Question about Garden
I need to know how to install mower deck of craftsman lt 1000 with a 42' cut, does not have cable linkange has the steel rod. Need a picture so that I can put back together.
  • 66 Answers
I need the 917. number
www.nnyparts.com
Posted on May 30, 2010
A cable is loose that will not allow me to engage the blades, how do I reattach the cable. it is a craftsman Lt 1000 17 IC ohv . model # 917.272260 42 inch cut.
Tightening up a stretched cable is impossible. If the cable is NOT adjustable to shorten it and make it tighter, then you will need a new one. Here is a link to one. I searched all the parts diagrams in your manual for the cable and find it was NOT listed. I hope this helps as I have researched your problem. Go here:
http://amcpartsstore.com/FSP-Deck-Blade-Engage-Cable-Craftsman/M/B0014G6T1S.htm
Aug 14, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I bought a new belt for my2005 lt 1000 42" deck
for a deck no.. Most everything on the deck is done by springs.. what i would do is look at the deck make sure nothing is rubbing the belt making it rip apart.. or make it to not engage.. i would with the engine off engage the blade and disengage the blade make sure all the brakes are pulling away from the pulleys and making sure all the arms are moving to tighten the belt.. if nothing is moving then i double check the cable or however engages the deck (all mowers are different) and if need the part. If the cable is not broken and is still on deck make sure all springs are lubed. If you have any questions please dont hesitate to ask
Jul 16, 2011 | Craftsman Replacement Belt for 42" Deck
The deck on my mower is lower on one side than the other. Is there a way to raise it up? It is tearing my yard up and scalping. I have a craftsman 15hp 42inch cut command. Any help would be appreciated...
To adjust a Craftsman deck, raise the deck to the normal cutting height.
Measure to the flange on the deck on the right & left sides. It is easier to lower the deck than to raise it, so, on the high side, find the threaded rod that supports the deck. Using a wrench, back off of the nut (counterclockwise as viewed from the end of the rod) until both the left & right sides of the deck are the same height.
Be sure your tires are properly inflated before measuring.
Gary
Jul 03, 2011 | Craftsman Garden
Do I need to mix oil with my gas for the lt 1000
Simple, it is seperate. There is no need for a mixture
Jul 29, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I need a deck diagram for a 19.5 hp 42' cut
Craftsman 42 in deck makes terrible noise and middle wheel shakes. started while mowing.
Jul 26, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Need a blade engagement cable diagram for a 2002 craftsman lt1000
as far as i know, there is no diagram available for the cable replacement. it is covered briefly in the owner's manual, but the best way to do it is to study carefully how the old one is routed, and replace a step at a time
Aug 06, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How do I remove the cutting deck on a Craftsman LT1000?
pull the pins from the rods attached to the front of the deck. then let the deck all the way down. remove the pins in the deck lift arms and remove the pin in the top of the tension pully and lift the end of the cable off the pully remove the clip holding the blade ingadgment cable in place . pull the pin in the arm at the back of the deck disconnect all of the rods you pulled the pins out of and slide the deck out. put it back in reversing the above prossess.
Jun 18, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need to fit belt that turns blades on husqvarna lt 120 can you help.
You will have to remove the cutting deck from under the ride on to have better access to the belt
If you take a picture of the cutting deck once it is removed it will assist you in putting it back together.
To remove the cutting head belt from the engine bottom pulley you must push the foot pedal down and lock it in place to take the pressure off the belt to remove it from the pulley.
There is most probably a rod that hangs down close to the side of the pulley which is there to stop the belt from coming off when the pressure has been taken off the belt, you have to loosen the rod retaining bolt and move it away from the side of the pulley to get the room to remove the belt, there will be a cable that adjusts the deck cutting height which has to be removed from the cutting deck to be able to remove the deck, there should only be 3 anchor points that hold the deck under the mower, 2 on the sides and a steel rod throught the front with spring clips on them for quick removal.
when the deck is out you will see t hat both the belt pulleys on the deck have plastic guards on them which have to be removed to be able to get the belt off the pulleys.
Replace the belt and install all the parts in the reverse order that you removed them in.
Is a reasonably large job for a person who has never done it before but it is a job that anyone can do if they just take their time and also a few pics before removing just for a reference
Hope this helps
May 12, 2009 | Garden
Garden Logo
109 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
