Question about Toshiba E-STUDIO 720 Copier
HDD Failure It says HDD mount failure. Please check HDD connection.
  • Toshiba Expert
  • 1,326 Answers
The HDD ( Hard Drive ) is mounted on the back of the copier behind the rear cover. It looks like a regular hard drive from a computer. It sounds like your hard drive has crashed. It will need to be replaced. You can try to disconnect & reconect the hard drive... Good Luck
Posted on May 30, 2010
HDD mount failure on Toshiba 351c copier
"HDD mount" means it has an internal hard drive (HDD, or hard disk drive), and the copier has failed to "mount" (place in operation) that disk drive. That error means that the internal hard drive has failed and needs to be replaced. It will very likely need to be a special proprietary hard drive, preloaded with some sort of operating system for the copier, and you'll need to get it from a dealer.
Jul 30, 2014 | Toshiba E-studio 351c Color...
No bootable device found
The Hard Drive is not starting up. You can check the Hard Drive and detach/re-attach. If it's a HDD failure, you will need to replace it.
The other issue could be HDD controller on the motherboard.
90%of the time it's a HDD failure.
Nov 23, 2013 | Computers & Internet
How can i solve the disk boot failure?
For Disk Boot Failure, below are the steps:-
1) First check your HDD. (Go to BIOS > Run the HDD self test).
2) Make sure there should not be any external media connected to your notebook (CD, USB drive etc.)
3) If your HDD is OK, then You need to install the OS again.
WIth regards
FIXYA
Please post your feedback and Vote if the problem resolved as per your satisfaction
Sep 24, 2010 | ASUS Computers & Internet
MY HARD DISK HAS EXPERIENCED A PROBLEM I CANT INSTALL THE OPERATING SYSTEM. I GET AN ERROR SAYING DISK FAILURE AND ITS DOWN NOW I CANT DO ANYTHING
Disk failure = the hard disk has a hardware failure = it's dead. It can't be fixed, replace it and reinstall.
Apr 15, 2010 | Toshiba Tecra A3 Notebook
Disk boot failure insert system disk and press enter
When you encountered this kind of failure this is a HDD error, so check the HDD if it is properly connected. Use another IDE or SATA cable, use also the another SATA or IDE slot of your motherboard. No another way to fix it that is only the hard disk you need to check. Maybe the IDE or SATA cable is bad or the HDD itself. Good luck!
Jan 23, 2010 | HP Compaq Presario S5200NX (DM173A#ABA) PC...
Medion akoya e1210 notebook. failure to boot pxe
Failure to boot PXE 061 is a BIOS message that indicates 2 things:
  1. System failed to boot to the hard drive
  2. System failed to boot to a network connection
The apparent problem is failure to boot to the hard disk. If the system was running yesterday and there have been no hardware changes to the system, then most likely failures are:
  1. HDD failure (Replace the HDD, reinstall OS and applications) I hope you have information backed up.
  2. HDD not being detected by the motherboard due to connection issue (Remove HDD and reseat it, then see if seen in BIOS) If no change replace hard drive, if new drive not seen, replace motherboard
Jan 11, 2010 | Computers & Internet
PXE-E61 media test failure check cable
Your unit is telling you that there is a cable problem (between HDD & MoBo) try a new one or if you have another drive with same cable swop over.
Sep 18, 2009 | IBM NetVista PC Desktop
I've got BIOHD-3 NO BOOTABLE DRIVE (HP Diagnostic test)
if it cant detect ur HDD ... then check for jumper settings. ...
Jul 04, 2009 | Computers & Internet
Firelite wont mount on my computer
look at its format, (NTFS) or (FAT32)? and check the DRIVER for the hdd to see if it has any complications or errors, this is easyest fixed by deleting the HDD driver in Device managment and then restarting the computer. good luck.
Oct 09, 2007 | FireLite (USBFLB80) Hard Drive
1,597 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
