The Ac-Clu fues blows out as soon as you replace it on cadillac sedandeville 2000
  • ikilyacuz May 29, 2010
    dont see burnt wires tho
  • 2,427 Answers
That's cause there is a shorth somewhere along the harness.. U will need to reomve the dash and pull the acc harhess out.. Its starts from the pblower.. Once out remove the loom housing ,d you will see at least 2 burnt wires.. Cut off and replace them.. Reseal in loom and put back harness.. Remount it and u should be fine..
Posted on May 29, 2010
  • Rishi Roshan Ali May 29, 2010
    You wount just see the burn wires.. Firstly the harness is strappend under the dashboard..u need to remove the dash to get too it. Then u need to remove the loom from the harness.. To see the wires.. A blown fuse like that is a short and burn grounding wires are all that can cause that.. And I'm sure its in that harness
Do you have to remove dash replace heater core 96 cadillac sedandeville
yes and im sorry to tell you that !! its a lot of work , I found a full break down at auto zone library its all free and no spam you can find it under chassie electrical
Feb 21, 2015 | 1996 Cadillac DeVille
2000 cadillac AC blow hot air out on driver side only
suspect a bad cabin compartment selector or actuator, got to look under dashboard panel.
Jul 28, 2014 | 2000 Cadillac DeVille
Trunk pulldown on 1994 Cadillac Sedandeville fails intermittently, then works
Replace the electric trunk latch assy
Try ---dealers parts dept first,then salvage yard,
then the internet
Mar 10, 2013 | 1994 Cadillac DeVille
What does it mean when the oil light in the 1995 Cadillac Sedandeville 4.9 comes on
It can mean one of two things. Either your oil level is too low, meaning more than 1 quart, or your pressure is too low. The first thing to do is check the oil level in the engine and top it up. If the light goes out after this then everything is okay. If the light stays on you should get the oil pressure checked with a mechanical guage to get an accurate reading.
Get this done as soon as possible. Manufacturers don't give you much room with these lights, when they come on you are very close to the engine meltdown point. Hope this helps.
Feb 21, 2012 | 1995 Cadillac DeVille
Actuator malfunction air conditioning won't blow into car
the actuator opens the indash vents for the ac to blow into your car yours sound like they are broke and need replaced check your ac fuse see if it is blown if not then have to replace the actuator you should be able to get to it from under the passenger floor dash plastic it is by the motor if i remember correctly
Sep 24, 2010 | 2000 Cadillac DeVille
Blows the fues for the head lights
There must be a short to ground in the wiring to the lights somewhere. When you say turn on the headlight, aren't the lights on anyway as soon as you turn the switch to start the bike? They should be, that's standard.
May 11, 2010 | 2003 Harley Davidson FLSTC Heritage...
I have a 1993 cadillac sedandeville the turn signals dont work can you help?
Usually when this happens it is due to a relay in your fuse box failing. There are 1 or 2 relays which turns the constant flow of electricity to your lights to intermittent when you use your blinkers. If the light is constant when you use your blinkers the solution will be to replace the faulty relay.
Jun 09, 2009 | 1993 Cadillac DeVille
My 96 caddy
make sure you cheak the fuses they should be under the dash by your feet(i have a 1993 deville and the fusebox is by the E-Break) if any look burned either replace them with the EXACT same model (the wrong fuse might cause a fire) if you're not sure have someone else do it
May 05, 2009 | 1996 Cadillac DeVille
Heating & Cooling Logo
14 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
