Question about GE Spacemaker Washer and Dryer Electric Laundry Center
My GE spacemaker top loader will not drain, makes buzzing noise
Water doesn't seem to want to drain, and I don't think its spinning properly. and whenever you think its going to drain it stops and makes a buzzing noise! any assistance would be great!
  • GE Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing MachineMy GE spacemaker top loader will not drain, makes  - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
Posted on May 29, 2010
Ge spacemaker stacked washer/ dryer drains, but does not seem to pump water while spinning. Cloths come out too wet
check for obstructions in the impeller preventing proper operation (coins , hair pins , bra wires etc )
Oct 20, 2016 | GE Washing Machines
My GE Spacemaker wslp1100 top loader is draining very slow causing error code dr. I took black drainage hose off and it seems to be clean. Filters are clean inside washer. I want to know if a coin could be...
You don't reveal full model number. It's not likely that a coin is blocking the water. The pump (part of the motor assembly) may be partially blocked inside or a garment (sock, u-shirt, etc.) may be blocking the water inlet to the pump. It's too early to remove the agitator.
Nov 22, 2013 | GE Spacemaker WSLP1100D Top Load Washer
Washer makes grinding noise but isn't doing anything else
Remove the cap off the agitator, flip back the top of the console, remove any nuts keeping the tub in the console. There will be a clutch ring that needs to be replaced. I have an older top load washing machine. I agitates, fills, and drains, but it won't spin. It sounds like it is spinning, but it doesn't. It might be the coupling. That is a 3 piece kit that goes between the transmission and the motor. I found the directions how to do it over the internet, got the part and fixed it myself.
https://www.structuredsettlement-quotes.com/
Nov 08, 2013 | GE GSM1800NWW Spacemaker 18" Built-In...
My whirlpool duet washer front loader wont wring out the clothese properly. We have replace the drain pump and cleared all the hoses and filters. It also doesn't seem to go in to real fast spin.
First, make sure your machine is not overloaded. Overloading will not allow the machine to spin out properly. Also, make sure its fairly level. Next, make sure that all the shocks on the drum are properly attached and in working order (after you pull off the access panel, the shocks are readily visible -- there are typically 4 of them, 2 in front, 2 in back). Their heads slip into a slot and then twisting them locks them in. Finally, I would pull of the drain line leading from the drain filter to the tub basin. Once its off, stick your hand up into the basin. All kinds of yuck tends to collect there, semi-obstructing the drain line, which permits more water to remain in the basin, which doesn't allow your machine to spin as quickly as it otherwise would.
Feb 24, 2013 | Whirlpool GHW9100L Front Load Washer
GE GSLS1100 Spacemaker won't spin or drain. Washes fine then makes a rattleling noise during spincycle.
When I first started using my washer when I hooked up the water it would fill the hose and then stop until I started the machine. Now when I hook up the washer to the faucet water starts to fill the machine before I close the lid and before I start the washing process....? The last time I used the machine it didnt drain and I had a flood, is there a problem with it now???
Jan 09, 2011 | GE Spacemaker WSLP1100D Top Load Washer
Front loader has gotten really really loud and shakes the whole floor when it spins properly. Today it left a lot of water in the clothes. It used to make a weird whining noise when it didn't spin out...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 13, 2010 | GE WBSR3140DW Top Load Washer
When the washer gets to the spin cycle it seems to stop and not pump out the water. All other cycles seem to work ok. It is a GE spacemaster 22"
heatman101
Sep 02, 2010 | GE Spacemaker WSLP1100D Top Load Washer
Spacemaker spin cycle problem
you may have something stuck in the drain pump......
first try using a wet/dry vacuum attach it to the drain hose and try to **** out what ever you have stuck in there... if that works you are good... if not you will have to get open the cabinet to get to the drain pump
Dec 23, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Ge washer not draining or spinning
HI yes you can remove the pump and clean. the pump is the problem
Oct 12, 2008 | GE WBSR3140DW Top Load Washer
GE Top Loader - Spin Cycle Problem
bad door switch, probably ripped out by a comforter or pillow
May 29, 2008 | GE WBSR3140DW Top Load Washer
GE Spacemaker Washer and Dryer Electric Laundry Center Logo
837 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
