Question about Noritz 6.3 Gallon Residential Tankless Water Heater - N-063S
I have a nortiz 063-s tankless, and it won't stay on...I'm thinking it's the computer, please help
  • Chris Sellers
    Chris Sellers Jul 01, 2010
    is the burner indicator flashing? have you checked the incoming water filter?
    Scholar:
  • 73 Answers
There are several things I would look for:
-Flashing burner light (indicates an error code)
-Trying flowing more hot water. In the summer alot of times you'll flow less hot water because your cold water is warmer. If you flow additional hot water at your shower, it will ensure the unit stays firing
-If the unit doesn't fire at all, you may have debris in your cold water filter or a stuck flow sensor. Call tech support to help you with cleaning a flow sensor.
Posted on Aug 01, 2010
I have a paloma ph6dp water heater that hasn't
You have an old tankless computer and it won't work?
What would you do if you had old laptop computer that didn't work?
Copy following links for possible resources including required yearly maintenance so tankless computers can last 4-6 years before needing replacement:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
h
Sep 07, 2013 | Water Heaters
I do have noritz 0931m that some times work and some time not
The NC250 (N-0931M) Series ASME Tankless Water Heater is a commercial grade water heater and many people install the vent wrong. PVC CANNOT be used for venting. The NC250-DV-ASME is for indoor use only. Improper venting will cause the symptom you describe.
Feb 08, 2012 | Noritz NORTIZ Outdoor Propane Tankless...
After freezing weather the Noritz N-0751M-OD started leeking water and now there is no power to the unit or panel..is the unit toast?
I believe you killed it,I've installed two units direct vented through side wall in Minnesota and the cold wind blew in flu and froze up units,water stopped running in houses so we were able to save
Jan 28, 2011 | Noritz NORTIZ Outdoor Propane Tankless...
Help! We bought out home 3 years ago and have a Nortiz tankless water heater. Recently we heard a dripping sound coming from the water heater and found that the bottom of the unit is leaking. We had a...
you will need to explain more of where the leak is on the bottom. You have two plastic valves on the bottom and if the clips are not on exactly it will leak and if the person who replaced valves did not use vasoline when they put it back together the could have cut the gasket ring on the inside putting in back together and again it will leak. You have to determine where the leak is coming from to begin with using a flash light to get the exact location. .
Oct 05, 2010 | Noritz 6.9 Gallon Residential Direct Vent...
No hot water? How can we reset?
This happens with Nortiz heaters. They just **** out. Likely the installation is very bad, but the unit can not tolerate that and it just dies. I recommend getting a Bosch 2700 or 715. If you want great efficacy, get the C-800. But follow the instructions! If it is installed correctly and you have the CO2 levels adjusted when it is installed, you will be very happy.
Apr 11, 2010 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
Water becomes ice cold in the middle of a shower
Sounds like you have a problem with water flow. Since your ground water is warmer in the summer, you mix less hot and more cold in order to get the same warm temperature. If your hot water flow gets low enough, your tankless will start to "short cycle" in order to prevent scalding. Use one of these three methods to increase your water flow at the shower:
1) Clean your shower head and descale
2) Widen the hole in the showerhead's flow restrictor
3) Remove your flow restrictor entirely
Jan 24, 2010 | Noritz NORTIZ Outdoor Propane Tankless...
Reset button for tankless water heater
you need to unplug the unit, wait for 30 seconds reset the temp to the lowest temp, then try it, if this does not work it might have done something to the circuit board, are you on a gfi out let it needs to be there is water and ele, and should be on the gfi with a reset on it,,
Jun 01, 2009 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
Nortiz model n132m tankless water heater is flashing code 14
My guess it need reset.Turn power off for five to ten minutes and try that.The heat may have mis fired for the code.
Mar 15, 2009 | Water Heaters
How to fix my tankless hot water?
what is it doing, I would first check the inlet water screen and make sure that it's clean. shut off the water going to the unit and the screen is right after the shut off, unscrew it and clean it. replace and turn the water back on. you can ask for me again if this does not help
Jan 11, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
Noritz 6.3 Gallon Residential Tankless Water Heater - N-063S Logo
438 people viewed this question
Top Noritz Water Heaters Experts
jasbo
jasbo
Mack Baxter
Are you a Noritz Water Heater Expert? Answer questions, earn points and help others
