Question about HP LaserJet 1020 Printer
My printer does not print at all i try to install over and over again the printer driver but it doesnt work.. my printer can read paper but it doesnt print. should i need to get a new driver or my software had a problem
  • Anonymous Apr 08, 2008
    Wil nie instaleer nie. Testpage wil nie print nie!!
    Genius:
  • 2,785 Answers
Can you give the printer model no and make.
Posted on Apr 08, 2008
SOURCE:
Printer does not print. have prints in que but doesnt print
Have you tried a quick reboot? Of course, save the file you want to print, reboot your PC and try printing it again. If this doesn't work, try removing your printer in the "Devices and Printers" that you can find in the control panel (or Printers in XP). After removing, try adding a new printer again. Don't worry, you won't need drivers then because the driver is already in your PC after you installed the printer the very first time.
I hope this helps... (,'')
Jun 04, 2011 | Office Equipment & Supplies
Hi there. I have a HP LaserJet P1006 printer and a laptop with Windows 7. The print jobs get stuck in the que and I cant delete it. I installed the cd software many times, and I have installed the software...
you are installing the drivers may be not correct. u remove the printer driver and install the proper driver again otherwise it may be spooler problem then u have to reinstall the os and configure printer dirver
Apr 07, 2017 | HP LASERJET P1006 Printer
My 1610 printer will note print any item other
try copying in colour first......see if tht works .....if not chk out if the cartridges are inserted properly....next you can clean the copper contacts on the cartridges with a piece of cloth....if it copies fine then check for the installed drivers in the control panel.try uninstalling the drivers and reinstalling them back again...try deleting the registry VID and PID keys if possible.....it should work for you......
let me knw if it doesnt.....
Jun 24, 2009 | HP PSC 1610 All-In-One Printer, Scanner...
Samsung CLP-350N installation problems
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 31, 2008 | Samsung CLP-350N Laser Printer
My Dell AIO 922 scanner/printer doesnt work
u can download da driver 4 ur Dell AIO 922 scanner/printer at these following sites-
www.driversplanet.com
www.download.com
etc...............
try now
Dec 23, 2008 | Dell 924 All-in-One InkJet Printer
PROBLEM ON INSTALLATION OF PRINTER
may i know if the printer is working right now or it does print??but it doesnt print you need to check if the printer icon is available in the PRINTERS folder in the control panel and if its available and says offline just try to click the icon the USE PRINTER ONLINE.if you doesnt have the icon you need to reinstall software used this link to download the software from hp website:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=2510767&lc=en&cc=us&dlc=en&lang=en&cc=us
select you appropriate OPERATING SYSTEM..
send feedback for further troubleshooting
Sep 06, 2008 | HP Deskjet 2460 InkJet Printer
Hp psc1210xi all in one with gateway can't print!
install the drivers of your printer again. and change the usb wire if it is to old.thats it.
Apr 28, 2008 | HP PSC 1210 All-In-One InkJet Printer
Teac p11 will not print goes through the motions. cleaned head changed cartridge still not printing
First think to do :
Assure that your printer is the default one and the driver is active
After :
Assure your firewall allow the printer software
After :
Verify your cable by trying a new one
After :
Unplug your printer to your computer
Uninstall the printer driver
Restart your computer without the printer plug in
Plug your printer
Leave Windows install the driver by itself
If it cannot
Assure that you have no printer driver install, if yes, uninstall it
Install the printer driver with your CD
Assure the driver is active
Assure the printer is the default one
Dec 01, 2007 | Teac P11/KIT Thermal Printer
Not printing
This is the information I received from another person when i ask for help. I did exactly as it said and my printer works fine now. Try it and see if it works for you. Good Luck!
First download and run "CleanupUtility.exe" from: ftp://ftp.lexmark.com/driver/inkjet_drivers/Cleanup/
Then unplug the printer's USB cable and restart your PC.
Then download and run the printer's drivers/install program for Vista, from: http://downloads.lexmark.com:/cgi-perl/downloads.cgi?ccs=229:1:0:548:0:0&emeaframe=&fileID=10374&searchLang=en&searchLang=en&os_group=Windows%20Vista
Only plug the USB cable back in when the drivers/install program tells you to.
After install, I think it asks for another reboot.
Then all should work fine.
Oct 28, 2007 | Lexmark Z640 InkJet Printer
HP LaserJet 1020 Printer Logo
50 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
