Question about Maytag Washing Machines
Maytag washer wiring diagram for A412 - Maytag Washing Machines
4 Suggested Answers
  • 1073 Answers
SOURCE: maytag a412 wiring for drive motor.
look inside the console the wiring diagram will be in there
Posted on May 02, 2008
SOURCE: what is the product capacity of older Maytag
I researched the exact same question recently and found on a website somewhere that it is 3.2 cu ft.
Posted on Jul 22, 2009
  • 6277 Answers
SOURCE: do you have a wiring
Sorry but this forum does not supply operation and service manuals direct; it's just made up of ordinary guys and gals, probably at home, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer service manual' and you may be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Also may I suggest you try the manufacturer's web site direct? You may find, however, that it will supply only to service engineers but good luck anyway.
Good luck,
John C
Posted on Mar 06, 2011
How do I find out the cubic feet for Maytag washer model A412?
Calculate it yourself: Place a straight edge across the top of the unit. Measure the height from the bottom of the tub to the bottom of the straight edge. Then measure the width of the inside center of the tub and take half that number. Then use the formula below to calculate it. For example. Height 30 inches, Width 28 inches (half of 28 = 14).
V = (3.1416 x (14 x 14) x 30)/1728
= (3.1416 x 196 x 30)/1728
= 18498.48/1728
= 10.70 cubic feet.
Mar 02, 2015 | Maytag Washing Machines
machine start when you push the start button but stops 3 or 4 seconds after the button is released help me dennis montgomery maytag neptune model #mah3000aww
Aug 27, 2010 | Maytag MAH8700AWM Neptune Front Load...
Code f24 comes up on mhwz2600tw00 and I changed user interface , mico computer machine control and door latch. Machine will come on with door open but when I shut door machine will not come on.
I removed back from washer and found wire broke .I also found packet with all codes and wire diagram. Repaired wire and washer works fine. I have had this washer for 2 years and the back has never been removed until this time. I think when washer was assembled wire was pinched and during all the washing in 2 years vibration finally finished breaking wire. All tech. from Maytag can't or want tell you anything about their machines. All they want to do is swap out parts and charge a arm and leg for thei service. You are wasting your time to even call Maytag for tech. support. They don't know anything about codes or anything else. If all applinces go out, refg.,dryer.washer.mico.,range, it want be replaced with another maytag.
Jan 28, 2010 | Maytag Washing Machines
I have an older maytag washer. It fills over the
I had the same problem on an older Maytag washer (A412 series?). The solution is easy...but a bit dirty. The problem is that your level switch, which is actually a pressure switch, is not actuating because its sensing line is plugged. The line usually plugs at the sensing line manifold (larger diameter tube) with washer "gunk" or slime near its connection to the drum. Note that there are not that many connections to the drum, so you should be able to find it and remove it. Access to the front interior of the washer will be necessary (its easy...the front panel rotates up and off). Access to the top instrument/control panel may be necessary to unhook the sensing line from the pressure switch if complete purging of the line is necessary. Take care when working with the pressure switch for their internals can be easily damaged.
Oct 04, 2009 | Maytag Washing Machines
What is the product capacity of older Maytag washer A412
Jun 29, 2009 | Maytag Atlantis MAV6260AWW Top Load Washer
Old Maytag washer LA182 motor replacement
Neil,
I need to know if the motor came with a wiring diagram when it was purchased or did it just come by itself. You may have to learn how to read the wiring diagram that is stored inside the control panel.
Jun 09, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag a412 wiring for drive motor.
May 02, 2008 | Maytag MAT13MN Top Load Washer
WASHING MACHINE NOT TURNNING ON
moste likely it is a 10A fuse which is blown
Please check following link and see the wiring diagram.
HERE fo wiring diagram
HERE for part number of fuse (nr4) and able to order it
Apr 27, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
216 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
