Question about Whirlpool Refrigerators
I can't get the water filter out of my Whirlpool gold side by side. Help
    Novelist:
  • 77 Answers
The water filter should be at the bottom of the refrigerator. You don't even have to open the doors.
You will either have a push button filter or a twist filter. I will walk you through the twist filter first.
At the bottom of the front of the frig, you will see a turn handle. This is the filter. What you need to do is turn the handle a quarter turn (90 degrees) counter clockwise. This will release the filter. Simply pull it out. the handle will slide off the front (this is what you were using to turn the filter). You must keep this and put it on the new filter in the same fashion.
The push button filter is in the same spot, only instead of turning it you push the button and it should pop out. Pull it out and save the cap! The cap goes on the new filter you install.
If you have located the filter but are having actual difficulties removing it because it is stuck, the only advice i have is be careful not to hurt your fingers! Applying slow pressure in a pulling fashion will generally relieve it. If I can be of further assistance let me know!
These filter generally cost between $35 and $40 at your local retailer.
Posted on May 30, 2010
SOURCE: whirlpool side by side water dispenser not working
I had the same problem and it appear the cable set between the freezer door and refrigerator body has some wires broken. The cable is in the bottom right hinge. You can try moving the cable with fingers at the same time you're pushing the water lever.
While this is not going to be a permanent fix, at least it confirm where the problem is.
Posted on Nov 28, 2007
ghappliances
  • 126 Answers
SOURCE: Whirlpool gold Conquest side by side refrigerator-- water dispenser doesn't work but ice dispenser does.
WHAT IS THE PROBLEM WITH YOUR FRIDGE
MOHAMED
Posted on Sep 20, 2008
  • 37 Answers
SOURCE: Removing the water filter and not replacing
Not with out re plumbing the unit underneath, it would be much easier to leave it in place.
Posted on Jan 03, 2009
peyton32034
  • 410 Answers
SOURCE: Whirlpool Gold Side by Side Refrigerator
sounds like the switch tabs are broken off of the switch bracket behind the dispenser front cover. you should hear a distinct click when you oush in on either lever for ice or water if not then that bracket is broken.  if you'll look on the very bottom of disp cover you will see 2 slots insert a small flat blade screw driver and pry the cover off then you'll see a white bracket with switches and wiring on it look at the black switches and most likely the little plastic posts that hold them on are broken. the bracket is inexpensive and very easy to repalace. if you have any urhter questions just ask thanks peyton...
Posted on Jan 22, 2009
dblred
  • 68 Answers
SOURCE: Water Filter
most whirlpools have the filter located in the bottom kickplate, right below the freezer door. turn counter-clockwise and toward you to remove. if it has never been removed before, they are hard to get out the first time.
Posted on Jul 24, 2009
Chemcial taste in water after changing water filter
Well this never happens with me but surely you might get some unusual result.
Chlorinated Solvents Exporters
Sep 12, 2012 | Whirlpool Gold GSS26C4XXB 26.4 cu. ft....
I have a whirlpool gold refrigerator. The ice
I just want to know if you solved your problem because I have the same problem.
Thanks
Oct 26, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
The water lines from the filter housing leak at the solenoid and are dripping at the filter. It is a Whirlpool gold series side by side
you should be able to push in the ring around the tube at the same time pull the tube out
cut about 1/4 in off and push it back into the hose clip
unless your line is craked this should work for most drip leaks
Oct 24, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Removal of water filter; Whirlpool Gold Side by side model GC3NHAXVY01
Turn the filter CCW and pull out. (water can stay on) remove knob from filter and put it on the new one. Insert the filter and turn CW to lock in place.
Eric
Oct 15, 2009 | Whirlpool Refrigerators
Water Filter
Jul 24, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Where is the release button for the whirlpool gold conquest water filter?
your filter either has a release button directly next to the filter within the kickplate. teardrop shaped button you push, or the only other filter hpusing requires that you twist teh filter out by turning counterclokwise it to is located within the kickplate under the refrig door
Mar 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Jan 02, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
642 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
