Question about Tunturi R30 R30 Series Rower
Has ceased to recoil - Tunturi R30 R30 Series Rower
    President:
  • Tunturi Master
  • 832 Answers
It sound like the return assembly cord has broken. If you mechanically incline then I suggest you pull apart your unit, but take pictures every step of the way until you uncover and inspect the return assembly. If you are not mechanically incline and since I don't know where you are located, go to the Tunturi website and locate your distributor they will be able to help you with parts availability, pricing and locate a servicer for you.
Posted on May 31, 2010
I have difficulty finding recoil starter for baurm 65 cc pro series engine
i dont doubt it
I cant find a online listing for the baurm recoil
anything on ebay for a bolt on recoil
maybe another makers recoil with 4 bolts will fit
you may have to take the recoil apart and replace what broke
Apr 09, 2017 | Garden
How to fix recoil starter?
It appears that the recoil spring is broken or has come away from its anchor position. It means opening the unit (usually 4 screws) and re-seating the recoil spring and rewinding the recoil spring so that it will recoil the starter rope with the correct tension. It may take a few attempts to get it right. If you do get it right, don't over-extend the starter rope when starting the washer. Someone was over-zealous!
May 11, 2014 | Troy-Bilt XP 3000 PSI 2.7 GPM Gas Pressure...
Recoil starter
Go to you tube On the line repair recoil core
Feb 14, 2014 | Toro Power Clear 418 ZR - Single Stage...
Pull cord not grabbing
The Dogs inside the Recoil are worn or Dirty is my first idea. But it could also be a loose Recoil also (This happened to me and my Ski Doo XP.
I purchased a new Recoil just to find out that 3 of the bolts were missing. Got new bolts and tightened it up and returned the Recoil. Ski Doo's Recoil Rebuild Kits do not last very long.
Nov 12, 2013 | Polaris 2010 WideTrak 600 IQ
Lawn mower recoil spring
Remove mounting nuts, pry recoil off fly wheel. Purchase new recoil assembly at mower repair store.
Jul 10, 2013 | Garden
Have champion 3500 watt generator recoil pull cord wont recoil HELP
need to take the recoil off the engine and check for a broken recoil spring, depending on the engine if it is a honda, they sell a replacement recoil unit, anything else and you will have to get creative....try tapping on the recoil with your palm and see if it trys to rewind, if no resistance or movement when bumping is a good indicator of a broken recoil spring....
Dec 14, 2011 | Electrical Supplies
I had to replace the recoil assembly on Electrolux 2000. Recoil works fine by it-self but when vacuum is reassembled the recol does not recoil. Why?
You have assembled it incorrectly and the recoil unit is sticking against something preventing the recoil. It is still tensioned ? Have you checked?
Feb 02, 2011 | Vacuums
Pulley cord wont go down unable to start on gas trimmer
Your cord wont recoil?
You should remove the recoil cover and see if you can rewind the rope manually.
It isnt too hard and will let you know immediately if you need to replace the recoil.
Just the recoil unit by loosening the three or four bolts and lift it off the trimmer. Turn it over and look at the recoil spool. There should be a notch in it. This is were you catch a bit of the starter rope and start turning it in the direction of normal rotation. Normal rotation will put tension on the recoil spring.
When you put 4-6 turns into it just let it recoil and see if it pulls all the rope back in. That's it. If the cord didnt recoil something inside the recoil has broken and you need to get the unit serviced or replaced. Most of the time the cost of repairing something like this is prohibitive. Its a better idea to just replace the whole unit.
Good luck and be careful!
Aug 11, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
The recoil turns but the crank wont turn at all. is it ceased up?
if you can pull the recoil full out then the fault is with the recoil remove recoil and try to turn crank by hand
Mar 15, 2010 | Coleman Powermate Premium Plus 6250W...
Tunturi R30 R30 Series Rower Logo
549 people viewed this question
Top Tunturi Exercise & Fitness Experts
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
