Question about Kyocera Mita KM-1815 All-In-One Laser Printer
Only prints on restart
Our Kyocera network printer only prints when l restart on my laptop that has VPN software loaded on the other computers on the network printing is fine, settings on add printer are the same can you crack it?
  • 36 Answers
I don't completely understand your description.
On any printer problem, I always delete and reload the driver first.
I've spent hours only to find out there was a glitch in the original install.
A fast, simple thing to do, might be to share the driver off another computer and print through it.
Are you using the remote login when you are trying to print?
If so, the print driver has to be loaded on the server as well as on your computer. And you have to be enabled in the printers group with premission to print.
Posted on Apr 08, 2008
SOURCE:
How do I get my text messages transfered to my laptop so I can print them off? I have a kyocera hudro
. Download BackupTrans Software's "Android SMS + MMS Transfer" software .It help us extracts SMS and MMS messages from any Android device and stores them on the PC.
2. Connect your Kyocera Hydro to your PC via mini USB cable. "Android SMS + MMS Transfer" will scan your drive and create a list that it can sync to your computer.
3. Click on "Kyocera Hydro" under the list of devices in the left-hand panel of the software.
Select the messages from the list, click "File" -"Print SMS and MMS." Select your printer and then click "Print."
App Option
4. Press the "Home" button on the Kyocera Hydro.Tap the "Google Play" icon to open the application market. Search for "PrinterShare Mobile Print." Tap "Install" to download and install the software.
5. Both the printer and the phone need to be on the same wireless network.Tap the app to searches the network for the printer.
6. Tap "Messages" to open your SMS and MMS messages in PrinterShare. Select the wireless printer.
Manual Method
7. Click on the messages and then tap"Copy message text".
8. Return to your Home screen and then open the email app.Compose a new message to yourself and paste the messages you want to print.Tap"Send".
9. Open the email on any computer connected to a printer and then click "File," and choose "Print".
10. Then you have successfully print your message from Kyocera Hydro.
Aug 12, 2014 | Boost Mobile Kyocera Hydro Smartphone
Kyocera will not print without kprint port
The KM-1650 will print useing a standard TCP/IP port printing over the network, I have done it ever since the machine came out. Load the print driver as a local printer and then setup a TCP/IP port and set the printer to print to that port in the printer properties.
Let me know if yo need more help.
Jan 15, 2010 | Kyocera Copystar Printing Systems -...
I access my office computer using my laptop via a VPN. I have bought a HP Photosmart to print off the laptop. It is linked to the laptop using USB cable. How can I print from the remote computer via the...
Normally, we put the printer on the network as a network printer and then install the printer to the VPN as a device.
I think it's the same for you...you share the printer on your laptop, then it should be able to be found by the office computer as your laptop is on the VPN.
Carl
Dec 21, 2009 | HP Computers & Internet
How do I connect a LD 228 to my wireless network
Software loaded? Leave the printer on and restart the computer.
HTH,
Mike...
Nov 25, 2009 | Miracle Computers & Internet
Cannot setup/connect to Kyocera CS-2050
go to kyocera mita america online. they have all the drivers. you need the KX driver
Jan 21, 2009 | Kyocera CS-2050 Black and White Copier
Printer FREEZES and prints blank pages
I DON'T THINK ITS THE PRINTER. THIS IS A SOFTWARE OR NETWORK ISSUE.
1 IT SOUNDS LIKE CORRUPTED FILES BEING SENT TO PRINTER, OFTEN PDFS. CLEARED ALL PRINT JOBS? ALSO AS400 PRINT QUEUE?
2 ALSO SOUNDS LIKE A VIRUS POSSIBLY "Adot.BAT". go online to housecall.com and do online virus scan.
3 OR, SOME OTHER CHANGE OR NEW DEVICE ON THE NETWORK MIGHT BE INTERFERING.
FIRST, TRY ISOLATING THE PRINTER FROM YOUR NETWORK. UNPLUG THE PRINTER FROM ALL DATA INPUTS AND RESTORE DEFAULTS. (LEFT OR RIGHT BUTTON TO SERVICE MENU, PUSH CHECK BUTTON, LEFT OR RIGHT TO RESTORE DEFAULTS, PUSH CHECK BUTTON).
IT SHOULD RESTART, THEN CALIBRATE. NEXT PRINT A CONFIGURATION PAGE FROM ITS MENUS, IF NOT TWO PAGES NET CARD IS DEAD.
IF OK SO FAR, TRY CONNECTING IT JUST TO A LAPTOP. USB ONLY THIS WAY, OR USE A NETWORK HUB, SEPARATE FROM YOUR NETWORK. INSTALL ANY OLD LASERJET DRIVER OR PRINTER ON THE LAPTOP JUST TO TEST IT.
IF ALL THIS WORKS, THE PRINTER IS FINE. BEFORE RECONNECTING THE PRINTER TO YOUR OFFICE COMPUTERS, FIX YOUR NETWORK & INTERNET OR VPN PROBLEMS.
THEN, DELETE ALL HP LASERJET PRINTERS & UNINSTALL ALL HP DRIVERS ON ALL NETWORKED COMPUTERS AND SERVER. (EXCEPT ZIPPED DOWNLOADED DRIVERS). START NEW HP PRINTER INSTALLATION COMPLETELY FROM ZERO. REINSTALL ONLY THE DRIVER YOU NEED. PCL5 IS RECOMMENDED.
Jun 13, 2008 | HP Color LaserJet 2600n Printer
Can't print via wireless connection once VPN connected
You have changed your IP address when you connect to the VPN so your network is no longer valid for that VPN session. What you can do is share the printer and then add it as a shared printer while 'in session'.
Mar 26, 2008 | Computers & Internet
HP 7410 can't print anymore
I think I have solved this, any way it worked for me.
Turned off printer and turned off wireless router made sure no computers are on.
Restarted printer make sure wireless settings are installed in printer then restart router.Once router is up and running switch on computer and you should be able to print.
Hope this works for you.
Dec 17, 2007 | HP OfficeJet 7410 All-In-One InkJet...
Kyocera Mita KM-1815 All-In-One Laser Printer Logo
78 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Adorjani Laszlo
AAAA262430
Marvin
Marvin
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
