Question about Toshiba Satellite A60 Notebook
Black screen with the text "Check System. Then press F1" Nothing happens. How do I check System if none of the keys work. Will not even go into BIOS. Please hel. I have tried pressing both F12 and escape on switch on nothing happens. Is this a cpu problem. I have taken the HDD out and connected to my desktop via USB and I can read it ok.
  • 59 Answers
Remove floppy disk or cd from computer, try to reboot, if same message, replace CMOS battery.
Posted on May 29, 2010
  • 428 Answers
Try using F2 or F10 or Del. Check the Key board connection. You can use Ctrl+Alt+Del to restart the machine. If it doesn't work you have to change the keyboard and check again.
How do I access the BIOS settings for the P5LP-LE motherboard. The startup key says to press F1, but pressing F1 does nothing.
The instructions say:
"Hold down the F1 key during the startup process and enter BIOS setup to re-enter/reset any custom BIOS settings." I would also try hitting the F1 key multiple times from the very turn on of the computer because the key may have to register at some point after turning on.
Try clearing the CMOS settings as explained on this page, it should clear out any passwords and will set the BIOS settings back to factory settings.
HP and Compaq Desktop PCs Motherboard Specifications P5LP LE Lithium
As for "The CPU fan runs normally on boot, but as soon as the Windows flash screen comes up, the CPU fan slows way down."
This is quite normal. On start-up the temperature of the CPU is not being read, when the flash screen comes up just happens to be the same time that the computer recognizes that the CPU is cold and doesn't need to be cooled.
On the "Then the installation program starts running and the CPU Fan speed starts fluctuating wildly from slow to extremely fast."
This could be normal as when files are read from a DVD the CPU doesn't work hard, but when it unpacks the files or does calculations it does work hard. Or it could be that the thermal paste between the CPU and the heat sink is not correct. Either dry , not making contact, or even too much. If the heat is not being transferred that would also explain the shut-down.
Nov 11, 2016 | Computers & Internet
How to set up bios on toshiba laptop tecra m1
Hold down the Esc key and press and hold the power button until the on/off light on the system indicator panel illuminates (green) for approximately one second. When the following message appears on the screen: "Check system, Then press [F1] key," press F1. The System Setup screen appears.
If that doesn't work, try powering on the laptop and when the Toshiba splash screen comes up, hit F2 or F12.
One of these methods will get you in to the BIOS setup.
Mar 10, 2015 | Toshiba Computers & Internet
How to get to toshiba nb205 bios
Jun 10, 2014 | Toshiba NB205-N210 Netbook
I toasted my school laptop, using it to seach arourd while taking break from studying and i am sure i now have a lovley viirus. while trying to restart laptop, all i get is the black screen with cursor...
This is a system board POST/BIOS error code (nothing todo with Windows). The ERROR 210: is a standard POST (Power On Self Test) errormessage that indicates an error with the keyboard. The error condition is thata keyboard scan code was received from the keyboard when none was expected,after the keyboard was reset.
If this occurs most of the time when you power on yoursystem, then it indicates that a key is sticking down or the key mechanical orelectrical parts are broken. Sometimes blowing out and cleaning out around thekeys will resolve this problem. Otherwise, you need to replace your keyboardwith a new (or at least a working) one.
Apr 19, 2011 | Computers & Internet
Black screen with flashing curser, pressed f8 and R keys. nothing happening. have run a bios check they say nothing wrong been on black screen for 24 hours now. please help!!!
That screen is what happens when the BIOS can load Windows because it was severly corrupted, There's only one thing you can do - reinstall.
Oct 18, 2010 | Dell Inspiron 1545 Notebook
Toshiba satellite 1415 S-173 BIOS entry key
Try this...
Toshiba® 335 CDS ESC Toshiba Protege ESC Toshiba Satellite 205 CDS F1 Toshiba Tecra ESC then F1 or F2 Toshiba Notebook [Newer models]
1. Turn on computer by Holding down power button while pressing the ESC key.
The machine will beep, then display:
Check System, then press [F1] key.
2. Release ESC key
3. Press F1 key
Nov 04, 2009 | Toshiba Satellite 1415-S173 Notebook
What function key accessed the bios on 500cdt
If you have a Toshiba Tecra 500CDT:
Steps
1. Power up computer from off condition with ESC key depressed. Unit will display "Check system. Then press (F1) key"
2. Release the ESC key, press the F1 key. This will put the unit into the BIOS setup screen.
Oct 19, 2009 | Computers & Internet
Amillo pro 2010 screens gone black
Check by rebooting it to BIOS--Press Del or F1 during boot....
Choose F8 option during startup intial stage-Windows
Choose Safe Mode----If it works---then No Problem with Hardware,,but with Operating System--Repair or Reinstall Operating System using Valid XP Serial Key
Oct 01, 2009 | Computers & Internet
Bios screen
2. Release ESC key
3. Press F1 key
Jan 22, 2009 | Toshiba Satellite 2405-S201 Notebook
Toshiba Satellite A105-s2716 power-up password
Hi, usually to get into bios on a toshiba laptop you press and hold the Esc key or the F1 key. try both of these, if they dont work, try this: 1. Turn on computer by Holding down power button while pressing the ESC key. The machine will beep, then display: Check System, then press [F1] key. 2. Release ESC key 3. Press F1 key If none of these work, we may have a different problem all together, get back to me if so, and i will see if we can find a solution. Hope this helps! Si :)
Sep 26, 2007 | ASI CL51-15 Notebook
Toshiba Satellite A60 Notebook Logo
390 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
