once the ink starts flowing, blot off the excess, and install the cartridge.
If you can't get ink to flow, then the cartridge might be bad. Most of them have an expiration date on the packaging.
Mar 31, 2010 | HP DeskJet 960c InkJet Printer
I have just replaced the color ink cartdrige in my HP Deskjet 722c printer and I tried to print a color picture in bond paper and it was a total mess
A new ink needs a little cleaning before using. Just dab lightly on a damp paper towel and look for a inch log stripe of each color on the towel. If all colors are not there it won't print very well and you should return the cartridge. Some have reported no yellow in their new cartridges.
Jan 08, 2010 | HP DeskJet 722c InkJet Printer
Print Head Problems??
The ink cartridges on your Canon Pixma MP500
print head not problem your yellow cartridge &black
problem
Oct 07, 2009 | Canon Pixma MP500 All-In-One InkJet...
Brother dcp-120 c printing problems
I have put new ink cartridges into the machine and I get an error message... yellow and red are empty . It will not print either.
May 16, 2009 | Brother DCP-120C All-In-One InkJet Printer
Color doesn't print before and after printhead replacment.
No, its not possible. The problem is likely the ink has dried in the purge unit or one of the small tubes going to the waste pad. The new printhead is the fix for the ERROR 41. The problem is there is sometimes other things that go bad, purge unit being just one example. One of the biggest problems with inkjets is that consumers leave their printers alone for long periods of time and the ink dries and clogs the tiny hoses inside. Even the ink cartdriges are just ink tanks, I have replaced those many times and have seen bad ones that just won't flow, replaced the inks and it works fine. You also have to put in the id# for the printhead after you replace it. Did you do that or get the instructions?
Sep 28, 2006 | Brother MFC-3220C Plain Paper Inkjet Fax
Canon Pixma MP500 All-In-One InkJet Printer Logo
254 people viewed this question
old marine
old marine
