Question about HP Office Equipment & Supplies
0xc18a0206 hp photosmart 3210 all in one error 0xc18a0206
  • 104 Answers
SOURCE: Ink System has failied. Error 0xc18a0206 on HP
Press *(star) and # (hash) together on the printer and let go.
Key 1 then2 then3
Press the right arrow key until the onscreen menu shows System Configuration
Press OK
Press right arrow key until failure status is displayed
OK again
I think there was another OK after this but not sure????
Keep pressing cancel til you get back to the main menu then
Unplug from power for 1 minute then plug back in
Power back on.
Posted on Mar 07, 2011
SOURCE: 0xc18a0206 error on hp photosmart printer
0xc18a0206
C7183 ALL IN ONE
Posted on Oct 23, 2008
SOURCE: HP Photosmart 3210 Printer will not scan any
I had the same problem and this is what I did to fix it.
Go to control panel
choose printers
look to left and find scanners and cameras
click scanner
a pop up should direct you to scanning options and will lead your scanner to scan the item
hope this helps
Posted on May 11, 2009
don_farr
  • 1011 Answers
SOURCE: hp 8250 ERROR 0xc18a0206
Peggy,
This is an ink cartridge problem.
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Posted on Nov 19, 2009
mace1mace
  • 1138 Answers
SOURCE: When I am printer Hp 3210 Messe error like this
here.. check this out. a solution to your problem.
These are reset instructions designed to clear most of hp errors starting with 0xc...It works on different hp models.. it could work on you too.
Semi reset
1. While your printer is on.. unplug to power cable from the printer.
2. Press and hold the "OK" and "HELP" buttons while you plug the power cable at the back of the printer. Try these steps to reset your printer to default setting.
Full reset
1. Press & hold " * " key...(asterisk sign)
2. While holding the " * ", press "#" key and then release both keys..."Enter Special Key Combo" will be displayed...
3. Press "1", "2" and "3" to display Support...
4 Press ">" right arrow button and release when System Config Menu appear....then click OK
5. Press arrow key to display Hardware Failure Status...click OK....
6. When Hardware Failure Status:Clear appeared, press "OK" to clear...
7. Press "OK" again to display "Hardware Failure Status Cleared. Press Cancel To Continue".....
8. Press "CANCEL" as many times to display "Welcome To Photosmart Express" or "Ink System Failure".....
9. The last part is to turn off the printer and unplug at the back...wait for 30 sec, then plug and turn on the printer...if asked, press "OK" to continue and allow the "One Time Ink Initialization" to proceed..After this try to print...
If you find the reset solutions helpful...Please rate this solution and vote YES ..thanks..
Posted on Aug 21, 2010
How can i resolve an hp 3210 error 0xc18a0206?.
try this it worked for me unplug power cord from printer and electrical outlet wait 30 seconds hold in help and ok buttons while reconnecting power cord. continue holding buttons until screen turns black turn printer on and continue this helped me
Apr 25, 2016 | HP Photosmart 3210 All-in-One Printer...
Ink system failure error: 0xc18a0007
Look for your specific error. Click the link for reset if your error is not found:
HP Photosmart 3210 Ink System Error
Failing this, your 3210 may require repair service.
I hope you found this document helpful.
Dec 28, 2009 | HP Photosmart 3210 Printer
HP Photosmart 3210 (all-in-one) Ink system failed error : 0xc18a0401
Hi ok I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 09, 2009 | HP Photosmart 3210 All-In-One InkJet...
Error code 0xc18a0001 HP Photosmart 3210 All in One
Hi I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
5. Wait 60 seconds.
Oct 15, 2009 | HP Photosmart 3210 Printer
Hello, my HP 3210 printer has an ink system failure...error: 0xc18a0206 , i have followed almost every possible solution on the net...replacing ink cartridges, re-installing drivers and programs, unplug...
Follow steps below to reset Hewlett-Packard (HP) All-in-one Printer. Resetting your printer will reset your printer to its original state.
1. Without turning the unit off, unplug the power cord from the back of the product.
2. Press and hold “# and 6′ keys.
3. While holding those keys plug the power cord back in.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.
** Give me your feed back
Oct 02, 2009 | HP Photosmart 3210 Printer
My printer says ink system has failed. Refer to
My HP Photosmart c5183
printer says ink system has failed. Refer to printer documentation. Error: 0xc18a0406. Please help.
Sep 24, 2009 | HP Photosmart 3210 Printer
258 people viewed this question
Seeker5211
Seeker5211
