Question about Frigidaire Heating & Cooling
I have a Frigidaire Window Air Conditioner, Model # FAC127P1A2. It is 2 Years Old. It has only been used 5 times. I went to turn it on and got no response, no power light. I also tried the remote. I have checked the power at the capacitor and the Primary side of the relay, and it is good. Is there a known issue with this? Thanks Max
SOURCE: Replacement remote for window unit air conditioner
I have that model Air conditioner with remote. Although the remote is marked Admiral thats the only identifying marks on the outside. Here are pictures of the remote.
Top View
Side View
Battery Compartment Cover
Here is what is printed on the battery compartment cover label.
SHUNDE HUA AO
ELECTRONICS CO., LTD
Drawing No: DF11F1-01 (AL) KYK-1801
Part No: 814011422
QA: 01
Date: 2005.01.11
Hope this helps. You might try a company called Vance Baldwin they usually carry a large inventory of remote replacements for all kinds of applicances. Had to get a remote for my Panasonic DVD player and it was only $12.00 (brand new)
Posted on Jun 02, 2009
  • 534 Answers
SOURCE: MY 2YEAR OLD WINDOW AIR CONDITIONER WON'T POWER ON
Apparently the gfci on the plug (the reset button) has gone bad. The best thing to do is to purchase a new cord and replace it. These switches sometimes go bad. Good Luck
Dave
Posted on Jul 28, 2009
  • 289 Answers
SOURCE: Hoffwell Air Conditioner KFR 61GW turned itself off
You may want to check the thermocouple. It should be located on the front coil. You have to remove the front cover to see it. However, close the vents and try it. If is overly humid that front coil will just condense all available outside humidity and the thermostat will be frozen. Pull the thermo stat away from the coil so it is not being frozen. Replace TC after that test Good luck.
Ash
Posted on Dec 08, 2009
  • 1150 Answers
SOURCE: i have samsung split type room air conditioner,
http://aircon.ru/pbc_download/files/f1215245089.pdf
check out this web site as it has your items manual. It may help you trouble shoot what's going on. There is a trouble shooting section.
Hope this helps.
Posted on Feb 03, 2010
  • 193 Answers
SOURCE: Capacitor problems!!
it's not the cap's fault that i see as the real problem,the cap is used to start the compressor and is rated for so many starts per hour and if you go over this rating it will stress the cap and after some time it will fail and this problem is known as short cycling and is normally caused by your thermostat.Or the unit is starting up under large gas pressure loads due to air in the system and or moisture and can only be fixed by a new gas charge
Posted on Apr 23, 2010
My fan wonT shut off
Good Morning Judy,
I understand that the fan will not shut off on your Frigidaire air conditioning and heat, air conditioner, model# LRA18HMT2, even when you have turned your appliance completely off. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit break, for 3-5 minutes. When power is restored, turn your air conditioner to any cycle and let it run for 5 minutes before turning it off. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 14, 2014 | Frigidaire Heating & Cooling
My frigidaire air conditioners spit dirt all over the floor. My window unit and my through the wall unit in a sleeve both do the same thing. I called Frigidaire two years ago and they told me there were no...
1. Turn units off
2. Remove Filter
3. Spray a foaming cleaner on the coils (Dow Bathroom Cleaner)
4. Use a spray bottle filled with plain water
5. Replace Filter and Grill
May 25, 2011 | Frigidaire FAC124 wall/Window Air...
I have an LG window air conditioner that's about 2-3 years old. The cooling function doesn't work. It just blows air and makes the air conditioning sound. How can I fix it? Is there a cheap...
Hello, this could be a problem with the thermostat on you ac and not turning on your compressor or the unit has no revrigerant in it. Here is a links to where you can buy window ac's online. http://www.amazon.com/Frigidaire-FAX052P7A-Window-Unit-Conditioner/dp/B000Q7GSHQ. You can also try sears they might be able to install a window ac for you.
May 13, 2011 | Heating & Cooling
No power
Could be some kind of fuse it the unit.
Aug 17, 2009 | Frigidaire FAC107P1A Wall/Window Air...
CARRIER WINDOW AC IN INDIA
clean the drain system, find the restriction
Apr 21, 2009 | Frigidaire FAC107P1A Wall/Window Air...
Frigidaire FAH086N1T Thru-Wall/Window Air Conditioner
clean your return air filter, and while you have the front cover off you may want to clean the evaporator as well (it's the silver grill looking thing) some compressors come off their springs during transport and will rattle for years but still work fine.
Aug 02, 2007 | Frigidaire FAH086N1T Thru-Wall/Window Air...
Heating & Cooling Logo
94 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
