Question about Refrigerators
Water drips from the top back part of refridgerator - we have a top freezer
  • 1 more comment
  • Mike Smith
    Mike Smith May 29, 2010
    Need model number to help you .
  • Mike Smith
    Model number needed .
  • Mike Smith
    Brand and model number needed to help for the solution .
  • Refrigerators Master
  • 43,501 Answers
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
Water Running in Refrigerator from FreezerWater drips from the top back part of - 2_bing.gif
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on May 29, 2010
Water is draiNung in the refridgerator
drain tube for freezer defrost plugged, you will have to remove of the inside trim but an easy fix
Sep 02, 2012 | Whirlpool 21.0 cu. ft. Top Freezer...
Water dripping inside KTLA22EMSS01
Your freezer actually cools your fridge. It sounds like you have ice build up in your freezer behind the back panel. You should be able to unscrew the back wall inside your freezer. A hair dryer should help defrost or keep it open for a few and use a screwdriver to remove the build up of ice. The ice has made its way down the vent and when it hits the fridge it is above 32 degrees so it is melting. Hope this helps. I manage rental properties and have had it happen on a few occasions.
Aug 16, 2012 | KitchenAid Refrigerators
Refridgerator freezer is making noises
Hello, your refridgerator in most likely in defrost cycle. the noise your hearing is the water dripping on the hot heater and ice dropping off the evaporator. should only last 15 minutes and then your all set. Mike
Sep 15, 2009 | Freezers
Refridgerator ice maker leaking water
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Aug 17, 2009 | Whirlpool ET4WSKXS Top Freezer...
Refridgerator drips water from the cold air vent.
if your freezer is on top,you most likely have an overflowing defrost drain. there is a drain that starts in the freezer and continues down to the drip pan. start at the top and work your way down.
Jul 26, 2009 | Whirlpool ET4WSKXS Top Freezer...
Water dripping down inside from bottom of freezer
clean the drain line out,its a tube on the back of the refridgerator
Apr 26, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
WATER LEAKING FROM INSIDE BACK OF REFRIDGERATOR SAMSUNG 267LASH
The frigerator has a drip pan it may need to be empty. Check the water line for leaks going into freezer.
Apr 11, 2009 | Refrigerators
Water drains from freezer compartment into refridgerator
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 09, 2009 | Refrigerators
Whirlpool top freezer leaking into refridgerator.
Sounds like you need to clean the drain again.. if Im understanding right you fixed it once already and lasted 3 weeks.. sound like it plugged up again.. make sure drip pan under evapurator is clean
Sep 24, 2007 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
