Question about Weber Genesis Silver B Grill
Only center tube lights - Weber Genesis Silver B Grill
  • 54 Answers
Check the orifice, they are the culprit most of the time. Be careful when cleaning the orifice its a small hole and you do not want to enlarge it
Posted on May 30, 2010
No lighted screen I can see the page is still there but it went dark
Hi There...
Your laptop picture tube gone so best of solution go to the nearest service center and replace the Picture Tube.
Sep 05, 2012 | Computers & Internet
I AM GETTING BRIGHT HORIZONTAL LINE IN CENTER OF THE PICTURE TUBE.& AND ALSO SCREEN WIDTH IS MORE
Sounds as if you have an older model T.V that still use Light tubes to produce the picture,both conditions are indicators that the picture tube is failing. Not many TV repair shops around anymore,since the price of Good quality TV's are realetively inexpensive. may need to buy another.the tubes themselves are very hard to find.
Jun 07, 2012 | Televison & Video
Have an Atwood LP water heater. When I light the pilot light and hold it for 30 seconds or more it stays lit but the burner tube will not light except for at the air/fuel mixture slits at the thermostat...
Yes, a good place to start would be to run a burner brush through entire tube to make sure all spider webs are out, then blow through again. If that doesn't cure it, double check your position of burner tube in chamber. Sometimes if it's moved into chamber too far, it will tend to back-up flame in to tube. I've had some that I re-installed and was sure I put it back exactly where it was before, but had to pull burner tube back approx 1/8"-3/16" to get a proper flame. Make sure it's centered in chamber as well.
Dec 06, 2010 | RTO Atwood Water Heater - 6 Gal LP
How do you remove the links from an invicta subaqua venom stainless bracelet?
it's not much harder then normal push pins, just a little trick..push the pin out, doesn't matter which way. You will probably have to pull it out with pliers once you get it started.
once that pin is out, the band still won't come apart. There is another pin, a tube actually that the other pin went thru. it connects the center links. to remove it, you have to first remove the outer links. to do this you push them inwards, toward where your wrist would be if you were wearing it. (the links are actually two pieces-the center 'snake-skin' piece, and the outer bars. the outer bars are connected behind the center piece) the outer bars are what you push inward, they will pop out once the first pin is out.
Now you will just have the center piece connected to the adjacent center piece. That second pin (the tube) will just about fall out if you turn the band on its side. Now the bracelet will come apart.
To put back together, just line up the to center pieces, slide in the tube, then put the outer links in from behind the center piece (this actually locks the tube in place) then put in the long pin.
Ideally it will slide in halfway easily, then carefully tack it in fully. if it doesn't get in halfway jiggle the links and tap lightly. Don't use too much force until it's past 2/3 inserted or you will bend the pin.
Jun 10, 2010 | Invicta Reserve Subaqua Venom Swiss Quartz...
Center and back burners won't light
cross over tube could be out of postion blocked or you need new burner
May 15, 2010 | Weber Genesis Silver B Grill
Poor picture no color
OUCH! LARGE DARK SPOT IN CENTER IS NOT GOOD FOR PROJECTION TV. YOU BURNT THE TUBES. THE LOSS OF COLOR IS THE ROOT CAUSE SOUNDS LIKE A DEFLECTION CIRCUIT PROBLEM. THE TIMING FEEDBACK IS USED TO SYNC THE COLOR CIRCUIT. IF THE TUBES LIGHT WITHOUT DEFLECTION THEY BURN THE CENTER PHOSPHOR COATING INSIDE.
Dec 24, 2009 | Televison & Video
All of the sudden my front right burner will not light. I clicks like it wants to light and you can smell the gas but it will not light.All the other burners are working fine.
Take a look at the burner when it is clicking and make sure the igniter electrode is creating a spark. If the burner head is removable pull off the burner cap and head. Inspect the burner head for debris and clean. Make sure any small holes on the burner head are not plugged. There is usually a small hole where the electrode is that a gas must exit for proper ignition. If the burner has a center igniter for two burners then inspect the flash tube for that burner and make sure it is centered and there is no obstructions in the flash tube. On that burner there are little holes located in front of the flash tube call step-up ports. Check to make sure those little holes are not plugged.
Sep 10, 2009 | GE Kitchen Ranges
Lighted line in center of tv
the trouble of your tv is not a picture tube.it's in vertical section,so check the supply of vertical IC if its ok ,re solder the ic.
Sep 30, 2008 | Emerson EWF2004 20" TV
D52W19 No pix, sound good - now green light blinks, no come on
First of all you need to find out which CRT leaked and replace it before any other repairs are done. The clear liquid is conductive and has done damage to the CRT board or boards.
Jun 15, 2008 | RCA D52W19 52" Rear Projection Television
Marshall tube amp problems
There is a bridge rectifier and red and black wires jumping from preamp tube to preamp tube. These need to be resoldered, take it to your favorite pro audio service center. I'm doing this to the same amp right this minute! Send it to me, I'll fix it. Tom Peary Norman's Electronics Atlanta, Ga 770 451 5057 www.neiusa.com
May 01, 2007 | Marshall 82 WTS LITHIUM BATTERY, 3 LED...
Weber Genesis Silver B Grill Logo
47 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
