Question about Denon PMA-2000R 2-Channel Amplifier
The amp shuts down repeatedly after approx 3 mins of operation
The amp will operate then shut down into standby mode after about 3 mins of operation. If yuo try to start again immediatedly it will try but not operate and go to standby. If its left for 5 mins, you can restart and it will work again for apprx 3 mins, and shut down again.
    President:
  • 1,099 Answers
Its usually not a fault that you will see unless somethings burnt up. This is solid state electronics and you don't see this stuff go bad. But in the meantime try disconnecting the speakers and see if it still goes into shutdown and at the same time have a dc multimeter attached to the speaker outputs. If the unit comes on and you don't see any DC at all or very very little B+ on both speaker terminal sets then you may have a defective speaker. If you do see dc then that's why the protections coming on so you don't blow out your speakers. If you don't have any equipment or don't have any electronics experience I would then take the unit to a repair person for an estimate. Good Luck
Posted on May 29, 2010
;turn coleman hottub on - flashes "pr" for a few min. then it shuts off
If your Coleman has Balboa electronics 'PR' is to notify you that it is in priming mode.
It could also be your pressure switch. On most tubs the pressure is mounted on the heater. If this switch is not reading correctly it could shut the spa down to prevent heater overheating.
Sep 18, 2012 | Pool & Spa
Acer 8920 G restarts after 3 min and again shuts down
First make sure your fan is operating on your processor it takes about 3 mins for it to over heat and stop and shut itself down for safety to prevent burning up the processor.if its not this read on.
Also when you boot into safe mode then do a system restore to a date before the problem started. But first in safe mode run your antivirus scan to find something that is missed while being hid behind the operating system while functioning. Remember to rate my solution and leave testimonial this is how i earn my achievements here on FixYa thanks in advance
Apr 28, 2012 | Acer Aspire 8920-6048 Notebook
Dell pc with windows xp wont come out of standby mode to be able to power up pc and use it
First, how do you know it's in standby mode?
I would turn it off and disconnect from the power source. Then plug it back in and try to start it. If possible, start it in safe mode to see if you can identify what is happening. If in safe mode, do a system restore back a day or two.
var fctb_tool=null; function FCTB_Init_889fec04667049cfad3405862ebb395a(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_d9758fe2c8fa4d33bc34f8b0b6f0496c(t) { fctb_tool=t; start(fctb_tool); }
Jan 02, 2011 | Microsoft Windows XP Home Edition
Windows cannot find regsvr.exe at start up
Probably the easiest way to resolve this issue is by following the steps outlined below.
1. Shut down the computer.
2. Turn the computer on and immediately press F8 repeatedly until you get the "Advanced Boot Options" menu.
3. use the down arrow to select "Safe Mode" and press enter.
4. Window is should start with a "Help" window.
5. In the help window there is an underlined "What is System Restore?"
Click on that and "Click to open System Restore"
6. click on that and a new window comes up recommending restoring to a previous state.
7. Click ok and the operating system should restore your computer successfully and reboot into normal mode.
//javaftper
Jul 31, 2010 | Microsoft Windows XP Professional
Evaporator coils ice up after a few days and the refrigerator comparment only stops cooling. The unit is 2 years old. When removing the backing from the inside of the fridge and after thawing out the coil...
I have some information on your model and that would involve forced defrost by the service manual page 28 at bottom. How old is your Samsung? Forced Operation Function (Pull-down / Refrigerator Defrost / Refrigerator . Freezer-Defrost / Cancellation)
● This function enables a pull-down mode, a defrost mode for the refrigerator only, a defrost mode for the freezer and the
refrigerator at the same time, and a cancellation of this function.
● Press Power Freeze and Fridge Temp. buttons for 8 seconds simultaneously to get in the ready mode for a forced
operation.
● The display panel will return to normal after 20 seconds in the ready mode.
● At the ready mode, press any button(except Ice Type and Child Lock) once to start a pull-down operation, twice for a
defrost cycle for the refrigerator, three times for a defrost cycle for the freezer and the refrigerator, and finally four times
for cancellation of this function.
● Another way to cancel this function is to simply plug out and in the power cord.
1) Pull-down
1-1) At the ready mode, press any button once then the buzzer will beep (ON for 1/2 second and OFF for 1/2 second)
until this mode is cancelled.
1-2) At this pull-down mode, the compressor will start immediately (No 5 minute delay) and if the system is in the
defrost cycle, it will be cancelled right away.
note) If this pull-down mode begins right after the compressor was off, the compressor may not start to run due to an
overload condition.
1-3) At this mode, the compressor and freezer fan will operate continuously for 24 hours and the refrigerator fan will be
on and off according to the set temperature(34℉)
1-4) After 24 hour operation, the system will be cycled at -14℉ for the freezer and 34℉ for the refrigerator.
1-5) In order to cancel this mode at any time, select the next mode on the ready mode or power off the system.
2) Refrigerator Defrost / Refrigerator . Freezer-Defrost operation
2-1) At the pull-down mode, press any button again on the ready mode to begin the defrost cycle for the refrigerator.
2-2) The beep sound continues for 3 second at the beginning, then ON for 3/4 seconds and OFF for 1/4 second until
this mode cease.
2-3) After this operation, the system will come back to normal operation.
2-4) At this mode, press any button again on the ready mode to operate the defrost cycles for both compartments.
2-5) The beep sound continues for 3 seconds at that time, then ON for 1/4 second and OFF for 3/4 seconds until the
defrost operation cease.
3) Cancellation
3-1) At the R,F-Defrost mode, press ant button again on the ready mode to return to a normal operation.
3-2) Simply unplug the power cord, then plug it again to return to a normal operation.
Press both button for 8seconds at the same time Send maual in one moment, Thanks, Sea Breeze
Jan 20, 2010 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Problem to start after shutdown
first on ur laptop. then after 1-2 sec. press F8 4-5 times ....then u will see a menu..on the top , Safe mode will b written.select it & press enter............thenwait a few min..& go to control panel--system restore...choose a restore point ,,reading the instruction & choose the date or time before the installation of that antivirus..
Jun 01, 2009 | Microsoft Windows XP Professional
PC SHUTS DOWN ON ITS OWN
Could be a few different possibilities-
Power Supply failing
Overheating Issue
Virus-
first thing i would do is to try booting the computer up into safe mode with networking. to do this:
Shut off your computer and turn it back on- immediately start pressing the F8 key repeatidly until you get an advance boot menu- then go to safe mode with networking and press enter on your keyboard- See if Windows operates normally while in safe mode- If so then issue is probably a Virus.
Apr 09, 2009 | HP Computers & Internet
Model RE44SZ21D when I switch TV on it maks a whinning sound like a hard drive not reading properly and switches back into standby. Sometimes it will start, (normally if not tried for sometime) stays on...
hello john.
this is a late suggestion,but if you still have the set & the proplem
in existence.
then i suggest you check with the lamp---situated on the right hand
side ,two screws to undo--once in further two screws--pull back the
casing clean with a dry cotton cloth & with that clean the cooling
fan just adjasent to the case.+ remember to leave the tv on standby mode for 3 minutes before you completely switch it off ,as this helps to cool down the lamp the fan at rear still propels while the tv is in standby mode.--------ASH
Aug 14, 2008 | Televison & Video
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Denon PMA-2000R 2-Channel Amplifier Logo
150 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
