Question about Zanussi ZEBF262W Bottom Freezer Refrigerator
Pool of water from freezer.
I have a Zanussi ZEBF 262W. Works fine, had it for about 4 years but lately I find first thing in the morning, a small pool of water on the ground near the left front side of the freezer - only about 1/4 cupfull. Not sure where it's coming from - obviously from the Zanussi somewhere. Any thoughts? Thanks
  • Kevin E Jun 09, 2008
    Found little nozzle at back (over plastic tray above motor) was blocked. This had caused ice to build up inside. Removed inside cover (6 screws) as you said, gave it a darn good clean out and defrosting. Used pipe cleaner on flow away tube. Now water can flow away again. Fingers crossed! Thanks for your advice!
The likely cause is the drainage outlet is blocked by dirt deposits or frozen ice behind the plastic panel inside the freezer compartmrnt. Melted ice overflows the tray insteady of being discharged through the tray's drainage outlet tube.
To check if the tray drainage hole is blocked, it is easy to take off the plastic panel inside the freezer compartment by undoing the six small screws.
Please don't forget to switch off the electric before you attempt to clean the blockage. Good Luck
Posted on Jun 09, 2008
I have a small magic chef freezer that opens from the top. I has about 3 or 4 cu. ft. of freezer space. Lately a buzzer has been going off every 15 or 20 minutes. It buzzes for about 5-10 seconds and then...
With the time as the compressor gets old the buzzing will increased, its not a bid deal, just set the thermostat to 1 during the winter, saves you energy and give the compressor more time to rest.
Sep 28, 2011 | Magic Chef Chest Freezer MCCF5WBX
My Jet Pump Looses it's prime at night.
I assume the pump is not running at night. If the pump is higher than the pool, and the inlet and outlet to the pool are both under water, then you have a small leak. This could be allowing the water to leak out of the line. Or, if the leak is higher than the pool surface it is allowing air to leak into the line, which allows the prime to run down into the pool. If you found this useful, please vote. Thanks.
Feb 16, 2010 | AO Smith 2 hp Swimming Pool - Jet / Well...
Zanussi fridge /freezer
the drain located under the evap. maybe stopped up pour some boiling hot water into it and see if it drains underneath into the drain pan
May 06, 2009 | Zanussi ZEBF250W Bottom Freezer...
Leaking frost-free Zanussi fridge-freezer
Has this thing a separate frezer and cooler compartment.
Have tried to completely defrost and clean that thing.
At times like in airco's the pinch valve for the cooling process to effect (expansion) is stuck frozen, or very seldom broke.
Apr 14, 2009 | Freezers
Fridge on Fridge freezer not working
Ok there is a drain pan under the evap. coil under the fan that may be clogged and full of ice there is a 3/4" hole the water drains out of that needs cleared if there is a puddle of ice over it , the ice will also effect the airflow traveling down the duct to the fresh food section of the unit.
If there is no ice puddle at the bottom of the refrigerator then make sure the unit is cooling well by making sure it has been running for 10 min. or so and checking the coil in the freezer , it should have a small layer of frost on it showing its getting cold the whole way through it. Let me know how this works.
Phil
Jan 02, 2009 | Zanussi ZI921 / 8FF Bottom Freezer...
Zanussi fridge freezer frostfree ZX 57/3 W not working
It sounds like you have a plugged defrost drain line. This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube.
Hope this helps,
Sai.
Jun 12, 2008 | Zanussi ZX99 / 5 Bottom Freezer...
The freezer is working but the the fridge
same here. have the znb 4051s refridgerator. freezer works fine but fridge does not. there is no sound eminating from the fridge either...any ideas? its 1 year old!
Apr 13, 2008 | Zanussi ZEBF277W Bottom Freezer...
Fridge not cooling
Three most common problems are bad evaporator fan motor, defrost problem, or damper motor.
Sep 30, 2007 | Freezers
LARGE WATER LEAK ON FLOOR
the reason is probably that the drain hole in the freezer (i assume this is a frost-free type) is blocked. take off the rear panel of the freezer and you will probably see a block of ice at the bottom. melt off with a hairdryer and free the drain with hot water making sure that water flows freely away
May 06, 2007 | Zanussi ZEBF250W Bottom Freezer...
Zanussi ZEBF262W Bottom Freezer Refrigerator Logo
461 people viewed this question
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
