Question about HP PSC 2210 All-In-One InkJet Printer
From the file > print dropdown menu only prints first page of multi-page document - will print all pages if using the printer icon in hotmail
  • 59 Answers
Check in the file print option that ALL is selected instead of pages. If yes, delete printer from printer folder in control panel, unplug printer, replug printer, reinstall software. It will work fine.
Posted on May 29, 2010
Lexmark pro 205 printing a blank page before a document
If you're using Windows, try to follow these steps to fix the problem.
  1. Start menu > Printers & Faxes > Lexmark Pro200 Series Properties window pops up > go to Advanced tab > Printing Defaults.
  2. The Lexmark Pro200 Series Printing Preferences window pops up > go to Advanced tab > More Options > under Suppress Blank Pages, enable "Enable blank page suppression"
  3. Save the setting.
  4. Try to print a document again to verify that the problem is fixed.
Nov 09, 2011 | Lexmark Prospect Pro205 Wireless...
My printer refuses to print. The Red Status light came on so I checked and found there was a paper jam - cleared that. Can get green light to come on if I press the job cancel button but still cannot get...
Perform a Factory Reset
Turn the printer power switch OFF on the right side of the printer. Check that the front cover is closed.
Turn the printer power switch ON while holding down the GO button until the Toner, Drum, and Paper LEDs are lit.
Release the GO button. All LEDs will be off.
Press the GO button 8 times. The Ready LED will flash briefly while the printer is reset. After the printer is reset the Ready LED will be lit.
Print a Test Print Page
Print the Print Settings by pressing the GO button three times.
- If the Print Settings pages do not print, check for alarm lights on the printer. Clear the printer error before trying to print again.
- If the Print Settings pages print, the problem is isolated to printing from your computer. Verify the printer cable connects from the back of the computer directly to the printer. If the cable has become disconnected, loose, or connects through another device, the printer may not be able to print.
Check the Printer Driver Properties
Follow the instructions below based on the operating system installed on your computer.
Windows 7:
Click on the Windows icon => Control Panel => View Devices and Printers.
Right mouse click the Brother printer. Left click See What's Printing. The print queue will open. If print jobs are listed in the printer queue, click Printer (at the top of the window) and click Cancel All Documents to delete the pending print jobs. Click Yes to confirm deleting the print jobs.
Click Printer at the top of the window again. Make sure that Pause Printing and Use Printer Offline are not check marked. If either setting is marked, click on the check mark to remove it.
Click Properties from this Printer menu list.
Click the Ports tab. Verify the correct port is selected (LPT1 is using a parallel cable and USB is using a USB cable). Remember to click Apply if you select another port.
Click the General tab and Print Test Page button. The Windows test page should now print.
- If the Windows test page prints, try printing from a program.
Windows Vista:
Click on the Windows icon => Control Panel => Printers or under Hardware and Sound click Printer.
Right mouse click the Brother printer. Select Run as administrator and left click Open. The print queue will open. If print jobs are listed in the printer queue, click Printer (at the top of the window) and click Cancel All Documents to delete the pending print jobs. Click Yes to confirm deleting the print jobs.
Windows XP and 2000:
1. For Windows XP Professional, click on Start => Printers and Faxes.
For Windows XP Home Edition, click on Start => Control Panel =>Printers and other hardware => Printer and Faxes.
For Windows 2000, click Start => Settings => Printers.
2. Double-click the Brother printer to open the print queue. If print jobs are listed in the printer queue, click Printer (at the top of the window) and click Cancel All Documents to delete the pending print jobs. Click Yes to confirm deleting the print jobs.
3. Click Printer at the top of the window again. Make sure that Pause Printing and Use Printer Offline are not check marked. If either setting is marked, click on the check mark to remove it.
4. Click Properties from this Printer menu list.
5. Click the Ports tab. Verify the correct port is selected (LPT1 is using a parallel cable and USB is using a USB cable). Remember to click Apply if you select another port.
6. Click the General tab and Print Test Page button. The Windows test page should now print.
Nov 01, 2010 | Brother HL-5240 Laser Printer
I was printing a downloaded document on my HP C5180 printer that contained 144 pages. The printer started at page 144 and stopped at page 44. How do I get it to print the remaining pages without reprinting...
You don't specify from which application are you printing, or even what operating system are we talking about.
If it's Windows, then you need to open your document, hit Ctrl+P or choose File->Print from the menu, and in the Print dialog that appears specify "1 - 44" in the Pages field. Finally confirm by clicking OK.
Please come back and leave a rating/testimonial if helped.
Aug 08, 2010 | HP Photosmart C5180 All-In-One InkJet...
How to print a page from a website
Please follow the steps to Print a web page using the Internet Explorer or Mozilla web browser.
>Please click on File, Print or press Ctrl+P key and then select the Printer( HP Officejet 5610), select the page range and click OK to print the web page contents.
>You can also preview the web page you're trying to print and then print it (File-->Print Preview).
Good Luck!!!
Jul 02, 2010 | HP Officejet 5610 All-In-One InkJet...
Printer prints approx one third of the first page of the file and then requires a restart from the printers page to continue. It will not print multi page documents
Go to start>>>Control Panel>>>Printers.
Make a right click on Printer Icon select Properties.
Go to Advance Tab.
And make sure that Print directly to printer is unchecked.
May 20, 2010 | HP PSC 950 All-In-One InkJet Printer
Won't print from Web page
make sure your firewall settings in the exceptions or advanced settings window lists your printer and it is selected. If it is not listed browse your programs using the add program at the bottom of the page and select your printer device program. Also, in your device settings for the device you are using to connect to the Internet is configured to allow your printer and files shared option enabled.
Apr 03, 2010 | Brother Multi-Function Center MFC-240C...
The printer will not print on the half inch left edge of the page.
go to settings and change the left margin to 0.0. if in Word, then file->page setup and set the margins to what you want, left margin to 0.0 in your case.
Sep 02, 2009 | Laser Office Equipment & Supplies
Printer will only print page 1 of multiple page documents
1. Check that you are using the latest print driver - from kyocera website.
2. If the issue is when you print pdf files then make sure you set the printer in KPDL Auto mode - check the print driver settings about this and the printer menu.
3.You may check if you have the latest firmware installed within the printer - print a service status page (Menu->Others->Service).
Nov 26, 2008 | Kyocera FS-C5030N Led Printer
Hi, I am using ms word 2007 and need an a3 sheet format. Its not in the page set up drop down menu and the only solution I have is to customise my page size. Even doing this however, and increasing my...
The print sizes available are dependent on the printers installed.
If you don't have an a3 printer installed on your computer, there won't be a A3 option in word.
if you install a standard pdf printer like cutePDF(simulates printer, but instead of printing document on paper, it generates an adobe pdf-file from the document) the option should become available in your dropdown.
Apr 04, 2008 | Computers & Internet
HP PSC 2210 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
