I JUST BOUGHT A HITACHI SIMPLE TOUGH 300 GIG EXTERNAL DRIVE. IT'S BEEN WORKING OK UNTIL TODAY. I REQUESTED IT BACKUP MY WHOLE C:\ DRIVE AND I RECEIVED A ERROR MESSAGE "WD BACKUP HAS ENCOUNTERED A BROBLEM AND HAS TO SHUT DOWN". I TRIED IT 3 MORE TIMES AND I GET THE SAME THING. GEORGE T. SMALL geothomasssmall@aol.com
    President:
  • 1,561 Answers
go to Start > Programs > WD SmartWare and click on the WD SmartWare icon to relaunch the program. Once the program relaunches, it will find the WD SmartWare drive and continue the backup.
Take care.
Posted on May 29, 2010
Can I use the Clickfree HD10373 as an external hard drive? I do not want to use it for automatic backup.
Uninstall the automatic backup software and format the drive you purchased from them and you should be good to go.
Apr 02, 2014 | Click Free Computers & Internet
I backed up data w/ WD Passport External Hard Drive, and when finished my computer's free hard drive space went from 115 gigs to 11. What happened, and how can I fix this?
What could have happened is that you backed up your drive onto itself. Check your external and see if it's still empty. If you named the backup, search for that name and remove it. If not, retrace your steps right until the beginning of the backup and see what location the software stores the file then remove it.
Worst case scenario you can always use the windows restore utility and go back 1 day before you ran the backup.
Good Luck
Jul 17, 2010 | Western Digital Passport WDXML800UE...
My passport 5oo Gig freezes my computer
Yes there is. Please note that removing the drive from your external will likely void any warranty you may have with the manufacturer.
If ok with that, remove the drive from the enclosure very carefully. Then connect the internal drive directly to a SATA connector, do not use USB and see if able to access drive. If so, backup data right away.
If this model is only USB connector, or if still not accessible when connected to SATA, then you will need a reputable data recovery service provider.
Feb 15, 2018 | Western Digital Passport WDXML800UE...
My XP will not boot when my Hitachi 1TB External USB 2.0 drive is connected. It gets as far as showing the Pentium screen and stalls.
Its probably trying to boot from your external drive.
Go into your bios and reset your boot setting to HDD0 as your first boot device, Disk drive 0 second and floppy third, unless you want to boot from an external drive. That being the case select an appropriate order.
If the bios shows your external HDD as HDD0, then you have to work out which is the drive carrying the operating system and set that to your first boot device.
To get into the bios, watch the boot screen for a key to hit to enter setup, normally its the "DEL" key.
May 03, 2010 | Hitachi 1TB External USB 2.0 Hard Drive
I got a Hitachi PortableDrive,500GB. How does the Backup-software on it works? I want to make an image of my PC, before I did it with "Acronis True Image". But the Drive above has a Backup- software, which...
this is really simple NEVER TRUST BACKUP SOFTWARE for one
you will not be able to back the HDD image that only occurs when the OS is installed trusting your HDDs proprietary software for backing up your data will only save a bunch of **** you'll never need or use , when backing up data like your whole computer there are only 4 locations that need to be backed Your Documents (videos , movies , photos , music , Etc.) your program executables your internet favorites and any game profiles , everything else is on your operating system and can not be saved since those files run through the OS registry saving them wont
save the registry loaded items so saving is redundant . stick
with saving the 4 items I suggested to an external HDD . as your
data grows daily save new data to your ext. HDD , it will take
a few minutes and you will have backed your all that needs to
be saved data . if you have any questions about backing data email at
terminalconnection@gmail.comand I will be more
than happy to assist you .
David
Jan 28, 2010 | Hitachi Computers & Internet
1TB WD essentials external harddrive timing out.
Well, never mind then. A simple usb port swap did the trick. Always something simple...
Sep 04, 2009 | Computers & Internet
Troubleshoothing a external Hitachi HDT72505OVLAT80 500 GB
I use Acronis for backups, Win Backup seems to corrupt from time to time but firstly I would check your backup drive for reliability. Run CHKDSK/f to the drive in question.
Jun 17, 2017 | Hitachi HDT725050VLAT80 500 GB EIDE Hard...
External hard drive disk space
Hi
Is it showing the 300gig in the properties? if yes then try to copy with command mode,If again its given problem then u need to backup your data and format the drive, then try copying.I think it will work.
T.Boopathy
Aug 17, 2008 | Western Digital My Book Essential Edition...
Installing driver
you dont need drivers for hds in windows XP if the operative system is already installed and you are trying to connect an external HD via USB... if this is your case you dont need drivers...you probably have another problem in your OS... And if there is a driver problem and the disk is HITACHI, just go to manufacturers website and thats all... good luck
Apr 06, 2008 | Computers & Internet
Backup hard drive to an external hard drive
"what the error actually says is, you have either run out of space, or the backup file (.bkf) is too large for this disk. note: if the disk is formatted with FAT32, the maximum possible size for the backup file is limited to 4 gigs."
That error means that the FAT32 file system only allows 4GB files or smaller to be transfered. The chance that the backup file (.bkf) is larger than 4GB suggests that this file is causing your problems. You could try manually copying around that file (selecting all files from that folder except the large one) and see if that works.
Usually you will get many errors copying a drive directly as system files will be inaccessible and whatnot. Your best bet is to limit your copying to "C:\Program Files\" and "C:\Documents and Settings\", assuming you have Windows.
Dec 13, 2007 | IO Magic Corporation GigaBank (I250HD35)...
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
