Question about KitchenAid KP26M1X Stand Mixer
Kp26m1xwh Kitchenaid mixer 575 watt stopped working.
Sounds like a part broke while I was mixing bread dough. How do I open it up to look for part?
    Sniper:
  • 53 Answers
On the back of the mixer is a screw holding on the Kitchenaid name plate band that wraps around the mixer. Remove this screw and the name plate and then you'll see four screws (two on each side) holding on the top cover for the mixer. Remove the four screws and then lift off the top cover and you'll see the motor, circuit board and gear box that operate the mixer.
Posted on May 31, 2010
325 k5ss mixer stir speed not working, but works in all other gears
First congrats on the great mixer that you have. next the pro 6 or professional 600 series mixers are of an entirely different design than the one that you have even though they are both bowl lift. Do you really need 6 quarts capacity? The pro series is a 575 watt mixer BTW, and it will have more power available to you IF you are doing bread or a lot of food grinding, if that is a requirement that you have then the 6 / 600 series is the better suited mixer but if all you are doing is general medium to light mixing duties then fix and keep the K5SS it a great machine,
Mar 02, 2013 | KitchenAid K5SS Heavy Duty Commercial...
Kitchenaid 525 stopped working while mixing cookie dough
Let it completely cool and then start again. It overheated because your speed was set too low for the heaviness of the dough. I have burned up three kitchenaid stand mixers so far making bread. go up one setting at least; if it is straining, go up another.
Dec 15, 2012 | KitchenAid KP2671 Professional 6 Series...
Is 300 w mixer powerful enough to mix bread dough?
Your mixer is easily able to handle the kneading of bread dough. Please advise:
9 cups of all purpose white flour, maximum.
6 cups of specialty flour, maximum. This is any flour besides all purpose white.
Bread doughs are only to be needed on speed 2, and never for longer than 7 minutes.
This is all stated in the Use and Care guide for the mixer itself. If these guidelines are not followed, it may lead to a product failure.
Jul 02, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Used the bread kneading hook, after 10 minutes, smoking
The mixer motor has probably overheated, as proper use and care was not being followed with the stand mixer.
Bread doughs are recommended to be mixed on speed 2 only and never for longer than 7 minutes. With the resistance of a bread dough that is provided against the beater, mixing for over 7 minutes may overheat mixer and cause smoking.
Please consult your use and care guide to refresh your memory about how to properly use your mixer for making bread doughs.
Jun 07, 2009 | KitchenAid K45SS Classic Stand Mixer
Bread dough hook slips when mixing
This is not a solution but I think you have a serious problem you might have sheared some gear teeth whent the mixer jammed and it only manifests itself under a heavy load, I would take it to a repair guy, those mixers are expensive and it would be worth it.
Mar 28, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Pops out of lock under a heavy load
Hi Susan. There is no worse feeling than the feeling you get when you find that you've been seperated from your hard-earned money by a company that markets a product with glowing phrases of what their product can do...And then doesn't deliver on it's promises. Kitchenaid mixers can make short work of bread dough NOT! My Kitchenaid HD Pro (475 watts) self destructed after only 30 uses of making my Sourdough Bread. The problem? A cheap piece of plastic that takes the stresses of two important shafts in the mixer. Cheap, shoddy parts in a mixer you paid top dollar for. Kitchenaid shows no shame in doing so.
What is happening with your mixer as it tries to mix your dough is that the head unit is thrust back and forth and side to side (bucking). Eventually hinges become loose and sloppy. Kitchenaid's behaviour is legal and beyond reproach, so make your next mixer purchase an informed one.
Goto www.consumeraffairs.com and do a search for your Kitchenaid model. You'll notice that you're not alone in your mixer troubles.
I solved my mixer problems by buying a used Hobart 20qt. Commercial mixer (A200) and rebuilt it. When mixing heavy dough you should only use about 60% of the bowl capacity. less, if your mixer is agonizing with the amount of food in the bowl..
You will be able to replace the thumb screw. Be prepared to wait for at least a month for the part to arrive once ordered.
If this solution has assisted you, please rate it. Good luck! ricardok45
Mar 08, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
The pasta/meat grinder attachment stops turning
Its a 325 watt mixer. If you grind or mix dough often you may consider getting something stronger or turn it off every ten minutes or so and let it cool down. We burned a 325 and got the 575 watt "600" series and no problems ever since. I know these things are expensive. The 325 is more mixer than grinder. The attachements fit ANY size mixer but some are not recommended for use in all mixers.
If its quiting see my posts on "doesn't run at sitr" and "Removing the motor cover" To get inside and clean those contacts.
Feb 08, 2009 | KitchenAid KSM150PS Artisan Series Stand...
KSM90 Kitchen Gets stuck in the middle of mixing Bread Dough
Hi
If you decide to get rid of it can you sell the accessories parts?. I have one with no parts.
Thanks,
Barak
baraksch@nana.co.il
Nov 18, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Food Mixers Logo
293 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
