Question about Fedders A6X05F2D Air Conditioner
My fan will run but the compressor will not turn on. It was working fine until it was switched from fan mode to cool mode.
    Scholar:
  • 73 Answers
Unfortunately, typically this means low freon charge. Need to have a tech charge the system.
Posted on May 29, 2010
Truck has recently begun to go straight into limp home mode immediately after starting. the cooling fan starts in high speed with no A/C running.
Make sure ac compressor clutch is not engaged even though ac switch is off. If clutch is turning compressor on due to stuck relay etc, ecm will turn on fan due to signal from pressure switch. You may need a scan tool to view scan data and determine source of fan issue
Jun 29, 2015 | Cars & Trucks
I have a GrandAire and the aircon works fine; when I turned the heat on, it seems to work fine (warms the house), but the fan in the outside unit is not spinning when the heat is on...is this a problem?...
I think your unit is working in good condition. If you keep in cool mode the out door fan runs to condensate the heat in condenser by taking fresh air from the ambient. And when you keep heat mode, definitely the ambient temp will be too less.I fit takes from their then compressor will get frozting and it couldn't work properly. Depending on pressure increase, the fan will automatically run and stop. Don't worry. Thanks.
Dec 16, 2010 | Heating & Cooling
Fan will not run on high. Compressor runs fine but the fan will not run on high. Works fine on low and med.
It's the mode switch contactors for the high setting just overview the wiring of the high cool or high fan contactors if it's not there check all leads for the high fan or high cool circuitry.
Aug 01, 2009 | Coleman Mach III Air Conditioner
Penguin model 610012-001a/c compressor won't start
I would check to make sure that the control is sending the "cool" signal to the control unit. LO on the room temp display usually means that the fan speed is set to low. Is LO and Auto showing on the display at the same time. Try resetting the thermostat first. Hold down the Mode and Zone buttons with the tstat off. While holding them down, turn the tstat back on and hold the buttons down until FF appears on the screen. Release the buttons and try the AC.
If this does not work, on the control board is a freeze control switch plug (blue usually). Try unplugging this unit and insert a small jumper wire. If the Compressor comes on and runs then you have a bad freeze control switch. If not, then you should replace the control board.
Hope this helps,
Jeff
Jun 23, 2009 | Dometic Rooftop RV Air Conditioner
Works fine, but every couple of days I will notice that it will not be cooling, as the fan or compressor will not be working. I will turn the temp controler off, then back on and the compressor and fa
Check the condenser coil to make sure it is free of any dust, which will cause the compressor to overheat. The fan underneath may still be running, but until the compressor cools down it will not start.
If the unit always immediately begins running when you turn the control off and back on, then it may be you have a bad control. Have a servixe tech look at it, as you cannot repair the control...it's a throw away device.
May 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Will not switch to cool mode. heat and fan work fine
hi,
regarding on switch mode theres a common line between heating and cooling although fan is always connect on them.,also with the thermostat,the sequence on this when you switch to cooling and your connection is on heater,the contactor will shift to compressor source,so if there is no cooling, the contactor supplying the compressor is not functioning when you switch on cool mode.try to tighten screw on compressor relay maybe only loose.on control panel,or check continuity of compressor if the compressor still good,check also the freon charge using clamp ammeter,this should be done by ac technician.have a nice day
rate me up,thank's
Apr 26, 2009 | Heating & Cooling
Freezer works Refrigerator will not cool down
The compressor should be OK this time because you caught it in time. But if the condenser fan stops you need to consider replacing the fan. I have had refrigerators do fine until the fan motor warms up and you are away, it stops. Don't think you should use the refrigerator until the fan is fixed. Sea Breeze
Apr 22, 2009 | Kenmore Refrigerators
Air conditioner fan will not come on and unit will run for 1 minute and stop
You hear the compressor kick in (Hum) but no fan comes on? Will the fan come on when just in fan mode, not cool, or do you have that set-up?
Aug 13, 2008 | Dometic Rooftop RV Air Conditioner
Temperature display and "Cool" light flicker and click
It has an electrical problem, first. You (and I) won't know about needing freon until the compressor is running.
Jul 23, 2008 | Kenmore 72055 Air Conditioner
Fedders A6X05F2D Air Conditioner Logo
189 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
