Question about Jl Audio 1000/1 Car Audio Amplifier
2000 watt jl audio amp & car battery...
I have a 2000 watt jl audio amp and 2 jl audio subs...after installing my system, my car battery died. I think its from the amp being on when my car is not running..what do i need to reslove this problem and what should i do??
  • Anonymous Mar 16, 2014
    how can I tell the watt rating on my jl audio a4300 amp I don't know how to tell what wattage rating is on the a4300 car audio amp.
    Novelist:
  • 100 Answers
Make sure that you don't have any strands that would connect the remote lead to the constant +12 volts. Also make sure that your remote lead fromt the radio switches off when you shut the car off. If you don't have an aftermarket radio with a remote turn-on lead, tap into the ignition wire to the radio. Let me know what kind of car you have and I can point you in the right direction to get the right wire. Good luck.
-Andrew Hawkins
Posted on Apr 11, 2008
SOURCE:
JL Amp isn't powering subs and speakers
silly as it sounds, you may want to check your EQ settings on your headunit. Things like sub volume, SLA, loudness and balance. When they replaced your battery, those old settings were lost.
Mar 26, 2010 | Jl Audio 500/1 Car Audio Amplifier
Got jl300/2 amp confused which subwoofer sounds good
Hello drsubhakar26,
JL W6's will perform well with from 150-600 watts RMS. W7's with from 150-500 watts. Less expensive Alpine Type R's work OK with from 200-500 watts RMS. Either of the brands will sound good. None of them will perform to their full potential with 300 watts RMS. Powering any sub with a 2-channel amp is a compromise. A monoblock is more efficient.
Hope this helps.
Jul 12, 2009 | Jl Audio Slash 300/2 Car Audio Amplifier
I Have 2 12inch jl audio subs and 1 800 watt kenwood amp and its just not enough boom, so was thinking about installing another amp (performance teknique ) but not sure how to wire it all up......n e help...
How is it wired now? One amp with individual wire to the two subs in stereo mode? What are your plans? Are you adding a matching amp or just buying a larger one to replace the one you have?
Jul 12, 2009 | Sony XM-SD61X Car Audio Amplifier
JL audio 250/1 not powerful enough for pioneer TS-W307D4?
you should move up to more power....underpowering subs is bad! try not to go under the subs rms by 5o watts?
Jul 02, 2009 | Jl Audio 250/1 Car Audio Amplifier
Will a JL audio 1000/1 amp run a orion HCCA 15
Hello evopower,
The JL 1000/1 will power the Orion HCCA OK.
It is stable only to 1.5 ohms so your best choice would be the 15.4 with dual 4ohm voice coils. In parallel, this would offer a 2ohm impedance. The 15.2 could only be wired for either a 1ohm load (too low) or a 4ohm load (less power).
Hope this helps.
May 16, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Need to pick perfect amp
I suggest to use separate amps to your sub, get a 2 channel amp for your sub and 4 channel amps for your speakers.
Here are my Top 5
  • Lanzar -OPTI4000D
  • MA Audio- HK-4000D
  • JL Audio 1000/1V2
  • OPti 22.2 Power Amp
  • AudioBahn-A5100T
Apr 05, 2009 | Power Acoustik FUBAR-12W Car Subwoofer
If I buy 2 12 inch jl audio w7 subs would it be better to get 1 or 2 jl audio 1000 watt amps
two amps and get a 2 farad cap please because if u dont u could melt wires together cause a fire or toast ur alt.
Oct 30, 2008 | Jl Audio Car Audio & Video
Amp voltage
Well this is interesting, Let me start by saying if you have a 2 ohm load and your system is set for 4 ohms you are going to overdrive your load and burn up your amplifier, maybe not right away, but sooner or later it will fail due to electrical and thermal stress bought on by power dissipation issues.
Yes you can get 2000 watts out of your amps, but the correct way is to bridge your amplifiers if you can, and terminate them into the proper load.
Thank you,
Shuttle83
Apr 21, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Jl audio E6450 cutting out
hi, have you figured out whats wrong with ur amp ...i have the same amp ....and as soon as i finished the connections ...and connect the remote on wire,,, the amp goes on ...making a ticking sound with the green light blinking and the red light staying solid on ...whats the problem please help ....how can i fix this ......my amp is a jl e6450 ....im using a panasonic cd player with a built in amp ....and thats the cd player im trying to connect to the jl amp ...please HELP
Nov 01, 2007 | Jl Audio E6450 Car Audio Amplifier
Jl audio 12w1v2-4
500watts sounds about right to me,i wouldnt go any higher as you risk popping the sub and haveing a melt down in the coil section of the subwoofer.
Feb 18, 2007 | Jl Audio 12W3 Car Subwoofer
Jl Audio 1000/1 Car Audio Amplifier Logo
177 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
matthew walsh
Level 1 Expert
Dalynn Turner
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
