Question about Sony KP-61HS30 TV
It started out with alot of different colored squiggly lines it would clear up after about ten minutes but it just shut off yesterday the red button on the front still flashes though
    Novelist:
  • 144 Answers
Especially Projection TVs will shut down to protect the projection tubes because loss of proper scan can burn an image into the phosphors in the tube itself. The squiggly lines most likely are a symptom of a failure in the Horizontal output section (the part that scans the picture from left to right), there is also a possibility of the Vertical output section (the part that scans the picture from top to bottom causing the problem. This will require replacing a circuit board or repairing the one in the set at a component level. This is best left to a qualified Technician to do the work.
Posted on May 30, 2010
Slow Internet/Keeps Cutting Out
Reset your router using the red reset button in back of the router. Let everything startup and test it. If the problem persists, then you might have to call your ISP or replace the router itself.
Feb 02, 2014 | 2wire Computers & Internet
Video Card Ribbon Problem? Squiggly Lines on Monitor
It can be that the video card in bad or any electrical part need to be fix and i recommend to send it to a repair shop.
May 12, 2012 | HP Pavilion Computers & Internet
My 2003 cavalier was rear ended yesterday. It started the first couple of times then it started, stalled, then started. I drove it ten miles. Turned it off and now it turns over but won't start. Any...
Alot of times after an accident fuses and bulbs start to blow. Impact issues. Slim possibility of the fuel pump 'kill' switch which shuts electricity off to pump in the event of an accident.
Dec 18, 2010 | Chevrolet Cavalier Cars & Trucks
Out of the box camera yesterday. Random LCD & power problems
Send the camera back, it's obviously faulty by what you have explained.
It should be under the manufacturers warranty so there will be no repair costs.
Regards.
Jul 27, 2010 | Kodak EasyShare Z950 Digital Camera
YELLOW AND BLUE SQUIGGLY LINES ON THE RIGHT SIDE OF THE SCREEN
Hi Fkanode.
The failure(s) in your TV is related to a part called light engine or optical block and Sony TVs are known for these kind of failures with the video showing with different colors or lines.
Check the link provide for more info or if you would like to try fixing the TV yourself.
Let me know if you would need further assistance.
Mar 07, 2017 | Sony Grand WEGA KF50WE610 50" Rear...
Squiggly Lines at Power On
Generally speaking, this type of symptom is caused by AC hum leaking throught the power supply. This can be due to a bad filter cap. Since this clears up after a while, I'd start by looking for poor solder connections in the power supply area. If you can, check the caps in that area as well. I'll research this a bit and try to get you more details.
Dan
Nov 06, 2008 | Toshiba 42H82 42" Rear Projection...
Picture & Color Distorted
Convergance IC replace.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 11, 2007 | Toshiba 50HX70 50" Rear Projection...
Vertical red line on 55 hitachi plazma
The vertical line, in my case, was due to a bad contact on the flexible printed circuit. I fixed the problem by using a piece of a rubber eraser to apply downward pressure on the flexible circuit as shown in the picture. To locate the faulty section lightly push on the flexible circuit from lef to right untill the line dissapears.
Nov 28, 2007 | Hitachi 55HDM71 55 in. HD-Ready Plasma...
Sony KP-61HS30 TV Logo
172 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
