Question about Brother MFC 7420 All-In-One Laser Printer
I have a printer mfc-7420 and scanner locked is been displayed on the display. Any solution to these problem
  • 59 Answers
Scanner locked brother MFC-7420 please help! nothing works. have sound and beeping and messege scanner locked
The scanner needs to be reset. Turn off the device and then turn it on again.
Please note that when you turn off the MFC's power switch its memory will be cleared. To check whether the MFC has faxes in its memory, click here.
Nov 25, 2013 | Brother MFC-8840D All-In-One Laser Printer
Brother MFC 7420 change drum soon light, did, still says change drum soon, how do I rest the drum, I cannot find my manual. Tks
Simply open the front cover.
Press the Options key on the control panel.
The display will show "REPLACE DRUM - 1.YES 2.NO".
Press 1 to reset the drum count.
Close the front cover.
This procedure wil work on the majority of the Brother MFC series of laser based Printer Scanner Fax Facsimile machines.
Good Luck and Thank You for using Fixya
WheatlandServices
Nov 05, 2010 | Brother MFC-7420 Printer
I get a SCANNER LOCKED error message on my brother MFC-7420. The manual says to turn the unit off and back on but that does not clear the error. I can use it as a printer but cannot scan or copy. There...
leave it on for a couple minutes and turn it off for a couple minutes, and try again, if still does it, you are having a problem with the scanner not properly going to home position. it will need to be repaired.
Nov 28, 2009 | Brother MFC 7420 All-In-One Laser Printer
Model - MFC-7420 - FUSER ERROR
Is the paper that comes out of the paper warm or cool?
If "cool", then the fuser is not operating.
The job of the "fuser" is to generate heat to melt the powdered-ink into the paper, to make a permanent bond.
So, take the printer to a qualified technician, for trouble-shooting.
Nov 18, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420 screen displays "Back Door Open" have cleaned etc. Can you help ?
Remove the drum and toner (cartridge), look inside the machine, there should be a piece of paper, remove it and error msg should go away.
Nov 08, 2009 | Brother MFC 7420 All-In-One Laser Printer
Hi, I can't get my new Brother MFC-7420 to start up. Installed the software, everything is connected and seems to power up, but no display on the printer. Menu/Set button produces NO display. Any ideas??
yes your printer is problem power adopter i mean power supply or motherboard is demage some times ac fuse is burning please replace it then solve your problem
Aug 17, 2009 | Brother MFC 7420 All-In-One Laser Printer
RESET DRUM
Open the front door where you put the toner/drum unit in the machine. Press options then press 1.
Close the door.
Counter reset!
Aug 26, 2008 | Brother MFC 7420 All-In-One Laser Printer
Battery problem MFC 7420
Tis a long way down my friend, I've never had to change one, on any brother printer, but I've never encondered them knowing not the time either. I suggest you take it to the repair agent, or get a manual but for what its worth this is what I know
I've seen the battery when I've had the scanner unit off the base printer, comes off after all covers are removed and all the cables that attach them are disconnected, then theres clips on the sides and two(four?) locking screws on back(front?) from memory. and thats all a task in itself.
Heres the best pic i can find of the left base of your printer engine displaying battery position, hope this helps.
Cheers
Soulvisitor
Jan 11, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420 all in one Scanner not working
sorry but is the 7420 compatible with Vista? what does the box say?
Nov 08, 2007 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420 All-In-One Laser Printer Logo
515 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
