Question about Cycling
How to attach front wheel free of brake pads after transport to trail head, the wheel won't re-attach without having the brake pads up against the wheel thus preventing free turning
    Brigadier General:
  • 8,546 Answers
Read this from the experts.
http://parktool.com/repair/readhowto.asp?id=160
Put the wheel on straight (tight up against the dropouts (those little grooves the axle fits into). Attach the brake cable if it was removed. Test the brakes. If way off center you need to adjust the relative tensions of the two pads so they oppose each other equally enough to keep them both off the rim unless you squeeze the brake lever.
If using the Quick Release to secure the wheel, read up on it.
http://www.bicyclinglife.com/HowTo/UseAQuickRelease.htm
Posted on May 29, 2010
Front right wheel doesnot want to turn on 2004 chevy trail blazer
check that the caliper is free to slide on the mounting pins It is necessary so that the caliper body can self centralise and let the brake pads come of the disc rotor. When the body seizes on the pins then one side of the caliper will have the pad in constant contact with the rotor and makes for bad braking and low economy
Feb 09, 2014 | Cars & Trucks
How do i change front brake pad on this car merecy sable 1989 -99
Remove the wheel, remove the 2 bolts holding on the caliper to the caliper carrier. You will need a large C-Clamp or a cailper piston tool. Place an old brake pad against the piston in the caliper and use the C-Clamp to push the brake pad against the piston to collapses the piston into the caliper. Also open the master cylinder cap and place a towel around the area to catch any brake fluid that would come out of the master cylinder as you collapes the piston, this is normal, but doesn't always happen, depending on the level of fluid in the master cylinder. Install the new pads and reinstall the caliper and wheel. Make sure you pump the brake pedal a few times before you take off, to get the pads against the rotor.
Mar 16, 2010 | 1999 Mercury Sable
Noise coming from front brakes or wheel ,i change brake pads
Did you have the rotors turned? Did you check for rotor runout? Did you remove all rust from hub face and rotor mounting surface? Did you remove rust from caliper or pad slides? Lube all caliper and pad sliding surfaces? Are the pads application specific? Did you flush and bleed the fluid? Did you torque the wheels properly?
Feb 09, 2010 | 2005 Chevrolet Silverado 1500HD
Avid Juicy 7 disc brakes:The front wheel was removed and the brake lever squeezed while the wheel was off. The front wheel goes on, but does not spin freely. It turns easily, but not freely like it...
It sounds like you have a piston that is not fully returned and is sticking.
Get a big flat bladed screw driver, take the wheel out and very carefully insert the screw driver into where the disc would sit and use the screw driver to try and push each brake pad back in without damaging your brake pads.
If this works go to a local bike shop and ask them for a avid brake insert for transporting your bike so this does not happen in future! :)
Jan 13, 2010 | Avid Juicy Ultimate Hydraulic Disc Brake ,...
Brake pad replacement
Removal & Installation
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Remove or disconnect the following:
    • Negative battery cable
    • Front wheels
  3. Place a C-clamp over the caliper as illustrated, place a screw drive head against the outboard pad and hook against the rear of the caliper. Slowly tighten the screw drive and retract the caliper pistons into their bores and breaking the outboard brake pad from the caliper fingers.
  4. Once the pad is free, slide the caliper in on the guides to provide clearance between the rotor and inboard pad.
  5. Place an appropriate prytool through the center opening in the top of the caliper behind the inboard pad between the pistons using care not to contact the piston boots. Pry the pad to free it from the pistons.
  6. Remove the two caliper guide pin bolts and position the caliper aside. Remove the brake pads.
View of the caliper guide pins and boots (1), anti-rattle clips (2), brake rotor (3), outboard pad (4), caliper adapter (5) and inboard pad (6)
To install:
  1. Completely compress the caliper pistons
  2. Install or connect the following:
    • Brake pads with anti-rattle clips onto the adapter
    • Caliper and align the guide pin bolt holes with the guide pins. Install the pin bolts and tighten to 32 ft. lbs. (43 Nm).
    • Banjo bolt with new washers on each side of the hose fitting and tighten to 35 ft. lbs. (47 Nm)
    • Wheels
  3. Check and adjust the brake system fluid level and road test the vehicle.
Nov 01, 2009 | 2005 Chrysler Pacifica
How do i replace front pads on 2005 chrysler pacifica
PLEASE DON'T FORGET TO RATE!!!!
    • Front wheels
To install:
    • Wheels
Brake pads are shut fairly tight. Can't get disc
Your brakes adjust automatically (so when the pads wear down your levers don't get looser). What you did was pull the brake lever and it adjusted making the pads shut.
Anyway all you need to do is take a wide flat-head screw driver and wiggle it back and forth between the 2 pads.
Jul 10, 2009 | Avid Juicy Ultimate Hydraulic Disc Brake ,...
92 960 wagon with ABS.
Very easy. Jack up the front of the car and support it with two sturdy jackstands. Remove the front wheels. To the brake fluid nipple on the caliper (the part that squeezed the pads against the rotor), attach a small tube leading to a drainpan, open the nipple, and push back the brake pads from the rotor with a broad screwdriver. Close the nipple. Be careful not to damage the pads if you are not replacing them. (It would be wise to replace the pads when you replace the rotors, though).
Two bolts hold the brake caliper onto the steering knuckle. Remove both bolts, preferably with an impact wrench, and remove the caliper. On some cars the bolts have indented 10mm hex-wrench heads rather than standard bolt heads, so you may need to acquire a new tool. Be careful to support the caliper so you do not damage the hydraulic brake hose. Slip the old rotor off the studs and replace it with your new one. New rotors are packed in oil which will damage your brake pads, so clean the new rotors with vinegar before installing them. Replace the caliper and pads. Check to see you have sufficient brake fluid in the master cylinder reservoir before operating the vehicle. If the brakes seem at all spongy, bring your car to a qualified mechanic to inspect your work and to bleed the brake hydraulic syatem. Always do both front rotors, never just one. Otherwise, your car will **** violently to one side when you brake.
Oct 03, 2008 | 1996 Volvo 960
Back brakes won,t bleed
you can prevent it from inflating by wearing a anti staic bracelet. it has an alligator clip that will attach to a ground. just take your time and you will do allright. when bleeding brakes always start with the right rear then the left rear then right front and finally left front. this is a two man operation. please rate this solution thanks
Aug 30, 2008 | 1990 Buick Reatta
Cycling Logo
172 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
