Question about Infinity HTS-20 System
How do u hook up the sub.
I would like to know how to hook up the sub
Sub woofer automatically turns off when playing
Could be a number of things. First try another sub, your current sub could have a problem. Second could be to low ohms going to the amp. Is it a new install or was your current setup playing fine then your current problem happened. I need to know what kind of amp and sub and how do you have it hooked up. If it's a 2 channel amp and your running it bridge mode then the amp needs 4 ohm sub hooked up unless specified that it can except a lower ohms. Could be a voltage problem as well. You can contact me at skinnman33@gmail.com let me know if this helps.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mark_b53a7494531bf96d
Aug 25, 2017 | Audio Players & Recorders
Sub hook up to Receiver
If the Pioneer has only one sub output connect it via a single RCA to the mono one. If it has two outputs (L&R) connect it to the L&R on the sub via a dual lead.
The other connections on the sub are for those amps without a dedicated sub output.
The manual for the sun can be seen online.
Yamaha YST SW205 Owner Manual Connections Connecting To Line Output pin...
Dec 18, 2017 | Pioneer VSX-454 Receiver
What's the best way to hook up 2 Hifonics hdl12d4 subwoofers to a mono amp
Ok, your post has two different models listed. Let's start with something you need to know about your amplifier. Is it one ohm or two ohm stable. This will make a difference. Also, whether your subs are single voicecoil (HFI12s4) or dual voice coil (HDI12d4).
Let's start with the easy scenario. Let's say your amp is two ohm stable and you have two single voice coil subs. It's simple. You go from the positive of the amp to the positive of both subs and the negative of the amp to the negative of both subs. This will provide a 2 ohm load to the amplifier, thus pulling all the power out of it.
Unfortunatley, if you have two dual voice coil subs, you won't be as efficient. You will only have the options of a 4 ohm load or a 1 ohm load.
This is where having a one ohm stable amp would come in handy. If the amp is one ohm stable, hook the positive of the amp to all 4 of the positives on the subs, and hook the negative of the amp to all 4 negatives of the subs. This produces a 1 ohm load.
WARNING!! If you have a 2 ohm stable amp DO NOT use the last wiring scenario. It will fry your amp.
Now, the last is a little trickier. This is for two dual 4 ohm subs. Follow closely. Hook the positive of the amp to one of the positives of each sub. (do the next step to both subs) Go from the negative of the voice coil that you hooked positive from the amp is hooked to, and hook that to the positive of the unused voice coil. Then go from the negative of that voice coil and hook to the negative of the amp. Make sure this is done on both subs. This will give you a 4 ohm load.
Hope this helps
Aug 31, 2011 | Hifonics HFI 12S4 12 DVC Subwoofer 600...
Am triying to hook up the wires from my pa to the sub but i dont get the subwoofer sound the way suppost to be ineed to know how to set up the sub
THE AMP OR RECEIVER HAS A SPECIAL SUB JACK ON THE BACK OF THE AMP OR RECEIVER THAT THE SUB HOOKS UP TO. IT TAKES A SEPERATE CABLE.
Feb 20, 2011 | JBL SF22SP Subwoofer
I don't know wich output to hook up my amplifiyer
on the back there should be 4 AV style receivers. 2 are for speakers and 2 are for sub. the sub will more that likely be labeled SW with a red and a white. If there are only two AV receivers than you probabally cannot hook up a sub properly. But you can always use the speaker ones, just wont be as good
Nov 23, 2009 | Eclipse CD3422 CD Player
Hits hard with one sub but has no bass with 2
do you no what ohm your amp can do and what your subs are
Oct 07, 2009 | Lanzar VIBE286 Car Audio Amplifier
Can i hook up a powered 12'sub to a Pheonix Gold xs2500 amp without blowing the speaker
First I hope you remove the speaker wires from the speaker that come from the built in amplifire. You cannot hook the powered sub to the amp without doing that first. Then all you need to do is run speaker wire from the sub out of the box to the amp. In no way can you hook up any other part of the powered sub, but the sub itself, to the amp. If you know the wattage of the sub and the ohms then wire it to the amp correctly. Your phoenix amp will put out 125 watts x 2 at 4 ohms and 250 watts x 2 at 2 ohms and 500 watts x 1 at 4 ohms bridged. Remember, only the sub itself in the sub enclosure can be connected to the amp. Hope this helped you. Let me know if you need more help.
Aug 23, 2009 | Phoenix Gold XS2300 Car Audio Amplifier
I don't know where to hook up the wires running from subs
the r+ and r- are for the right sub and the l+ and l- are for the left sub
Jun 14, 2009 | Jensen LXA300 Car Audio Amplifier
Just installed my cva-1004 in my truck and all connections are good get dvd picture but no sound do i have to have the remote to select inputs i also hooked amp and subs up amp to the sub rc's at the back...
Hey Ryan I have the same thing dude has and my sound only works when I have my subs are hooked up. Without my subs hooked up I have no sound at all. Do you know how I can fix this?
Jan 26, 2009 | Car Audio & Video
Wiring my subs to my amp
bridge it and rear channel if you need to know how to bridge let me know
Feb 07, 2008 | Phoenix Gold Octane-R 15.0:1 Car Audio...
Infinity HTS-20 System Logo
Top Infinity Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you an Infinity Audio Player and Recorder Expert? Answer questions, earn points and help others
