Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool dryer wont start
Whirlpool duet dryer wont start
not the door switch
not the thermal fuse
electronic controls tested ok
  • Whirlpool Master
  • 1,525 Answers
Hello theres a long pin that sits inside the door make sure it has not snaped off if thats ok then the trouble may be caused by the capacitor next to the motor white cyilnder with couple of wires coming off
regards
shaun
Posted on May 30, 2010
I have a whirlpool duet gas dryer model ggw9200lw1. when i press the start button it clicks once but wont run.
First, check the door switch. Push and release it by hand and you should hear a click. If no sound, replace the door switch with this part.
If the switch is ok, press the cancel button on the machine. Then do this. press and hold the start button for 2 seconds then release wait 2 seconds and press and hold again for 2 seconds continue this pattern until the dryer goes into test mode. You will see all the lights on the control light up. press each button on the control one at a time 3 times each. (Do not press the cancel button) until the dryer begins to run. When the dryer starts to run then press the cancel button. Then your machine should function properly.
Oct 19, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool duet gas dryer is not working. The lights on the control panel are on. My husband has replaced the thermal fuse, thermistor and the motor. Still will not run. Please help.
check the door switch,if this switch is bad dryer wont work,this is a spdt type switch as it runs the drum light when doors open and lets machine start and operate with door closed
May 06, 2012 | Whirlpool Dryers
Dryer has power but wont start
Hello there and welcome to fixya
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. To determine if the door switch has failed, watch the part testing video at the bottom of this page. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.) To determine if the thermal fuse has blown out,
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Apr 05, 2012 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Dryer wont start when button is pushed.the thermal fuse was tested (good) the high limit thermostat was replaced as with the thermal cutoff. I did notice an abnormality on the cap of the electronic control
Did you check the door switch? Electronic control could be an issue but start with the basics and you have covered most of them already... good job.
Eric
Jun 12, 2010 | Kenmore 66862 Dryer
Whirlpool dryer LER5636PQ0 push to start keeps failing to work
You could have a worn door switch . Push in on the plastic piece which closing the door actuates and press the start botton . If it starts ,several times , then replace the door switch . Pt # 3406107 . Do this after you put the 2 thermal fuse (slim white piece with 2 wires attached )wires togather for testing purposes only . BE sure to unplug dryer before doing ANY repair testing first ! If it starts by jumping the wires , then pt # 3392519 fot thermal fuse .
Jul 14, 2009 | Whirlpool Dryers
Dryer does not start - Thermal Fuse is ok.
Good to know, when the appliance does not start at all is always thermal fuse, wiring, door lock switch, or rarely the control assembly.
Have a nice day.
Jan 02, 2009 | Maytag PYE2300AY Electric Dryer
Whirlpool Dryer wont start
Possible door s/w or thermal fuse. If its blowing thermal fuses with a clean and avg vent run check the relay, cycle unit with no heat fuction if the heat still comes on replace the relay board. Call your local servicer.
Mar 16, 2008 | Dryers
Whirlpool Duet GHW9150P Front Load Washer Logo
314 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
