Question about Keurig B50 Coffee Maker
Plastic part that upper needle is in is cracked
    Champion:
  • 213 Answers
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: The plastic piece that holds
Here is a tip that I wrote about how and where to get replacement parts foryour Keurig Coffee Brewer
Keurig CoffeeBrewer Replacement Parts
heatman101
Posted on Aug 13, 2011
Model 140m. Why doesn't the bottom bobbin loop to the needle?
The hook pulls the top thread around the bobbin. Remove the needle plate and turn the hand-wheel toward you while watching the needle. The hook should catch the thread as the needle is on it's way back up. The loop may not form since there is no material or needle plate, but you can see that the needle and hook are in a position for it to happen. This is called "timing".
A simpler answer might be bent needle, wrong needle or needle in backwards, all simple mistakes I have made.
When putting it back together be careful of the black plastic bobbin case as it is often easier to get it out than to get back in correctly.
Dec 01, 2015 | Janome Sewing Machines
Singer sewing machine needle moving to the side after it's in the fabric for a zigzag stitch
If you can grab the hand wheel and move it right and left, then it probably needs a plastic collar that goes next to the left upper shaft bushing.
If not then the cam timing needs to be adjusted.
Mar 13, 2014 | Kenmore 15516 Mechanical Sewing Machine
I have a brother ls-2125 sewing machine. the upper thread is not catching the bobbin thread properly. help please
  1. Tension
    • Your sewing machine tension controls the rate at which the thread is fed through either the upper section of your machine or through the bobbin case. If your upper or bobbin threads aren't threading properly, sometimes adjusting the tension will correct this problem.
    Timing
    • Your sewing machine works by passing the upper thread through the needle of the sewing machine at precisely the same time the bobbin brings its thread to its uppermost position. If either the needle or the bobbin thread reach these positions too soon or too late, the threads won't interact and create the knots that make the seam. You can throw off your timing by sewing too many layers of fabric or hitting a pin with your needle. See you sewing machine repair facility to correct any timing issues.
    Thread
    • Thread can get snagged or caught in the upper section of your machine or on lint pieces in the lower bobbin section. If your threads aren't catching properly, you may be able to fix it by unthreading and rethreading both your upper thread and bobbin threads.
Oct 15, 2011 | Brother LS-2125 Mechanical Sewing Machine
Cannot find little needle that goes into gas cup have tried a few repair shops they say nothing goes in it
There is a float needle in a carburetor that allow fuel to flow and shuts off fuel flow and is regulated by the position of the metal or plastic float in the float bowl or "cup" as you call it. The needle though is installed into the upper "main" body of the carburetor. You can repost if you like and provide the manufacturer name and model number of the machine you are referring to,
May 08, 2011 | Briggs & Stratton Garden
Coolant leaking in and around the intake manifold as well as the under carriage of that same part I think. Outake? I know that the part that attaches to the manifold appears to be metal but the manifold...
The plastic piece is the upper intake manifold. The metal part is the lower intake manifold. Sometimes the gaskets go bad between the upper and lower intake manifolds. But usually the upper intake manifold is cracked and needs replaced.
Nov 11, 2010 | 1993 Buick Park Avenue
I have a 98 lincoln town car executive and I need to know how you change the thermostat
1. drain coolant
2. remove engine cover
3. remove the 2 bolts from water hose connection (upper rad hose connecting to)
4. remove o-ring and thermostat
5. repeat in reverse order
Feb 05, 2010 | 1998 Lincoln Continental
Bobbin holder turns and keeps bending needles
hi,
the whole upper assembly may have come out of alignment when the machine bent the needle, the upper cover may have to come off, and study the inner metal area where the needle is attached for alignment bolts or screws, maybe one has come loose. On ours if you choose the zig zag and adjust it all the way out it will do that everytime. maybe download the user manual at www.brother.com and see if theres something in there also.
J
Jul 23, 2008 | Brother XL-2230 Mechanical Sewing Machine
Keurig B50 Coffee Maker Logo
239 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
