Question about Bosch 24 in. SHV4303 Built-in Dishwasher
Need to replace drain hose on bosch dishwasher model shv4303UC/11
I have removed the dishwasher from the under the counter, but do not know how to disconnect the drain hose from the dishwasher.
Thanks
  • Bosch Master
  • 2,605 Answers
Hi, Welocome to Fixya. You just need to remove the small plastic holding tab at the back where the hose exits the machine. Then along the left side ( from the front...right side from back ) remove the side panel and the hose will simply pull out of place. Hope that answer's your question, let me know how you make out. Thanks for visiting "fixya" today. Please take a moment to leave a comment and also rate the solution provided accordingly. Good luck. Macmarkus :)
Posted on May 29, 2010
DISHWASHER WON'T DRAIN ANLY HAD IT FOR 6 MONTHS. CLEANED FILTER. DID NOT HELP. WHAT TO DO?
Hi, if its still under warranty you should call bosch and get them to arrange a service engineer to come out and check it for a fault.
Jan 15, 2016 | Bosch Dishwashers
How do I replace the outlet hose?
The exact steps depend on the make (brand name) and model of your dishwasher, but in all cases, you will have to pull the dishwasher out from under the counter. If it's an "American" dishwasher (Whirlpool, Kenmore, KitchenAid, GE, Frigidaire, etc.), you will see the hose clamp that connects the drain hose to the dishwasher, and it will be easy to disconnect the hose from the dishwasher. But if you've got a "foreign" dishwasher (Samsung, LG, Bosch, Fischer-Paykel), replacement is much more difficult and should be left up to a professional dishwasher repairman.
May 15, 2015 | Dishwashers
How do i replace the drain hose
It's a fairly big job. You have to pull the dishwasher out from under the cabinet. Then remove the left-hand metal panel. You should now be looking at the case-brake assembly. Reach inside the dishwahsher and turn the water-inlet bezel counter-clockwise to remove it. Now you can tilt out the case-brake assembly and loosen the clamp that holds the drain hose in place. Pull the hose off (have a towel or Sham-Wow ready to catch the water). Then you have to remove the clamp or hose-restraint at the back of the dishwasher. Thaen you can pull the drain hose out and replace it.
Jun 28, 2014 | Samsung DMT800RHS Dishwasher
How do I change the waste hose on a Bosch Dishwasher Model Number SMS53E12GB the existing hose has been crushed by the base of the machine. I cannot see how I can get to the connection point at the base of...
It is not the easiest thing to do,here is what you have to do;
turn off power supply and water to the dishwasher
remove screws mounting d/w to counter top
remove lower panel
disconnect water and power from d/w
lower legs
pull out from under counter
remove panels covering door hinges
remove linkage from door spring to door hinge
remove the Torx screw securing tub to base frame in the front&rear
pull on base frame to seperate tub from frame about 8-10 inches
remove drain hose from drain pump/install new hose
reassamble in reverse order
Good luck,
Gene
Aug 06, 2011 | Bosch Dishwashers
My bosch dishwasher under counter model is not emptying. It seems to be blocked rather than the drain pump. How do I free it. Thanks in anticipation
Check under the counter to make sure that the hose has not gotten something pushed against it and gotten a kink in it.
Feb 03, 2011 | Dishwashers
Drain hose leaks. can i buy a replacement house
You can use generic hose.
Turn the breaker off.
Remove your unit. It may have screws holding it to the underside of the counter. You may also need to lower the front legs by turning the feet with a wrench.
Look under the machine and disconnect the drain hose. Take care as there will be water in the system.
Look under the sink and disconnect the other end of the drain.
Take to Home Depot and get a section of the same length and diameter.
Installation is the reverse of removal.
Hope this helps you. Please rate this answer if so.
Mar 21, 2010 | Bosch 24 in. SHU66C05 Stainless Steel...
Bosch Dishwasher pump keeps emptying
Disconnect the power to the unit. Remove the lower access panels and check the tray under the dishwasher. You will probably find it is full of water. Use a towel or a sponge to remove the water. There is a float that will stop the operation of the unit and run the pump if water is in this tray. Test the unit. If there are no leaks, check the drain hose under the sink. THE DRAIN HOSE MUST RUN UP TO ABOVE THE TOP OF THE MACHINE THEN TO THE DRAIN. If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overflow into the tray under it.
If there is no water in the pan under the dishwasher there may be a problem with the pressure switch at the side of the pump housing but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
Go here for Bosch Dishwasher Parts: http://www.repairclinic.com/Bosch-Dishwasher-Parts
www.RepairClinic.com
Feb 11, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch Dishwasher SHV4303UC - Does not drain.
Try looking for slithers of glass etc under the impeller. Remove the sump covers (filters) and look into the bottom. There will probably be a small cover held down by a screw. Under this is the impeller. Roll up a hand towel into a cigarette shape and slide this under the impeller - that should clear anything out.
Jan 20, 2008 | Dishwashers
Shu5312uc bosch dishwasher
Since water doesn't drain out,it could be a clog in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Aug 02, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Replacing a drain hose
If you remove the steel left side panel you can see that the drain hose only extends a short way into the machine. Where the hose enters the pan is a white clip that has a small square hole this clip can either be removed by pushing on it from the inside or prying the small square hole with a screwdriver. the drain hose is held in place by a black triangular clip on the plastic drain loop simply pull the clip off and slide the drain hose down then pull it out from the back of the machine.
Dec 04, 2006 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch 24 in. SHV4303 Built-in Dishwasher Logo
302 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
