I get the message 'error loading operating system' everytime i start my computer, when i do start it it says to press DEL for setup, when i press this a blue screen appears and a passwod box appears in red in the middle but no one knows the password could you please help me
    Novelist:
  • 125 Answers
The Setup option is for your BIOS , heres a link to resetting the BIOS password if you want to access it.
but as for the error loading operating system you will need any setup disks or recovery CD's that you got with your computer, preferably a Windows Installation CD , then you will have to insert the CD restart and let the computer boot from the CD and reinstall your operating system.
Posted on Apr 08, 2008
D800 cannot change boot order
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart This will set the boot order If this fails you might try some of these Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Feb 05, 2013 | Dell Latitude D800 Notebook
I have a Compaq Presario f700 running Windows 7 64bit. It freezes up at bootup, unless at the Compaq screen I press the [DEL] button to view the start-up sequence message. Why? How can I fix it?
if this fails to fix the problem
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell what file has been corrupted or missing you might be able to work your way through problem if you are unable to find a solution
restart back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time
click start all programs accessories system tools you should see your system restore option
hope this helps
May 17, 2012 | Compaq Computers & Internet
Screen says" Loading PBR for descriptor
And again and again and drives you up the wall.OK-boot sector is corrupted, or hard drive is going south.What you can try is system restore.On boot see which button is designated for that-usually f10 or f12.Start tapping that button and follow instructions. If that failed, the only option is to reinstall OS.If you have a lot of stuff that you want to save, install Windows in different folder, say WindowsA.All your stuff will be saved on the Hard drive-My Documents.Good luck and keep us posted.
Jun 14, 2011 | Computers & Internet
What will i do if this message appear on the screen of my computer everytime i attempt to open it : Reboot and select proper device or insert boot media in selected boot device and press a key.
I dont know if youre are familar with bios settings, nut every time you start
the computer, you can press esc or del or something to load the bios. in the bios you can select the boot device. set it to harddisk.
Apr 19, 2010 | Microsoft Windows XP Professional for PC
I would like reset the password of my d33005 motherboard
Go into the BIOS setup to reset the password. Start by rebooting the system. Before the system starts loading the operating system, the computer will give an opportunity to enter the BIOS setup utility. Usually a screen appears saying to press a key to enter the setup utility; i.e. "Hit DEL to enter Setup". You have to know what key the computer is looking for to get to Setup. DEL in used on the a lot of ASUS machines but you may that to refer to a manual or read the screen just before the operating systems to load. Once you get in, look for something related to security settings. Once it is found under the boot tab. Here is where you can reset the motherboard password. Hope this helps.
Dec 15, 2009 | ASUS Computers & Internet
When switching on laptop. message appears A disk read error occurred. Press ctrl+alt+del to restart. When done this nothing happens. please help.
This usually happens when the operating system is not being read from the harddisk or it is corrupted.
Do one of the following Go the BIOS (Press Del at start up or may be another,it depends on the Motherboard)and in the exit select Load Setup Defaults and exit...select Yes when Prompted.
If this doesn't help press F8,F6 or whatever it is according to your motherboard on start up...and it will direct you to the boot options where you can select 'Last known good Configuration'.
Try and remove any other external devices attached (like pen drive and printer etc.) and then reboot.
Lastly you can install the Operating System again,keep *********** board drivers handy.
Hope it helped...
Nov 22, 2009 | Compaq Presario Notebook
C640 can't boot up
Ok.Better reinstall the os.Because disk boot error cannot be solved is suppose...To install the os follow these steps.
Step 1:Power on your system and press DEL key
You will see a blue screen with some options on it in white. (you can only use your keyboard to navigate in this screen). Go to the Advanced Setup Options ---> then select Boot Priority ---> 1st Boot device to be Floppy drive , 2nd Boot device to be CD-Rom drive
Step 2:Insert the Bootable DOS floppy in your Floppy Drive. Press F10 to save the bios settings and exit. (Your system will re-start automatically)
Step 3: Let the Dos load from the floppy and A: shows up.
Step 4: Change the Command prompt to HDD Drive letter, it will be D: or E in which u have Xp cd contenet.And type If xp content in d:under x folder mean.D:cd\x and press enter.
Step 5: now type on the D:\ prompt -- setup.exe and press enter
Step 6: follow the prompts there after. and for more info contact http://tinyurl.com/m7ghqz
Jun 19, 2009 | Dell Latitude C640 Notebook
Bios checksum error. How to solve it?
If you are using an old computer, there’s a possibility that you already encountered this error message during bootup; “CMOS checksum error – Defaults loaded”. At this point, the PC will halt its operation and requires you to press F1 to continue or DEL to enter setup (mostly but also depends on motherboard) to proceed.
This is caused by incorrect or corrupted CMOS values. BIOS settings are stored in CMOS. Each time the system is booted this number is recomputed and checked against the stored value. If they do not match, the error message will be displayed.
For most cases, this is caused by the motherboard battery. Buy a new one to any electronic retailers in your area and replace it. Turn on your computer and press the stated key to enter the BIOS setup. It can be DEL for some or F2 but this depends on your computer. On the BIOS menu, try to change the DATE and TIME settings because their values are reset to different value. Most settings are set to default so leave it as it is. Save the settings and reboot your computer.
Oct 04, 2008 | MSI PM8M-V Motherboard
Error loading operating system
Firstly have you set your jumpers on your hard drive setting before placing into computer. If not check if the cd rom is on the same cable, if on same cable then change the jumper.
Have you gone into bios and loaded the hard drive. If a new hard drive you will need to detect it in bios first. Then Save and exit.
To go into bios, press f1 or f2 or DEL when you first start computer. Each computer is differentand you'll have to see which you require to press.
After bios is setup, put in your copy of windows xp, or your boot disks and follow instructions to set partition and format drive, then install operating system.
If you are only installing a new secondary drive as a backup, you will still need to detect in bios first. Then load you windows and go to my computer and format the drive using windows.
Aug 05, 2008 | Computers & Internet
Asus P4B Motherboard
Press DEL to enter setup and set Reset to Defaults in Exit menu. If you have USB keyboard, make sure you enable Legacy USB and USB keyboard settings, save and exit and reboot.
Aug 04, 2008 | Computers & Internet
Computers & Internet Logo
134 people viewed this question
David Payne
David Payne
