Question about Schleich Horse Trailer by
Where is the data plate located on a two-horse-trailer
Where is the data plate located on a two-horse trailer,made in 1970's,brake on rear axle,we called bumper hitch,with a smaller size tires back axle,with a center divider bar&seperated by a board seperater,the escape door is in the front,to get to the horses,can't find the data plate,VIN no.or a name brand either,tell me something, please ,these trailers were popular in the 70's,when everyone was showing horses,on the weekend's,this seem's to be a little narrow,for two horses.
I forgot that was a while back,so couch-potatoes,would not remember what all that's from nowaday's,huh??
Tip
Trailer Wiring Problems?
Hello all,
For those of you that need to wire up a trailer or have to occasionally borrow trailers and look at the wiring plugs with disdain (I mean face it they don't make sense, ground is white, +12vdc is black, etc), this is for you.
Plug Types/Application
7 Way - RV Trailers, Horse and Utility Trailers
6 Way - Horse, Stock and Utility
4 Way - Utility Trailers
Columns are: Color, Function, Mark on the plug.
Seven wire Trailer plugs:
Horse, stock or utility trailers:
White = Ground - 1
Blue = Electric Brakes - 2
Brown = Tail and clearance lights - 3
Black = Battery, aux power - 4
Yellow = Left turn/Brake - 5
Green = Right turn Brake - 6
Orange or Purple (not both) = Auxilliary or Reverse - 7
Recreational Vehicle:
White = Ground - 1
Blue = Electric2_bing.gif Brakes - 2
Green = Tail and clearance lights - 3
Red = Left turn/Brake - 5
Brown = Right turn Brake - 6
Yellow = Auxilliary or Reverse - 7
Six wire trailer plugs:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery2_bing.gif, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Four wire plugs:
White = Ground
Ground should be 10ga.
Others 14 ga
A test light and a 12VDC power source can be handy for trouble shooting.
Best regards
Mike
on May 16, 2010 | Toyota 4Runner Cars & Trucks
What size brakes for a 2000 exiss 3 horse trailer?
trailers are made from what ever parts are available at the time. Best suggestion is to take the linings/pads off a wheel and visit a local brake shop for identification
Nov 16, 2014 | Cars & Trucks
Rear differential how to pull axles
you have to remove the four bolts in the brake back plate ,then remove the rear cover on the diff ,then strip the planet gears ,then on the end of the half shaft is a horse shoe shape clip ,pull this out then the half shaft comes out
Nov 10, 2010 | 2000 Jeep Grand Cherokee
Tip
Trailer Wiring
Hello all,
For those of you that need to wire up a trailer or have to occasionally borrow trailers and look at the wiring plugs with disdain (I mean face it they don't make sense, grd is white, +12vdc is black, etc), this is for you.
White = Ground - 1
White = Ground - 1
White = Ground - GD
Red or Black (not both) = Battery, aux power - A
White = Ground - GD
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
on Jan 09, 2010 | Cadillac Escalade Cars & Trucks
Tip
Trailer Wiring 101
Hello all,
White = Ground - 1
White = Ground - 1
White = Ground - GD
White = Ground - GD
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
on Jan 09, 2010 | Dodge Ram 1500 Cars & Trucks
Rear axle bearings
There are 4 bolts for each rear axle. They are located behind the rear brake drums. Remove e-brake cable from rear drum and take off brake line.(carefully). I recomend draining and changing your rear differential fluid too, because if the fluid by run out of axle housing. also you should replace the seals for the axles of if you are changing the bearings. When you are done don't forget to bleed your brakes, and hooking up e-brake cable. I hope this answers your question.
Jan 28, 2009 | 1986 Toyota Pickup 4WD
Tip
Trailer Wiring Cheat Sheet
Hello all,
For those of you that have or occasionally borrow trailers and look at the wiring plugs with disdain (I mean face it they don't make sense, grd is white, +12vdc is black, etc), this is for you.
White = Ground - 1
White = Ground - 1
White = Ground - GD
White = Ground - GD
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
on Sep 23, 2009 | 1998 Ford Explorer
Tip
Hello all,
White = Ground - 1
White = Ground - 1
White = Ground - GD
White = Ground - GD
Yellow = Not used -
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
on Sep 19, 2009 | 1987 Jeep Wrangler
Tip
Trailer Wiring Standards (Color Codes/Plug Marks)
Hello all,
For those of you that have or occasionally borrow trailers and look at the wiring plugs with disdain (I mean face it they don't make sense, ground is white, +12vdc is black, etc), this is for you.
This will show you how to wire trailers with seven, six and four pin connectors
Seven wire Trailer plugs (Large trailers with a battery and electric brakes):
White = Ground - 1
White = Ground - 1
White = Ground - GD
White = Ground - GD
Yellow = Not used -
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
on Sep 09, 2009 | 2004 Dodge Ram 2500
Tip
Hello all,
Columns are Color, Function, Mark on the plug.
White = Ground - 1
White = Ground - 1
White = Ground - GD
White = Ground - GD
Yellow = Not used -
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
on Sep 09, 2009 | 1981 Ford F 150
Schleich Horse Trailer by Logo
109 people viewed this question
Top Schleich Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Schleich Toy Expert? Answer questions, earn points and help others
