Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
I have a craftsman 1.5 hp/ 2 Gal. air compressor and everytime i go to turn it on it kicks out the breaker. model #921.152100 capacitor ????? plaese help aroberts616@aol.com
  • 10,865 Answers
Hi there. Plug your compressor in as close to your circuit box as you can on a circuit that is dedicated to that outlet
What is happening is this. You have a 15 amp circuit and a 15 amp draw on your compressor. No wiggle room at all. If you need to get the air a long ways use air hose and never an extension cord. Joe
Posted on May 29, 2010
I have a 33 gal craftsman compressor when I turn on the relay switch hums but the motor doesn't spin?
I would check the capacitor since it appears that the motor is not locked up. Here is a how to on testing capacitors;
how-to-check-capacitor
May 16, 2012 | Craftsman 33 gal Air Compressor 6 hp...
I have a 3 gal 1 hp air compressor and it will only build pressure to 27 lbs.
If it makes hesitation sounds just before shutting off, you need to oil the compressor as per the manual. This is the most common problem.
If it is kicking on and off normally, you need to adjust the pressure relay. The instructions are under the cover.
May 14, 2011 | Craftsman 3 gal. Air Compressor, 1 hp,...
Compressor starts innitially,then when pressure gets low it trips breaker when it tries to start back up.20 amp breaker to light switch to compressor is about 2o ft on12-2 wire. tried 30 amp breaker,does...
the start capacitor on the motor body is weak,the motor needs this component to over come the air pressure when cycling to re-build the low air pressure,change both the start and run capacitors when doing the start because the other run capacitor is just as old and it will soon fail
Mar 19, 2011 | Craftsman 33 gal Air Compressor 6 hp...
Compressor fills air tank and when it cycle to refill tank it kicks a 20 amp dedicated circuit breaker. Sears looked at it twice and said it is OK. Changed breaker with new one because Sears said it...
try this. When compressor shuts off. TURN OFF POWER. then spin the compressor backwards or forwards until it is off the compression stroke. Turn unit back on. If it doesn't blow the breaker, then it is worth looking into the type of compressor (pump) you have. Many have a "reed valve" and that might be failing, holding the compressor itself under load when it shuts off so that on restart it is under heavy load and the motor draws too many amps to get it started hence blowing the breaker anyway hope this helps
Feb 17, 2011 | Craftsman 25 gal Air Compressor 3 12 hp...
I have a 25 gal. craftsman oilless air compressor. Runs for about 1/2 a minute & than kicks the breaker out.
Hello babeaton, several things can cause that, but, the most common thing is the regulator. let it run again and right ofter it kicks off feel the power cord and see if it's warm to the touch, if so it likely is the regulator. Breakers operate based on the amount of heat generated from current running through the cord/wires.
Good luck my friend!
Jan 16, 2011 | Craftsman 25 gal Air Compressor 3 12 hp...
Air compressor struggles to start but eventually starts
If the proplem only happens after the initial start-up with the tank empty, then your back flow valve is sticking and preventing the compressor from kicking over imediately. If it does it all the time, even when the tanik is empty, then your capacitor on the motor is not charging correctly.
Jan 17, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air compressor motor will not restart
Hi, The start capacitor on the motor needs replaced. Good Luck, hope this Fixsya!
Feb 22, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
262 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
