Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Double picture on start up
In the last three months when we turn on tv the right side of tv showing darker and showing double pictures on sometimes triple pictures and with horizental lines but after 20 minutes the piture become normal.my tv is sony KDL_46vl130 .my friends told me ot might need the change the bulb what do you think.
  • Shahid Electronics
    Shahid Electronics Jul 09, 2010
    toolkits, STOP answering tv questions/ chats. You have no idea how lcd tv works. No convergence section in lcd tv, ever. I need to report to admins of FY about your incorrect tv solutions.
  • 59 Answers
Lcd does not need convergence. the display panel is defective.
Posted on Jun 08, 2010
    President:
  • 1,099 Answers
It's a convergence issue. Go into the main TV menu under video settings and look for convergence. If it has an auto convergence select that and wait a minute the TV will adjust itself and give you a clear picture.
If the TV does not have an auto convergence and just regular convergence than select this. It will give you a grid pattern on your TV and you have to move the coursor (using TV remote) and adjust each "point" so that each line is perfectly white. If you notice red or blue anywhere on that "line" then you have to adjust using the up, down, left and right arrow keys to "line up the red and blue lines with the nearest white line. It takes time and patience to do, but when completed, all lines on the grid pattern should be pure white and you will have a great looking picture.
You have to do this will all TV inputs (Video1, Video2 and so on) the reason Zoom looks good, is because you never used that screen as much and so the lenses didn't have a chance to get out of syncs.
RPTV's are made of the three lenses (red, Blue and Green) and as you watch TV, these lenses slowly get out of alignment. So you should do a convergence about twice a year to make sure nothing is out of whack.
Good luck...
Posted on May 29, 2010
Our tv has been getting darker and darker - we've tried to adjust brightness in menu and have it set to far right but its still too dark. Is there another adjustment to brighten the picture other than...
In many many cases this is an indication of a failing picture tube. The gun assembly in the neck of the picture tube is shorting. There is a fix, but this is surely last resort and the final cure may not provide a fix. Picture tube rejuvenation is not always successful. I would certainly opt for a new TV. Thanks for asking, and show a few hands of support!
Mar 13, 2011 | JVC AV-27530 27" TV
When I turn on the set, the right half of the screen is distorted. It flickers, different colors move from center to far right of screen, double images that appear as negitives and sometimes that half of...
Symptom shows problem with lcd panel (screen) however, t-con board that is part of lcd panel could be defective and cause of these symptoms.
T-Con board is located at top center of cld panel at rear and would be covered with metal shield. There are three type of t-con board utilized according to lcd panel and are available in shopjimmy.com
Please check what t- con board is similar with your tv board to order it. If you are not handy with electronics stuff repair then local tv repairman will help you to replace t-con board that might solve your tv picture problem.
Thanks.
Jan 29, 2011 | Samsung LN46A550 LCD TV
KDL-40XBR5 has vertical color lines no picture .After 50 minutes picture shows back with right side darker. TV was purchase 2008
It sounds like you might have a defective LCD panel. Your warranty for your TV is 18 months. Some of these models the warranty was mis-printed and said only 12 months.
Sep 08, 2010 | Sony KDL-40XBR5 40 in. LCD HDTV
54inch Hitachi TV has double figures and colors red, yellow-not normal. Set approximately seven -eight years old. Lost remote control and direction book in moving. Is the set worth getting fixed? Generally...
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 11, 2010 | Hitachi 57F500 57" Rear Projection...
Dark picture
I contacted Sony directly. They were able to help me and didn't try to rip me off with some plan I didn't need.
Apr 12, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Pictures problems
It might be related to a small control board that is inside this model. It costs $180.00 to replace. Parts might not be available
Jul 03, 2008 | Philips 27PT6441 27" TV
Problems with TV
Our 37 inch Sanyo LCD HDTV has a problem with the picture distorted by being too wide. This has beenia problem for the duration since we bought the TV about three months ago. The PIX Shape button on he remote does not adjust this problem. We need help in solving the problem. Thank you.
fred_story@cpmcast.net
Oct 24, 2007 | LG LRSC26980 25.2 cu.ft. TV Refrigerator...
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
396 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
