Question about Black & Decker 9072CTN 2.4V Cordless Screwdriver
What is the polarity on the 2.4 power adapter for the B&D 9072 cordless Screwdriver?
You need a 4.0 - 4.5 DC 100 mA power source with center pin positive polarity.
Posted on Dec 19, 2010
Input voltage?
looks like it is 12 V, 1 to 2 amp.
her are some power Adapters listed on amazon. Also, look on the bottom to see what polarity it is (also by mosue over the picture of the adapter in the bottom link (to zoom in)
Amazon com Pwr Extra Long 6 5Ft Cord AC Adapter Charger for Seagate Hdd...
Amazon com Super Power Supply AC DC Adapter Charger Switching Cord Plug...
Apr 28, 2016 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I need a power adapter for telephone base for model 30524
Not a problem. Take the base unit with you to Radio Shack and they will get you a proper replacement. (The numbers on the plug in to the unit will say how many volts Direct Current are required to operate is properly and the tag underneath will also state how many milliWatts of power are required at that voltage.) The key is buying the proper plug in end that fits the socket. Radio Shack has units with several socket tips so you may select the proper one. Make sure the polarity of the socket plug you use matches the wire polarity... the stripe on one side of the power cord is the + side on the socket tip.
Apr 04, 2015 | GE 30524ee3 3 Headset Corded/2 Cordless...
I have lost the power cord for my 400 Amp power on board jump starter model #VEC021STC. where can I purchase one.
THIS IS A 12 VOLT POWER ADAPTER YOU MAY USE ANY 12V ADAPTER IF IT HAS THE SAME POLARITY AND SIZE PLUG WITH AT LEAST 2 AMP CURRENT RATEING HERE IS A LINK ON AMAZON
http://www.amazon.com/HQRP-Adapter-Charger-VEC021AC-VEC021STC/dp/B009DF2RFE
Dec 09, 2014 | Vehicle Parts & Accessories
Polarity
As long as you buy a genuine Dell AC adapter, it will be find.
Do not buy a 3rd party AC adapter.
I have bought at least a dozen Dell AC adapters on eBay. Just make sure the photo shows a genuine Dell.
http://www.ebay.co.uk/itm/Original-OEM-Dell-Inspiron-Mini-10v-Battery-Charger-Power-Supply-Cord-19V-30W-/190678344193
Apr 15, 2014 | Dell Inspiron Mini 10 Notebook
I need to buy battery for KC 9072
Either you can buy the original battery from Black and Decker or you can replace with the same mA rating with the regular types available in all stores any rechargebale variety with a good mA rating.
Couple in series and parallel to get the desired voltage and current rating.
Sep 19, 2011 | Black & Decker 9072CTN Cordless...
I have a Uniden TRU8885 - 3 Base, when I plug into power suply, it turn on, but after the base turn on and display the message welcome, the base turn off
buy higher capacity power adapter 9volts 1000mA capacity and use ensuring correct polarity, it will work. i had the problem and adopted this and this works ok. also ensure your handset battery is new and charged after installing the higher capacity power adapter. good luck. venkataramani
Aug 27, 2011 | Uniden TRU8885-2 Cordless Phone
Yamaha psr-280 flashing display no key response or sound. Is it dead??
Your adapter should be a 12 volt DC delivering 2 amps (2000 ma). If the adapter is too small, you will have the symptoms you are seeing. Make sure the polarity is correct. DO NOT use the so called "universal adapters".
Apr 13, 2011 | HQRP AC Adapter / Power Supply for Yamaha...
I need to buy battery for KC 9072. From where I can get it?
you can buy it direct from Dewalt or if you give me your general area I will try and find one more locally. The part number I found is 497755-01 and it lists for around 11.00 Please let me know if I can help more and if you have any more question please ask before voting. The site is "dewaltservicenet.com" and I used the model number 9072ctn to find it.
Feb 09, 2011 | Black & Decker 9072CTN Cordless...
I have a very old Maxtor external 200 GB hard drive. I can not find the power adapter for it. On the label, a part of it rads 12V 2A - does that's mean I need to look for a 12 volt, 2 amp power adapter?
Depending on the power adapter, you might be able to pickup one at Radio Shack..
If it is a single pin plug, check near the power adapter jack to see if it shows you polarity of the
center pin, which will either be "+" or "-" Take this information to your local Radio Shack along
with the voltage and amperage requirements
Feb 06, 2011 | Computers & Internet
Black & Decker 9072CTN 2.4V Cordless Screwdriver Logo
243 people viewed this question
Top Black & Decker Hand Tools Experts
Robert Monigold
Robert Monigold
Don Numinen
Don Numinen
Are you a Black & Decker Hand Tool Expert? Answer questions, earn points and help others
