Question about Mitsubishi WS-55511 55" Rear Projection Television
My tv worked fine. I moved it to a different room. When I plugged it back in the green power button just blinks and I can't make it do anything. I tryed the reset with a paper clip and nothing works. What could it be?
    President:
  • 1,099 Answers
Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on May 29, 2010
How to turn my TV back on?
are you sure the panel of LCD is not damaged?
Nov 09, 2014 | Televison & Video
Hello, I have an 56' Mitsubishi 1080I television. Model #55859. We moved the TV across the room last night and now we cannot get it to turn on. All we can get is a flashing green timer light on the front,...
Hi rteague2566,
The flashing light indicates something is wrong. Have you tried pushing AV reset button on the front panel of the TV. You may even try the little pin hole reset by the power button too. I think you may have bumped or, vibrate it to hard in the move and, caused the lamp or lead wires to become lose or, unseated. You may have even damaged it. Did you move this TV when it was still warm? Is the light blinking fast and, can you hear anything going on inside. Usually the DM board fails or, a few capacitors need replaced with this model.
If you still can't get the TV to turn on after the reset buttons have been pushed. Can you read the blink code. It should blink, blink, pause, blink, blink, blink. That would be a blink code of 23. Count the blinks in between the pauses. Let me know what code you get. If it just blinks real fast it is probably the DM. I kind of think you may just need to re-solder the leads. A DM cost about $250 with labor. When you plug back in and turn the TV on, let it blink for a few minutes, it might come back on. I'll wait for your response to give further instructions.
Jan 26, 2011 | Televison & Video
Unplugged my Ws-55711 TV to move it to another room so the carpet could be cleaned. When I moved it back and plugged it in, the green light kept blinking for more than 60 seconds. I unplugged the TV for...
Open up the front, look under the right side picture tube. Look for puddle of oil on signal board. If you see this, it has bad picture tube & signal board. Not a good repair.
Jan 17, 2011 | Mitsubishi WS-55711 55" Rear Projection...
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Blinking Green Light of Death
I had this similar problem TWICE!!!. I called around for a repairman and they charged over $300 dollars to repair (HELL NO). Anyways I took a trip to Vegas hoping to win some of the money to repair it and left the TV plugged in and BLINKING during my trip. When I came back it was not blinking anymore and I got curious. Well I pressed the power button and to my surprise IT TURNED ON!!!!. A month later I moved to a different house and unplugged my TV to move it and when I plugged it in the DAMN BLINKING GREEN LIGHT OF DEATH was back. Well I thought I'd get lucky again and leave the blinking on, well 2 days later the blinking was gone and ONCE AGAIN MY TV WAS ON...... I hope this helps and works for other people. My point is, before you pay for a technician to repair it and before you give up on your TV and unplug it, Try leaving it on BLINKING for a few days and see what happens.
GOOD LUCK GUYS.
Oct 07, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Blinking green light will not power up
My WS-55859, Did the same thing. Power went out, when it came back on the green light in front of TV would blink, but TV would not power on. Did some googling and saw multiple posts for "blinking Green light" or "Blinking Green light of death". Most of the posts pointed to replacing capacitors on DM Power board. I followed the direction and it worked great. Note the TV shop guy who did the soldering for me said the capacitors "looked fine" and they were not the problem. I couldn't tell the difference between a good or bad capacitor, so I asked him to swap them anyway. He did, I plugged the board back in, buttoned up the back of the TV. After 60 seconds Green light stopped and I started watching TV again... Here is the link to the best instructions I found (http://hdtvoice.com/voice/showthread.php?t=32186).
Aug 30, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
Jun 19, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Mitsubishi ws-55515 light blinking
Sounds like the remote is not programed correctly or the input sources have been changed.
Call the cable company and complain that it worked before they came and shoud work afterwards.
Mar 24, 2008 | Mitsubishi WS-55515 55" Rear Projection...
Green light just blinks
Four bad 1000mf/25v caps in DM module = Common repair
for qualified Mits tech..................................T.
Nov 11, 2007 | Mitsubishi WS-48513 48" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
183 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
