Question about Frigidaire GLWS1233A Top Load Washer
Washer wont spin on its own but spins with a push
    President:
  • 1,902 Answers
Remove that back panel and make sure that the belt is on and not broken. If the belt is good then make sure that the motor is still good and working correctly
Posted on May 29, 2010
My machine wont run, i replaced the drain pump and thermostat sensor.
Depending on your model pushing soil level and spin speed at the same time then hitting the power button will start it in diagnostic mode from here out pushing start will check its features, door lock, low spin, high spin, pre wash, wash, bleach, softener, rinse, drain, spin...ext
Jun 01, 2014 | LG WM2688HWM TROMM SteamWasher
Washer wont operate a spin cycle
What is the model number of your unit?
Nov 24, 2012 | Washing Machines
Washer wont operate even with lid shut. I have to push on lid until it starts.
What happens over time is the lid gets a little bent from use , reason it wont start unless lid is put down is because there is a lid switch that is called a safety switch, you might have to bend down lid some or this: Ok, first check under the lid, there is a peg that goes into the top edge of the washer. That is a switch. The idea between this is that it is a safety feature for mostly kids, so that when the washer is on that high speed spin cycle, that a child does not open up lid and stick there arm or hand in and have it injured. Most washer are designed so that the washer will only spin when the washing machine lid is down. So, of course you have it down, but sometimes the lid might have got a little bent or warped. So first try with lid down pushing down on lid while on spin cycle. If still wont spin, most likely it is that switch that that peg goes into, if you take a knife or flat head screw driver, with lid up on spin cycle and push into that hole with the knife or flat head screw driver and do not here a click when pushing it and releasing it, then you need to replace that switch, it is pretty cheep, normally under 20 bucks and a appliance store and when picking up the part they can tell you exactly how to replace it yourself, it is pretty easy and only takes a few minutes. Hope this helps. Mike
Sep 09, 2011 | Maytag Ensignia 3.3 cu. ft. Top Load...
Wont spin or drain
Hello , this might help you.
Jul 31, 2011 | Washing Machines
Machine wases & epties just wont spin motor ok brushes around 20mm long filters all cleaned not sure where to go next?
Hello there,
Jul 27, 2011 | Washing Machines
Washer works fine but no spin cycle
Hello there,
Jul 27, 2011 | Kenmore 44042 Front Load Washer
My washer washes fine but when its time to spin it wont spin or drain waster
Under the washer lid you will notice a peg that goes into a slot, that is a safety switch that when it spins and you open it when spinning in automatically stops to avoid energy. Sometimes from normalmuse the switch goes out To test this Carefully when in spin cycle , and lid open putna flat head screw driver in that slot and drepress and try again. You know push in and push out, if you hear a clicking sound on when pushing in and out, then switch is probably good. If no click qt all, switch needs replacing, which is cheap and do it self job with basic instructions.
May 29, 2011 | Washing Machines
Washer will not spin
Check your lid switch with a screwdriver pushed into it but, be carefull the switch will now not prevent the tub from spinning
May 29, 2009 | Washing Machines
Washer washes and wont spin clothes in either the wash or rinse cycle
If you have little to no agitation (as well as spin), look for a broken motor coupling (connects motor to transmission).
If the motor coupling is ok, open the lid and select a spin cycle, insert a flat screwdriver or pen into the lid switch and try pushing the drum along in a clockwise direction. If it doesn't spin or spins slowly then the brake/clutch assembly is slipping and will need to be replaced.
Feb 25, 2009 | Kenmore 24032\24036 Top Load Washer
The washer runs threw the cycles but drum wont spin
If it is a topload whirlpool or kenmore, you may need a new lidswitch or motor coupler. What do you mean you push the drum to one side?
Jan 20, 2009 | Admiral AW22 Top Load Washer
Frigidaire GLWS1233A Top Load Washer Logo
71 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
