Question about ElectroVoice EV Rider FTCA020 Caddy Fold N Drive Mobility Scooter - Metallic Blue
I AM LOOKING FOR A BATTERY CASE REPLACEMENT FOR MY MOTHER'S SCOOTER? ANY LEADS ON A GOOD SOURCE? THANKS IN ADVANCE.
  • 3 Answers
Brighter future workshop. a charity organisation that sells second hand parts
Posted on Jun 17, 2010
Electric Mobility: Replacement scooter charger
Rob, If need be, possible you can adapt you old chargers connector onto new charger if not the same plug. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
24 Volt 4 0 Amp On Board Battery Charger for Rascal Scooters and Power...
RASCAL 600 600t HANDICAP MOBILITY SCOOTER PRISM 24V BATTERY CHARGER...
Aug 17, 2016 | Electric Health & Beauty
CHARGER GREEN LIGHT FLASHES ALWAYS EVEN WHEN NOT PLUGGED INTO BATTERIE ALSO ONLY LASTS ABOUT 1 HR ON SCOOTER GOES FROM GREEN TO RED IN NO TIME
Battery Not Holding a Charge
Mobility scooter batteries can encounter problems, as over time, these batteries age and lose some of their effectiveness, until eventually they stop working completely. In this case, battery replacement represents the only thing that owners can do to fix the problem. Before doing so, however, they should perform some other troubleshooting measures to make sure. For collapsible scooters, seat the battery properly when unfolding the scooter for use. Owners should also make sure to properly connect the battery, while also looking for any error messages or flashing lights displayed on the scooter's dashboard.
5 Troubleshooting Tips for Mobility Scooters
http://www.travelscoot.com/battery-information.html
http://www.travelscoot.com/contact-us.html
Dec 01, 2015 | Travel Scoot Travel Mobility Scooter -...
I am looking for a pdf manual for a Rascal scooter model 500. My mother bought one used and never got a manual with it.
http://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CCEQFjAA&url=http%3A%2F%2Fwww.scootaround.com%2Ffiles%2Fmanuals%2Felectricmobility%2FElectric%2520Mobility%2520Rascal%2520R200%2C%2520R500%2520Owner%27s%2520Manual.pdf&ei=a9RgVJrPJoyrgwTs4IHwCA&usg=AFQjCNF0I3DUiwsiLEW5iM_ua6QISpNCSg&bvm=bv.79189006,d.eXY&cad=rja
Nov 10, 2014 | Health & Beauty
Looking for a bladez DKS200 mobility scooter battery case?
http://www.bladezscooters.com/
http://www.monsterscooterparts.com/
Unlikely some other manufacturer's box will fit, if only because the circuit connecter is built into the pack.
May 03, 2012 | Health & Beauty
How do I replace the battery?
to replace the batteries in your Go-Go you need to remove the battery case from the scooter and turn it upside down . as you use an AGM gel battery you will not spill any thing i change mine out every 400 charge cycle as they are good for about that long. on the bottom of the case you will find 8 screws you need to take out to open the case you will need a 6 to 8 inch long Philips screw driver for this. after you remove all the screws you need to turn the box up right and remove the top.inside you will find 2 batteries. you will need to replace both batteries to ensure the full 24 volt to power the scooter. yes you use any AGM gel battery.i get mine at batteries plus as it cost about half the price.
carefully using 2 wrenches loosen and remove the small bolts and nuts holding the cables leads to the batteries' terminals, there should be 2 black and 2 red. now either draw how they attached to the positive and negative terminals or mark them in some manner.The batteries have two velcro strips on the bottom of each battery. remove the strips and place in the same position on the new batteries now place the new batteries in the box and press down firmly to seat the velcro, attach the cable leads to the proper terminal, replace the top and turn box upside down and replace the screws. now the batteries are ready to charge up so you can do as i do... race like at speed demon around in circles... happy scooting
Aug 29, 2011 | Pride Go-Go Elite Traveller Plus HD...
Freerider Ascot Electric Mobility Scooter (4 wheel) Battery charges and holds current - horn works and shows green on power dial Scooter hardly moves underload - the engaged lever is set correctly. I...
I would suspect the brake is not releasing correctly and dragging on the motor housing. Try driving the scooter a short distance and feel the motor case at the rear near the brake assembly if it is very warm or hot the the brake is sticking and will have to be replaced. Hope this helps
Jun 03, 2011 | Health & Beauty
CRT Scooter just quit working and doesn't accept battery charge.
Hi. There is often an in-line fuse for the voltage to run the controller. Often the charger feed goes through this fuse. Check the fuses. Sometimes the fuse is OK, but the contacts in the fuse holder are faulty. Also check the battery connectors, and where the battery leads are fixed to the batteries.
I have removed many connectors from battery leads and connected the leads to the batteries without in-line connectors.
Good luck. Neil.
Jun 01, 2010 | Drive Medical BLUE 3 Wheel Compact Mini...
Scooter wont start. will start with jump leads
the battery earth to the bikes chasy may be dirty check all battery leads are clean and tight plus any to the frame,,,
Mar 18, 2010 | 2008 Yamaha Yamaha G5
Spare parts
I sell parts on ebay periodically.
My ID id campiaturzii2003.
Aug 25, 2008 | Sony Playstation 3 (PS3) Console
ElectroVoice EV Rider FTCA020 Caddy Fold N Drive Mobility Scooter - Metallic Blue Logo
123 people viewed this question
Top ElectroVoice Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an ElectroVoice Health and Beauty Expert? Answer questions, earn points and help others
