Question about Sevylor 48 in Inflatable River Tube
Air pressures for a sevylor colorado kcc335g
I have bought a sevylor colorado kcc335g inflatable canoe. Can someone tell me what the max air pressures are for the side and floor air chambers?
Thanks, Clive
3 Suggested Answers
SOURCE: I have a cut 2-3in.
alrigth, for fast repair, i would use tuck tape( the red one) if you d'ont have anything else. you can also use an old bike tire tube, cut it open and take the piece you need to cover the entire cut and a little more. you want to use contact glue to make it work, to use the glue, put the glue on each pieces on the side you want to glue together. wait for about five minute(let it dry) in the meanwhile ,put the tube (the part that has the cut) on something flat, put the two covered glue surfaces together, put someting flat on top of it (just like a big sandwich) and put some wheigth on top of that, wait for 30 min and it should be repaired
Posted on May 19, 2011
SOURCE: I have a Sevylor Tahitik
up front under the spray shield on the sides of the main side tubes, you will see them pump yhe floor first and that will open the sides to get at the valves. mine are black Boston valves ,
Posted on Jul 27, 2011
Sevylor st5656 what air presure should be in it
The ST5656 is a low pressure hull, so shouldn't be inflated to more than 1 psi, or about as firm as a ripe grapefruit. If you leave it out in the sun you need to let some air out or the air inside will expand and it will blow up
Apr 04, 2013 | Stearns SEVYLOR Sit on Top Kayak U250
What is the air pressure or psi for a schwinn bicycle called discovery 700c
All tires have the maximum inflation pressure molded into the sidewall.Try inflating to about 5psi below the max as a start.(My 26" tires are "MAX INFLATION PRESSURE 65PSI",I like it at about 50psi.
Sep 17, 2012 | Pacific International Mens Schwinn 700C...
SEVYLOR PULLS TO ONE SIDE
Practice your paddling. Seriously.
I know someone who cannot paddle a kayak in a straight line because she puts more power on one side than the other and cannot seem to learn how to even it out.
    Jul 04, 2011 | Sevylor 1-Person Sit-On-Top Inflatable...
    WHERE IS THE AIR NOZZLE TO FILL THE SEVYLOR FLYING MANTA RAY LOCATED
    All the Sevylor tubes have a valve that comes apart in to two pieces, remove the top and you can fill remove the hole thing releases the air. You need a 12 volts high volume low pressure pump with connectors, 20 bucks in Overtons. Fill it till it is stiff, put it in the water let the air cool down inside then hand fill it with the connector and human breath to stiff it up again.
    Sep 07, 2010 | Sevylor 48 in Inflatable River Tube
    I;ve got a hole in the bottom of my Sevelor Colorado, is there any way to fix it? other than going to someone who can vulcanise the hole.
    Depending on the material type, a standard bike tyre tube rewpair kit may work very well! Just follow the instructions int he repair kit and see how you go. At any rate you are not going to cause any more damage than what is already there and there is a good chance the bike tyre tube repair kit will repair the hole (assuming it is not too large of course)
    Mar 30, 2010 | Sevylor 48 in Inflatable River Tube
    Sevylor motor mount instructions
    I dont believe a motor will mount to it. Sorry!
    Sep 30, 2009 | Sevylor 48 in Inflatable River Tube
    Sevylor river xk2 does not track well on still water
    This inflatable kayak is meant to turn to facilitate maneuverability in whitewater; it needs to turn.
    Try attaching piece of plastic as a skeg, perhaps the skeg from the Sevylor Tahiti will suffice (or a piece of lucite or a plastic cutting board). A skeg makes a boat track straight.
    My Sevylor Colorado came with an optional skeg which I only attach on flatwater (never whitewater).
    Aug 14, 2009 | Sevylor Inflatable River Xk2 Kayak
    Infatable canoe
    Inflatable canoes have considerable appeal for certain uses. When folded they are quite compact and their weight - about twenty to thirty pounds - makes them ideal for toting to remote fishing waters or for storage in today's small car trunks. The better-quality versions are made of heavy-duty vinyl-coated polyester, or PVC, with multiple air compartments (so if one compartment springs a leak, you still have some flotation). Restrictions include speed, since inflatables are relatively slow, and they have minimal carrying capacity. Repair kits are a must on most trips. Also, you will want to have a foot pump to inflate the canoe before starting out.
    Dec 01, 2008 | 3M SportsStuff Speedzone 3 Inflatable...
    Sevylor 48 in Inflatable River Tube Logo
    377 people viewed this question
    Top Sevylor Sport & Outdoor - Others Experts
    Bill Eager
    Are you a Sevylor Sport and Outdoor - Other Expert? Answer questions, earn points and help others
