SOURCE: Hack wanted to enable multi region
1) Go to the Preference page in the Setup menu
2) Press 1 3 8 9 3 1 on the keypad of the RC. I had to hold each number down for 2 or 3 seconds.
3) Options will be available to be selected. Select 0 using up/down on remote.
4) Player is now region free.
SOURCE: regional code for dvd player
Follow the steps below:
1. go to standby mode
2. press stop button for 5 secs
3. blink light noted
4. press "enter", "84269" then "enter"
5. shut down unit and restart
Reagrding unlock of samsun ht-x715.
Found this
http://www.amazon.com/review/R2FMHKVOZYF6HX/ref=cm_cd_NOREF?%5Fencoding=UTF8&cdPage=&cdERR=noPurchase#CustomerDiscussionsPost
Worked for me with a small change
1. Remove disc from tray.
2. Switch off player and unplug from mains.
3. Wait 30 seconds, then reconnect mains.
4. Turn on player with remote. press the 'Repeat' on the remote for 10 sec'.
5. Press enter on remote. (There will be no on-screen response.)
6. Press 8, 4, 2, 6, 9 on the remote. (There will be no on-screen response.)
7. Press enter on the remote. Player will automatically shut off.
8. Turn player on.
9. Turn off.
10. Turn player on then off again.
11. Player is now region-free.
SOURCE: region codes for Samsung ht z110
Try this
1. Disconnect your player from its main power source for 30seconds
2.Reconnect your player to its power source
3.Press the power on button on your remote control
4.Press the Enter button on your remote control
5.Press 8,4,2,6 and 9
6.Press Enter on remote control and the your player will place itself on standby mode
7.press the power on button on remote control.
your player is multi region.
SOURCE: multi region code for philips hts 3090 dvd player
With your set on and without disc in the tray:
1. Press PLAY from your remote control
2. Press the following button sequence: 1590 2379 390
3. Press PLAY again
This will release the region verification in your home theater (region free). However, some DVDs (multiregion in particular) will not play, since they require region detection from the player unit.
I've done this to my 3090 and been using it like this for 3 years.
